Software Archive
Read-only legacy content
17060 Discussions
How to use onesignal ? put that in index.html
Uriel_S_
Hello, I have a problem with onesignal.
Just do not know what to index.html to receive notification.
in that part of APP that put the codes to receive a message?
I'm a beginner.
Chris_P_Intel
Do you know Javascript? The OneSignal Cordova plugin (or their RESTful API) are going to require quite a bit of Javascript skill to leverage in your app.
Uriel_S_
I am new to Javascript.
But it's just a test.
Do you want something to appear.
My app is simple, a screen with 1 text.
Hugs.
Thomas_B_6
Hi Uriel,
the onsignal setup is quite straight forward.
Just check the Javascript examples.
1. Install the Javascript SDK (Google for Onesignal and XDK)
2. Create a simple xdk page with just on button in editor (btn_push)
3. insert the following Javascript into your js.file
4. Dont forget to prepare the Google ID and the Onesignal ID
Best,
Tom
(function () {
    "use strict";
      hook up event handlers
    function register_event_handlers() {
        // window.plugins.OneSignal.setLogLevel({logLevel: 4, visualLevel: 4});
        var notificationOpenedCallback = function (jsonData) {
            alert("Message was \n" + jsonData.message);
        window.plugins.OneSignal.init("xxxxx-xxxxx-xxxxx-xxxxx-xxxxx", {
                googleProjectNumber: "xxxxxxxxx"
            notificationOpenedCallback);
        // Show an alert box if a notification comes in when the user is in your app.
        //    window.plugins.OneSignal.enableInAppAlertNotification(true);
        /* button  #btn_push */
        $(document).on("click", "#btn_push", function (evt) {
            window.plugins.OneSignal.sendTag("Group", "My Testgroup");
          //  alert("Registered");
            window.plugins.OneSignal.getIds(function (ids) {
                alert("ID : "+ids.userId + "\nToken "+  ids.pushToken);
    document.addEventListener("app.Ready", register_event_handlers, false);
Uriel_S_
Does not work. Please look at my code in the pastebin.
 App.js > http://pastebin.com/RW67UCXH  end index.html  > http://pastebin.com/11CD0eKN
  <!-- cordova-plugin-statusbar Yes -->
  <!-- cordova-plugin-device Yes -->
  <!-- cordova-plugin-splashscreen Yes -->
  <!-- onesignal-cordova-plugin-pgb-compat Yes-->
  <!-- com.google.playservices Yes -->
  <!-- Minimum Android API 14 -->
  <!-- Target Android API 19 -->
Hugs
Uriel_S_
Yes.
Very good
