Software Archive
Read-only legacy content
17060 Discussions
How to provide application name with different language
Arthur_T_
I would like the specify different language on the application name so that when the device changed language. Our app name will show in proper language. Is it possible on XDK project?
e.g. we have Chinese / English app name, then when device in Chinese, it will use our Chinese app name to show under our App icon. Similar for the case of English.
Arthur_T_
Finally I base on a cordova plugin: https://github.com/speige/cordova-plugin-pgb-ios-localize-app-name
(iOS only and stated not work) to implement it. Now it supports iOS/Android and tested ok. Anyone can make use of the plug-in and change as needed.
Shahab_L_Intel
Please see if using a plugin as indicated in the following thread will help you do that:
https://software.intel.com/en-us/forums/intel-xdk/topic/599146
Arthur_T_
