Software Archive
Read-only legacy content
17060 Discussions
How to print out android phone text messages?
lucy_l_2
Do you think you can print out text messages from android phone? The answer is yes, to print out android phone messages on computer, you need to move them to computer at first, then you can print them out as you like. And we can use iPubsoft Android Manager to move android phone messages to pc easily.
How to print text messages
Step 1:Connect Android Phone to PC and start the app on computer
If this is the first time you connect your android phone to computer, you shoule enable the USB debugging. You can follow the guide to open the USB bugging: Enter "Settings" < Click "Applications" < Click "Development" < Check "USB debugging".
Step 2: Preview messages and Start Export
After that you can open the transferred sms to print them out.
That's all!
Hbllmut_H_
Samsung Backup program can help you print text messages on your PC effortlessly in no time. Check the following step-by-step guide:
Xkoiul_L_
There is an Android Assistant working for transfer phone data. It allows you to connect phone to PC via USB cable. Just export your text and then print them out. Copy text messages from android
https://youtu.be/_TR-Z_rBAM8
eve_e_
To print out text messages android, this youtube video could also help:
https://www.youtube.com/watch?v=ao-J_tVcl44
Lena_F_
If you manage or backup your android phone with an android assistant, I think it can be easy to print out text messages.
You just need to transfer the texts from your phone to pc, and save them as printable formats, when your computer is connected with a printer, this is done. Print text messages android.
This guide can help a lot.
Vpmsae_V_
You can copy and past the text into an email you send to yourself and then print from a computer. However, the recommended solution is to use Android Manager tool. how to print text messages from android
Sahan_K_
u can also use android print option in latest phones
Hbcder_H_
In my opinion , you should transfer messages from android to computer , then you can print out these messages on the computer, if you don't know how to transfer ,what you need is a transfer tools , you need to install it on the computer, after then , connect you phone to the computer, next , it can provide a preview to you and you can select messages you want to transfer , the last , start to transfer android messages to the computer,
alan_s_1
If you want to print text messages from Android phone, you need to transfer the messages from your Android phone to computer first. After that, you can easily print text messages from Android phone with printer connected to your computer. You can learn how to print text messages from Android phone here step by step.
Baker__Emily
You can consider is to email the messages and then download the attach files to print them. Sending your SMS from Android to PC can be easy if the Message App on your phone equips the email feature. Just follow the detailed steps below to have a try:
Step 1. Email Android Messages
At first, you need to open the SMS App on your Android phone and find out the option Backup SMS from the menu. After that, you are able to elect the wanted conversations and click OK to send them to your email account.
Step 2. Download & Print the Messages
When the sending process ends, you can enter the email account on your computer and then download the attach files to check the contents. After confirming the messages, you can print them out by clicking the Print button.
McEwan__Ian
To Print out Text Messages from  Android Phone all you need to do is to get the messages to the computer first. Use Android Data Recovery to save the deleted/existing/formatted text messages to the pc as HTML, TXT,etc. Then use a printer to print it out.
Garcia__Ceciclia
According to user reviews, some people have printed messages by taking screenshots one by one. In fact, it is too troublesome. Here I suggest you to transfer text messages to PC, and then print off Android messages via printer. While, as you know that messages are usually saved on the phone memory or SIM card. Thus, in order to successfully print out text messages from Android phone, we have to turn to a third-party software. Then this Coolmuster Android Messages Backup is my recommendation.
By working this program, you are able to copy every detail of your text message conversations to PC, so that you can completely print out them via printer without any loss. In addition, this software is pretty easy to use, you can achieve your goal of saving SMS to PC and print off them within minutes.
Garcia__Ceciclia
In fact, it is pretty easy to restore lost SMS from Android device as long as you have worked an effective recovery tool. As you know, you can find over hundreds of recovery programs online which have claimed that they can help retrieve lost Android messages. However, most of them are not as effective as they should be. So in order to successfully recover deleted text messages from Android mobile phone,Coolmuster Android Messages Recovery software, which has been generally considered very useful on the market.
By running this Android Messages Recovery, you are able to preview all deleted SMS messages before restoring. Thus you can selectively mark your deleted messages to recover, as this software can display the whole messages on your Android phone, those existing ones are no exception.
