Software Archive
Read-only legacy content
17060 Discussions
How to move Vtune to another machine
Philippe_C_
I would like to move a VTune Amplifier XE to another machine. How should I do to transfer the licence?
Thank you
Philippe
KitturGanesh
Hi Philippe, Are you using a single user or a floating license? If you are using a single user license then you should be able to install the Vtune package on the other system. A single-user license allows the license owner to install the product on mutiple systems. however, only ONE copy of the software may be in use at any one time. So on that new system, you can place the license file under C:\Program Files (x86)\Common Files\Intel\Licenses (if 64-bit arch) or same path but Program Files instead of (x86) in the path. Then you can set up the environment variable INTEL_LICENSE_FILE= and install that package on that system. It should work just fine. If you are using a floating license and the system you want to run on is not specfied as one of the hosts as part of the floating license, then you can change the host information and resend the license file which you can use to run on the other system. Can you let me know what license model you have? Single or floating? thanks, Kittur
Philippe_C_
It worked great, thank you
KitturGanesh
Great to know Philippe, thanks for the confirmation :-) Regards, Kittur
James_S_2
Hi, we had a Linux server decomissioned which was running VTune Amplifier XE 2011 Update 3. The licence should have been transferred to the new server but was not. We no longer have the support agreement for the software but are happy with the revision we have, it would appear to be node locked, so how could we update the node to the new server ?.
Best Regards
James_T_Intel
Hi James,
I will communicate with you via private message.  In the future, please start a new thread for individual issues rather than adding to an existing thread (even if a similar topic).
Sincerely,
James Tullos
Technical Consulting Engineer
Intel® Cluster Tools
