Software Archive
Read-only legacy content
17060 Discussions
How to malloc a buffer on co-processor in offload mode?
songlinhai
   How could I malloc a buffer on co-processor in offload mode? I only know that I can malloc a buffer on host, and use "offload in" to malloc the same buffer on co-processor. Is there some ways that I can malloc the buffer on co-processor directly?
   Thanks a lot!
Bachar_Z_
You can use malloc directly inside the offload region!
if you want to use the buffer later on, you can use an output variable in the (size_t) and use it later as in variable for aother offload region.
you should do the cast!
Kevin_D_Intel
Perhaps Explicitly managed Heap-allocated Data discussed here provides the functionality you’re looking for.
Bachar_Z_
if we want to use the pointer p in more than one function, this way does not work!
Kevin_D_Intel
With the local pointer that is correct; however, with a global pointer as demonstrated below the method is usable with multiple functions. I also confirmed this with our Developers.
$ icc -V
Intel(R) C Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 13.1.2.183 Build 20130514
$ icc example.c -o example && example
q = 77
[cpp]#include <stdio.h>
#include <offload.h>
__attribute__ ((target (mic))) int *p;
extern void f1();
extern void f2();
void f1()
  // The nocopy clause ensures CPU values pointed to by p
  // are not transferred to coprocessor
  #pragma offload target(mic:0) nocopy(p)
    // Allocate dynamic memory for p on coprocessor
    p = (int *)malloc(sizeof (int) * 100);
    p[99] = 77;
void f2()
int q = 0;
  // The nocopy clause ensures p is not altered by the offload process
  #pragma offload target(mic:0) nocopy(p) out(q)
    // Reuse dynamic memory pointed to by p
    q = p[99]; // Will be 77
  printf("q = %d\n",q);
int main()
f1();
f2();
}[/cpp]
Bachar_Z_
My case was the following:
I have an object with a pointer sould be in Phi mem, and I use that object in may functionality inside the system.
in my case, the global array( pointer) does not work because I have many of this object. " static does have the same problem"
And then I used the size_t variable as output for the alloc part ofthe object and I can use that value whenever I need to apply some functionality to any obect of that type!
Corey_P_
With reference to Kevin's code example above using nopy to reference a buffer that is created on the Mics. This method currently has a problem when using multiple Mics, though works fine for a single device. Read here for further discussion on that specific method:
http://software.intel.com/en-us/forums/topic/393649
Corey
