Software Archive
Read-only legacy content
17060 Discussions
How to submit a Software Problem Report
Intel_C_Intel
First question:
How to I submit a "Software Problem Report"?
Second:
Here's the command line given to compile and the error:
f90 -c -cpp -O4 -static -fpe2 -warn argument_checking -DUNIX -Dunix -DALPHA -I. -I/gluonc/e614/e614soft/triumf/mofia/2.1.ko/source/include -I/gluonc/e614/e614soft/triumf/ybos/4.1/library -I/gluonc/e614/e614soft/triumf/cfm/2.3/source -I/gluonc/e614/e614soft/triumf/bru/1.1 -I/gluonc/e614/e614soft/triumf/mofia/2.1.ko/source/modules   xtalk_mod.f90
f90: Severe: xtalk_mod.f90, line 122: Please report this error along with the circumstances in which it occurred in a Software Problem Report
                            IF(remove_whit(ihit,DCWhits(iplane,:),DCTDC, &
[ Aborting due to internal error. ]
make: *** [xtalk_mod.o] Error 1
Here's a peek at the code around line 122:
                      IF(abs(iWireGood-iWireXtalk) <= iWireAway) THEN
!                            DCtdc(Whit2P%hits(ihit))%XTflag = 1
                         IF(ihit==1) THEN
                            NXtalkPHits(iPlane) = NXtalkPHits(iPlane) + 1
                            NXtalkWHits(iPlane,iWireXtalk) = &
                                 NXtalkWHits(iPlane,iWireXtalk) + 1
                                 DC_nPhits(iPlane)) /= 0)             &
                                 WRITE(lout,*)"Xtalk hit not found by remove"
                         ENDIF
                      ENDIF
Any Ideas?
Paul
See the Compaq Fortran Support Page for details on how to submit a problem report to Compaq.
Steve
Intel_C_Intel
Steve,
Thanks. Could you be a little more specific about the URL? I obviously
sent this message beause I did not find the correct link after 5 minutes
of searching.
I'm looking at the page www.compaq.com/support/fortran/index.html right now. I don't see "Software Problem Report" anywhere on the page. A search of the support site turns up a few hundred thousand matches for the words
"Software", "Problem" and "Report". The first twenty of these are not the
correct link.
Any Hints?
Paul
Jugoslav_Dujic
Valued Contributor II
The compiler obviously got it wrong and you should submit a problem report so the Compaq folks could fix it. Such problems can usually be workarounded by simplifying the line in question and breaking it into
several simpler lines, something like:
!= Variant 1 =================
iTemp = remove_whit(...)
IF ( iTemp /= 0) WRITE(lout,*...
!= Variant 2 =================
...remove_whit(ihit, DCWhits(iplane, 1:whatever)...
!= Variant 3 =================
TYPE(type of DCWhits), POINTER:: pDCWhits(:)
pDCWHits => DCWhits(iPlane, :)
...remove_whit(ihit, pDCWHits, ...)
I'm sure you'll eventually find the winning combination.
Explicit interface/module association for remove_whit, if you don't already have it, is highly recommended. Also, note that it would be wise to declare dummy argument for DCWhits as assumed-shape (:) for performance reasons (in which case explicit interface is required).
HTH
Jugoslav
If you have a software support contract, submit the report through the appropriate contact for that. If you want to send it to us informally, send a gzipped tar file of the source file that got the error, along with any include files (and module sources) required, to [email protected]. Please note that we're closed this week, so we won't look at it until next week.
Steve
