Software Archive
Read-only legacy content
17060 Discussions
How to use parallel inspector for a exe which runs as windows servcie.
skumawat
I have a exe which runs as a service. How can i user the parallel inspector for this exe to dectect memory errors.
Parallel inspector gives the options only to launch a exe, but my exe is already running as a service.
Rob5
New Contributor II
Currently there is not a way for Intel Inspector XE to attach to process. In order to obtain result confidence, Intel Inspector XE needs to analyze the application from beginning to end. If there is a way for Intel Inspector XE to launch the application, then the application can be analyzed. Additional information about a similar use was written in the following forum thread, which may be of interest.
http://software.intel.com/en-us/forums/showthread.php?t=80617
Sincerely,
Rob
Rob5
New Contributor II
Skumawat,
We will research this further as there does appear to be interest in analyzing application in the way you described. We will update this forum thread as soon as additional information is available.
Sincerely,
Rob
Rob5
New Contributor II
The following document describes how to analyze a Windows* service with Intel Inspector XE 2011
http://software.intel.com/en-us/articles/using-intel-inspector-xe-2011-on-a-microsoft-windows-service/
- Rob
SergeyKostrov
Valued Contributor II
-Take a look at command line options of your Windows service. SomeWindows services could be
executed in a Debug mode as regular Win32 applications for debugging (!);
- Take a look at a Microsoft'sPlatform SDK example 'Service' located at:
any year )>\Samples\WinBase\Service
and, if you have the source codes you could add such functionality for debugging or inspections with Parallel Inspector.
Sergey
