Software Archive
Read-only legacy content
17060 Discussions
How use GetCurrentDirectory
jschomaker
Would someone write all the code required to use the function GetCurrentDirectory? I cannot find any samples in any of the documentation or users guides. I've tried various things that don't work, such as:
Integer inum, ret
character*20 adirectory
ret = GetCurrentDirectory (inum, adirectory)
I don't get any compilation errors, it just doesn't work.
Jugoslav_Dujic
Valued Contributor II
First argument is length of character buffer:
IF (GetCurrentDirectory(LEN(aDirectory), aDirectory)) THEN
    !Strip trailing char(0)
    aDirectory = aDirectory(1 : INDEX(aDirectory, CHAR(0)))
Jugoslav_Dujic
...of course, aDirectory should probably be far more than 20. In general, you should use constant MAX_PATH (=260).
Jugoslav_Dujic
Bah, sorry for 3rd message, "Edit" button doesn't work -- I forgot .GT.0 in the first post.
jschomaker
Jugoslav,
Thank you!! It worked perfectly. You are GREAT. Do you know where in the documentation I could find examples of using this (or any) function? Thanks Again!
There are dozens of examples using Win32 APII routines provided with CVF. There's also the new book Compaq Visual Fortran: A Guide to Creating Windows Applications.
Steve
