Software Archive
Read-only legacy content
17060 Discussions
I can't build my first app in Android
marek_g_
Hi i've a proble, always crashing  if  I try to build a  works in emulate but was freeze in uploading state of building
xdk:client:[2016-04-12T00:39:56.837Z]: (1460421596838): memlim: 767557632
xdk:client:[2016-04-12T00:39:56.842Z]: (1460421596842): Setting NW crash dump to: C:\Users\CaioCoCora\AppData\Local\XDK
xdk:client:[2016-04-12T00:39:57.060Z]: (1460421597060): Intel XDK: 3088
xdk:client:[2016-04-12T00:39:57.061Z]: (1460421597061): Platform: win32-ia32 (6.3.9600)
xdk:client:[2016-04-12T00:39:57.061Z]: (1460421597061): System Info:  CPU: 4 X Intel(R) Core(TM) i5-3470 CPU @ 3.20GHz Physical Memory: 8527204352
xdk:client:[2016-04-12T00:39:57.061Z]: (1460421597061): NW: 0.11.7-rc10-dev
xdk:client:[2016-04-12T00:39:57.146Z]: (1460421597146): Created new theme: base
xdk:client:[2016-04-12T00:39:57.146Z]: (1460421597146): Registered new theme: base
xdk:client:[2016-04-12T00:39:57.147Z]: (1460421597147): Current theme is now: base
xdk:client:[2016-04-12T00:39:57.147Z]: (1460421597147): Loading theme from: ../../public/themes/xdk.json
xdk:client:[2016-04-12T00:39:57.148Z]: (1460421597148): Failed to load theme: xdk { [Error: Cannot find module '../../public/themes/xdk.json'] code: 'MODULE_NOT_FOUND' }
xdk:client:[2016-04-12T00:39:57.795Z]: (1460421597795): Starting client process initialization
xdk:client:[2016-04-12T00:39:57.813Z]: (1460421597813): NW Cache is up-to-date.
xdk:server:[2016-04-12T00:39:58.306Z]: (1460421598307): memlim: 767557632
xdk:server:[2016-04-12T00:39:58.311Z]: (1460421598311): Setting NW crash dump to: C:\Users\CaioCoCora\AppData\Local\XDK
xdk:server:[2016-04-12T00:39:58.542Z]: (1460421598542): Starting server process initialization
xdk:server:[2016-04-12T00:39:58.664Z]: (1460421598664): Http server started on the standard port 58889
xdk:server:[2016-04-12T00:39:59.685Z]: (1460421599685): NW Cache is up-to-date.
xdk:server:[2016-04-12T00:39:59.817Z]: (1460421599817): Component "core:assert" starting import
xdk:server:[2016-04-12T00:39:59.818Z]: (1460421599818): Component "core:assert" finished initialization
xdk:server:[2016-04-12T00:39:59.818Z]: (1460421599818): Component "core:component-error" starting import
xdk:server:[2016-04-12T00:39:59.818Z]: (1460421599818): Component "core:component-error" finished initialization
xdk:server:[2016-04-12T00:39:59.818Z]: (1460421599818): Component "core:command-line-options" starting import
xdk:server:[2016-04-12T00:39:59.818Z]: (1460421599818): Component "core:command-line-options" finished initialization
xdk:server:[2016-04-12T00:39:59.818Z]: (1460421599818): Component "core:service-error" starting import
xdk:server:[2016-04-12T00:39:59.818Z]: (1460421599818): Component "core:service-error" finished initialization
xdk:server:[2016-04-12T00:39:59.819Z]: (1460421599819): Component "core:buffer" starting import
xdk:server:[2016-04-12T00:39:59.819Z]: (1460421599819): Component "core:buffer" finished initialization
xdk:server:[2016-04-12T00:39:59.819Z]: (1460421599819): Component "core:signaler" starting import
xdk:server:[2016-04-12T00:39:59.822Z]: (1460421599822): Component "core:signaler" finished initialization
xdk:server:[2016-04-12T00:39:59.822Z]: (1460421599822): Component "core:signaler-group" starting import
xdk:server:[2016-04-12T00:39:59.824Z]: (1460421599824): Component "core:signaler-group" finished initialization
xdk:server:[2016-04-12T00:39:59.824Z]: (1460421599824): Component "core:logger" starting import
xdk:server:[2016-04-12T00:39:59.825Z]: (1460421599825): Component "core:logger" finished initialization
xdk:server:[2016-04-12T00:39:59.825Z]: (1460421599825): Component "core:http-request" starting import
xdk:server:[2016-04-12T00:39:59.826Z]: (1460421599826): Component "core:http-request" finished initialization
xdk:server:[2016-04-12T00:39:59.826Z]: (1460421599826): Component "core:database" starting import
xdk:server:[2016-04-12T00:39:59.827Z]: (1460421599827): Component "core:database" finished initialization
xdk:server:[2016-04-12T00:39:59.827Z]: (1460421599827): Component "core:version" starting import
xdk:server:[2016-04-12T00:39:59.827Z]: (1460421599827): Component "core:version" finished initialization
xdk:server:[2016-04-12T00:39:59.828Z]: (1460421599828): Component "core:userfs-name-converter" starting import
xdk:server:[2016-04-12T00:39:59.828Z]: (1460421599828): Component "core:userfs-name-converter" finished initialization
xdk:server:[2016-04-12T00:39:59.828Z]: (1460421599828): Component "core:crash-handler" starting import
xdk:server:[2016-04-12T00:39:59.830Z]: (1460421599830): Component "core:crash-handler" finished initialization
xdk:server:[2016-04-12T00:39:59.830Z]: (1460421599830): Component "core:i18n-support" starting import
xdk:server:[2016-04-12T00:39:59.830Z]: (1460421599830): Component "core:i18n-support" finished initialization
xdk:server:[2016-04-12T00:39:59.830Z]: (1460421599830): Component "core:theme" starting import
xdk:server:[2016-04-12T00:39:59.885Z]: (1460421599885): Component "core:theme" finished initialization
xdk:server:[2016-04-12T00:39:59.886Z]: (1460421599886): Component "server:userfs" starting import
xdk:server:[2016-04-12T00:39:59.894Z]: (1460421599894): Component "server:userfs" calling init()
xdk:server:[2016-04-12T00:39:59.964Z]: (1460421599964): Component "server:userfs" finished initialization
xdk:server:[2016-04-12T00:39:59.964Z]: (1460421599964): Component "server:user-profile" starting import
xdk:server:[2016-04-12T00:39:59.968Z]: (1460421599968): Component "server:user-profile" calling init()
xdk:server:[2016-04-12T00:39:59.968Z]: (1460421599968): Component "server:user-profile" finished initialization
xdk:server:[2016-04-12T00:39:59.968Z]: (1460421599968): Component "server:ui-builder" starting import
xdk:server:[2016-04-12T00:40:00.049Z]: (1460421600049): Component "server:ui-builder" calling init()
xdk:server:[2016-04-12T00:40:00.051Z]: (1460421600051): Component "server:ui-builder" finished initialization
xdk:server:[2016-04-12T00:40:00.051Z]: (1460421600051): Component "server:emulator-notification" starting import
xdk:server:[2016-04-12T00:40:00.055Z]: (1460421600055): Component "server:emulator-notification" calling init()
xdk:server:[2016-04-12T00:40:00.056Z]: (1460421600056): Component "server:emulator-notification" finished initialization
xdk:server:[2016-04-12T00:40:00.056Z]: (1460421600056): Component "server:emulator-webserver" starting import
xdk:server:[2016-04-12T00:40:00.057Z]: (1460421600057): Component "server:emulator-webserver" calling init()
xdk:server:[2016-04-12T00:40:00.058Z]: (1460421600058): Component "server:emulator-webserver" finished initialization
xdk:server:[2016-04-12T00:40:00.058Z]: (1460421600058): Component "server:zip-util" starting import
xdk:server:[2016-04-12T00:40:00.061Z]: (1460421600061): Component "server:zip-util" calling init()
xdk:server:[2016-04-12T00:40:00.061Z]: (1460421600061): Component "server:zip-util" finished initialization
xdk:server:[2016-04-12T00:40:00.061Z]: (1460421600061): Component "server:uuid-server" starting import
xdk:server:[2016-04-12T00:40:00.064Z]: (1460421600064): Component "server:uuid-server" calling init()
xdk:server:[2016-04-12T00:40:00.065Z]: (1460421600065): Component "server:uuid-server" finished initialization
xdk:server:[2016-04-12T00:40:00.065Z]: (1460421600065): Component "server:force-download" starting import
xdk:server:[2016-04-12T00:40:00.068Z]: (1460421600068): Component "server:force-download" calling init()
xdk:server:[2016-04-12T00:40:00.068Z]: (1460421600068): Component "server:force-download" finished initialization
xdk:server:[2016-04-12T00:40:00.068Z]: (1460421600068): Component "server:updater" starting import
xdk:server:[2016-04-12T00:40:00.073Z]: (1460421600073): Component "server:updater" calling init()
server:updater:[2016-04-12T00:40:00.074Z]: (1460421600074): config.base-auto
server:updater:[2016-04-12T00:40:00.074Z]: (1460421600074): url=auto
xdk:server:[2016-04-12T00:40:00.074Z]: (1460421600074): Component "server:updater" finished initialization
xdk:server:[2016-04-12T00:40:00.074Z]: (1460421600074): Component "server:editor-node" starting import
xdk:server:[2016-04-12T00:40:00.111Z]: (1460421600111): Component "server:editor-node" calling init()
xdk:server:[2016-04-12T00:40:00.111Z]: (1460421600111): Component "server:editor-node" waiting for delayed initialization
xdk:server:[2016-04-12T00:40:00.111Z]: (1460421600111): Component "server:cordova-lib" starting import
xdk:server:[2016-04-12T00:40:00.617Z]: (1460421600617): Component "server:cordova-lib" calling init()
xdk:server:[2016-04-12T00:40:00.747Z]: (1460421600747): Component "server:cordova-lib" finished initialization
xdk:server:[2016-04-12T00:40:00.748Z]: (1460421600748): Component "server:api-explorer" starting import
xdk:server:[2016-04-12T00:40:00.756Z]: (1460421600756): Component "server:api-explorer" calling init()
xdk:server:[2016-04-12T00:40:00.896Z]: (1460421600896): Component "server:api-explorer" finished initialization
xdk:server:[2016-04-12T00:40:00.896Z]: (1460421600896): Component "server:plugin-listener" starting import
xdk:server:[2016-04-12T00:40:00.899Z]: (1460421600899): Component "server:plugin-listener" calling init()
xdk:server:[2016-04-12T00:40:00.899Z]: (1460421600899): Component "server:plugin-listener" finished initialization
xdk:server:[2016-04-12T00:40:00.899Z]: (1460421600899): Component "server:git-runner" starting import
xdk:server:[2016-04-12T00:40:00.902Z]: (1460421600902): Component "server:git-runner" calling init()
xdk:server:[2016-04-12T00:40:00.903Z]: (1460421600903): Component "server:git-runner" finished initialization
server:editor-node:[2016-04-12T00:40:00.905Z]: (1460421600905): Starting Brackets node process C:\Users\CaioCoCora\AppData\Local\Intel\XDK\bin\node.exe C:\Users\CaioCoCora\AppData\Local\Intel\XDK\bin\node-core
server:editor-node:[2016-04-12T00:40:01.068Z]: (1460421601068): Brackets node is running on port 55317
xdk:server:[2016-04-12T00:40:01.068Z]: (1460421601068): Component "server:editor-node" finished delayed initialization
xdk:server:[2016-04-12T00:40:01.069Z]: (1460421601069): Component "server:ui-builder" calling start()
xdk:server:[2016-04-12T00:40:01.073Z]: (1460421601073): Component "server:ui-builder" finished start()
xdk:server:[2016-04-12T00:40:01.074Z]: (1460421601074): Component "server:emulator-webserver" calling start()
xdk:server:[2016-04-12T00:40:01.074Z]: (1460421601074): Component "server:emulator-webserver" finished start()
xdk:server:[2016-04-12T00:40:01.074Z]: (1460421601074): Component "server:editor-node" calling start()
xdk:server:[2016-04-12T00:40:01.074Z]: (1460421601074): Component "server:editor-node" finished start()
xdk:server:[2016-04-12T00:40:01.076Z]: (1460421601076): Intel XDK is initialized now
xdk:server:[2016-04-12T00:40:01.076Z]: (1460421601076): Writing to the server data file
xdk:server:[2016-04-12T00:40:01.078Z]: (1460421601078): Wrote server data to "C:\Users\CaioCoCora\AppData\Local\XDK\server-data.txt"
xdk:client:[2016-04-12T00:40:01.327Z]: (1460421601327): Successfully read server data file
xdk:client:[2016-04-12T00:40:01.454Z]: (1460421601454): Component "core:assert" starting import
xdk:client:[2016-04-12T00:40:01.455Z]: (1460421601455): Component "core:assert" finished initialization
xdk:client:[2016-04-12T00:40:01.455Z]: (1460421601455): Component "core:component-error" starting import
xdk:client:[2016-04-12T00:40:01.455Z]: (1460421601455): Component "core:component-error" finished initialization
xdk:client:[2016-04-12T00:40:01.455Z]: (1460421601455): Component "core:command-line-options" starting import
xdk:client:[2016-04-12T00:40:01.455Z]: (1460421601455): Component "core:command-line-options" finished initialization
xdk:client:[2016-04-12T00:40:01.455Z]: (1460421601455): Component "core:service-error" starting import
xdk:client:[2016-04-12T00:40:01.456Z]: (1460421601456): Component "core:service-error" finished initialization
xdk:client:[2016-04-12T00:40:01.456Z]: (1460421601456): Component "core:buffer" starting import
xdk:client:[2016-04-12T00:40:01.456Z]: (1460421601456): Component "core:buffer" finished initialization
xdk:client:[2016-04-12T00:40:01.456Z]: (1460421601456): Component "core:signaler" starting import
xdk:client:[2016-04-12T00:40:01.457Z]: (1460421601457): Component "core:signaler" finished initialization
xdk:client:[2016-04-12T00:40:01.457Z]: (1460421601457): Component "core:signaler-group" starting import
xdk:client:[2016-04-12T00:40:01.459Z]: (1460421601459): Component "core:signaler-group" finished initialization
xdk:client:[2016-04-12T00:40:01.459Z]: (1460421601459): Component "core:logger" starting import
xdk:client:[2016-04-12T00:40:01.460Z]: (1460421601460): Component "core:logger" finished initialization
xdk:client:[2016-04-12T00:40:01.460Z]: (1460421601460): Component "core:http-request" starting import
xdk:client:[2016-04-12T00:40:01.461Z]: (1460421601461): Component "core:http-request" finished initialization
xdk:client:[2016-04-12T00:40:01.461Z]: (1460421601461): Component "core:version" starting import
xdk:client:[2016-04-12T00:40:01.461Z]: (1460421601461): Component "core:version" finished initialization
xdk:client:[2016-04-12T00:40:01.461Z]: (1460421601461): Component "core:exit-notifier" starting import
xdk:client:[2016-04-12T00:40:01.461Z]: (1460421601461): Component "core:exit-notifier" finished initialization
xdk:client:[2016-04-12T00:40:01.461Z]: (1460421601461): Component "core:userfs-name-converter" starting import
xdk:client:[2016-04-12T00:40:01.462Z]: (1460421601462): Component "core:userfs-name-converter" finished initialization
xdk:client:[2016-04-12T00:40:01.462Z]: (1460421601462): Component "core:crash-handler" starting import
xdk:client:[2016-04-12T00:40:01.463Z]: (1460421601463): Component "core:crash-handler" finished initialization
xdk:client:[2016-04-12T00:40:01.463Z]: (1460421601463): Component "core:analytics" starting import
xdk:client:[2016-04-12T00:40:01.463Z]: (1460421601463): Component "core:analytics" finished initialization
xdk:client:[2016-04-12T00:40:01.463Z]: (1460421601463): Component "core:i18n-support" starting import
xdk:client:[2016-04-12T00:40:01.463Z]: (1460421601463): Component "core:i18n-support" finished initialization
xdk:client:[2016-04-12T00:40:01.463Z]: (1460421601463): Component "core:theme" starting import
xdk:client:[2016-04-12T00:40:01.463Z]: (1460421601463): Component "core:theme" finished initialization
xdk:client:[2016-04-12T00:40:01.470Z]: (1460421601470): Analytics ID: 6055cfef-a393-4d5d-8c4b-75f58c99e38a
xdk:client:[2016-04-12T00:40:01.471Z]: (1460421601472): onExit listener 0:
    at Object.exports.onExit (C:\Users\CaioCoCora\AppData\Local\Intel\XDK\xdk\core-modules\public\exit-notifier.js:17:2339)
    at setupDefaultAnalytics (C:\Users\CaioCoCora\AppData\Local\Intel\XDK\xdk\core-modules\public\analytics.js:17:1438)
    at C:\Users\CaioCoCora\AppData\Local\Intel\XDK\xdk\core-modules\public\analytics.js:17:6219
    at C:\Users\CaioCoCora\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:1229:26
    at _fulfilled (C:\Users\CaioCoCora\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:834:54)
    at self.promiseDispatch.done (C:\Users\CaioCoCora\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:863:30)
    at Promise.promise.promiseDispatch (C:\Users\CaioCoCora\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:796:13)
    at C:\Users\CaioCoCora\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:604:44
    at runSingle (C:\Users\CaioCoCora\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:137:13)
xdk:client:[2016-04-12T00:40:01.497Z]: (1460421601497): Component "client:app" starting import
xdk:client:[2016-04-12T00:40:01.497Z]: (1460421601497): Component "client:help-helper" starting import
xdk:client:[2016-04-12T00:40:01.497Z]: (1460421601497): Component "client:nativefs" starting import
xdk:client:[2016-04-12T00:40:01.497Z]: (1460421601497): Component "client:document-manager" starting import
xdk:client:[2016-04-12T00:40:01.497Z]: (1460421601497): Component "client:project-manager" starting import
xdk:client:[2016-04-12T00:40:01.497Z]: (1460421601497): Component "client:aa-controller" starting import
xdk:client:[2016-04-12T00:40:01.497Z]: (1460421601497): Component "client:build-validator" starting import
xdk:client:[2016-04-12T00:40:01.497Z]: (1460421601497): Component "client:projects-renderers" starting import
xdk:client:[2016-04-12T00:40:01.497Z]: (1460421601497): Component "client:projects-renderers-jsapp" starting import
xdk:client:[2016-04-12T00:40:01.497Z]: (1460421601497): Component "client:projects-renderers-webapp" starting import
xdk:client:[2016-04-12T00:40:01.497Z]: (1460421601497): Component "client:projects-renderers-iotapp" starting import
xdk:client:[2016-04-12T00:40:01.497Z]: (1460421601497): Component "client:active-sync" starting import
xdk:client:[2016-04-12T00:40:01.497Z]: (1460421601497): Component "client:apk-installer" starting import
xdk:client:[2016-04-12T00:40:01.497Z]: (1460421601497): Component "client:appcenter-options" starting import
xdk:client:[2016-04-12T00:40:01.498Z]: (1460421601498): Component "client:resource-manager" starting import
xdk:client:[2016-04-12T00:40:01.498Z]: (1460421601498): Component "client:resource-cocos2d" starting import
xdk:client:[2016-04-12T00:40:01.498Z]: (1460421601498): Component "client:resource-cocos2djs" starting import
xdk:client:[2016-04-12T00:40:01.498Z]: (1460421601498): Component "client:resource-phaser" starting import
xdk:client:[2016-04-12T00:40:01.498Z]: (1460421601498): Component "client:resource-pixi" starting import
xdk:client:[2016-04-12T00:40:01.498Z]: (1460421601498): Component "client:resource-easeljs" starting import
xdk:client:[2016-04-12T00:40:01.498Z]: (1460421601498): Component "client:resource-plain" starting import
xdk:client:[2016-04-12T00:40:01.498Z]: (1460421601498): Component "client:resource-render-frame" starting import
xdk:client:[2016-04-12T00:40:01.498Z]: (1460421601498): Component "client:resource-util" starting import
xdk:client:[2016-04-12T00:40:01.498Z]: (1460421601498): Component "client:bower-package-manager" starting import
xdk:client:[2016-04-12T00:40:01.498Z]: (1460421601498): Component "client:services-tab" starting import
xdk:client:[2016-04-12T00:40:01.498Z]: (1460421601498): Component "client:editor" starting import
xdk:client:[2016-04-12T00:40:01.498Z]: (1460421601498): Component "client:live-preview" starting import
xdk:client:[2016-04-12T00:40:01.498Z]: (1460421601498): Component "client:backend-services" starting import
xdk:client:[2016-04-12T00:40:01.498Z]: (1460421601498): Component "client:backend-feeds" starting import
xdk:client:[2016-04-12T00:40:01.498Z]: (1460421601498): Component "client:merged-feed" starting import
xdk:client:[2016-04-12T00:40:01.498Z]: (1460421601498): Component "client:backend-services-ext" starting import
xdk:client:[2016-04-12T00:40:01.498Z]: (1460421601498): Component "client:backend-service-utils" starting import
xdk:client:[2016-04-12T00:40:01.498Z]: (1460421601498): Component "client:cert-manager" starting import
xdk:client:[2016-04-12T00:40:01.498Z]: (1460421601498): Component "client:account-settings" starting import
xdk:client:[2016-04-12T00:40:01.499Z]: (1460421601499): Component "client:ui-builder-client" starting import
xdk:client:[2016-04-12T00:40:01.499Z]: (1460421601499): Component "client:project-meta" starting import
xdk:client:[2016-04-12T00:40:01.499Z]: (1460421601499): Component "client:contenttype-registry" starting import
xdk:client:[2016-04-12T00:40:01.499Z]: (1460421601499): Component "client:editor-registry" starting import
xdk:client:[2016-04-12T00:40:01.499Z]: (1460421601499): Component "client:platform-registry" starting import
xdk:client:[2016-04-12T00:40:01.499Z]: (1460421601499): Component "client:projecttype-registry" starting import
xdk:client:[2016-04-12T00:40:01.499Z]: (1460421601499): Component "client:library-registry" starting import
xdk:client:[2016-04-12T00:40:01.499Z]: (1460421601499): Component "client:cordova-registry" starting import
xdk:client:[2016-04-12T00:40:01.499Z]: (1460421601499): Component "client:service-method" starting import
xdk:client:[2016-04-12T00:40:01.499Z]: (1460421601499): Component "client:settings-db" starting import
xdk:client:[2016-04-12T00:40:01.499Z]: (1460421601499): Component "client:adb" starting import
xdk:client:[2016-04-12T00:40:01.499Z]: (1460421601499): Component "client:iosdb" starting import
xdk:client:[2016-04-12T00:40:01.499Z]: (1460421601499): Component "client:device" starting import
xdk:client:[2016-04-12T00:40:01.499Z]: (1460421601499): Component "client:device-discovery" starting import
xdk:client:[2016-04-12T00:40:01.499Z]: (1460421601499): Component "client:dialog-box" starting import
xdk:client:[2016-04-12T00:40:01.499Z]: (1460421601499): Component "client:test-local-server" starting import
xdk:client:[2016-04-12T00:40:01.499Z]: (1460421601499): Component "client:quick-tour" starting import
xdk:client:[2016-04-12T00:40:01.499Z]: (1460421601499): Component "client:hot-keys" starting import
xdk:client:[2016-04-12T00:40:01.499Z]: (1460421601499): Component "client:persistance" starting import
xdk:client:[2016-04-12T00:40:01.499Z]: (1460421601499): Component "client:tabs" starting import
xdk:client:[2016-04-12T00:40:01.499Z]: (1460421601499): Component "client:hash-utils" starting import
xdk:client:[2016-04-12T00:40:01.499Z]: (1460421601499): Component "client:file-watcher" starting import
xdk:client:[2016-04-12T00:40:01.499Z]: (1460421601499): Component "client:tool-tip" starting import
xdk:client:[2016-04-12T00:40:01.499Z]: (1460421601499): Component "client:cordova" starting import
xdk:client:[2016-04-12T00:40:01.499Z]: (1460421601499): Component "client:settings-ui" starting import
xdk:client:[2016-04-12T00:40:01.499Z]: (1460421601499): Component "client:external-links" starting import
xdk:client:[2016-04-12T00:40:01.500Z]: (1460421601500): Component "client:external-editors-runner" starting import
xdk:client:[2016-04-12T00:40:01.500Z]: (1460421601500): Component "client:project-list-load" starting import
xdk:client:[2016-04-12T00:40:01.500Z]: (1460421601500): Component "client:upload-manager" starting import
xdk:client:[2016-04-12T00:40:01.500Z]: (1460421601500): Component "client:git-manager" starting import
xdk:client:[2016-04-12T00:40:01.500Z]: (1460421601500): Component "client:new-project-creator" starting import
xdk:client:[2016-04-12T00:40:01.533Z]: (1460421601533): Component "client:help-helper" finished initialization
xdk:client:[2016-04-12T00:40:01.534Z]: (1460421601534): Component "client:nativefs" finished initialization
xdk:client:[2016-04-12T00:40:01.548Z]: (1460421601548): Component "client:active-sync" calling init()
xdk:client:[2016-04-12T00:40:01.548Z]: (1460421601548): Component "client:active-sync" finished initialization
xdk:client:[2016-04-12T00:40:01.550Z]: (1460421601550): Component "client:apk-installer" calling init()
xdk:client:[2016-04-12T00:40:01.550Z]: (1460421601550): Component "client:apk-installer" finished initialization
xdk:client:[2016-04-12T00:40:01.561Z]: (1460421601561): Component "client:resource-render-frame" calling init()
xdk:client:[2016-04-12T00:40:01.561Z]: (1460421601561): Component "client:resource-render-frame" waiting for delayed initialization
xdk:client:[2016-04-12T00:40:01.562Z]: (1460421601562): Component "client:resource-util" calling init()
xdk:client:[2016-04-12T00:40:01.562Z]: (1460421601562): Component "client:resource-util" finished initialization
xdk:client:[2016-04-12T00:40:01.568Z]: (1460421601568): Component "client:backend-services" calling init()
xdk:client:[2016-04-12T00:40:01.568Z]: (1460421601568): Component "client:backend-services" finished initialization
xdk:client:[2016-04-12T00:40:01.569Z]: (1460421601569): Component "client:backend-feeds" calling init()
xdk:client:[2016-04-12T00:40:01.569Z]: (1460421601569): Component "client:backend-feeds" finished initialization
xdk:client:[2016-04-12T00:40:01.570Z]: (1460421601571): Component "client:merged-feed" finished initialization
xdk:client:[2016-04-12T00:40:01.571Z]: (1460421601571): Component "client:backend-services-ext" calling init()
xdk:client:[2016-04-12T00:40:01.572Z]: (1460421601572): Component "client:backend-services-ext" finished initialization
xdk:client:[2016-04-12T00:40:01.572Z]: (1460421601572): Component "client:backend-service-utils" finished initialization
xdk:client:[2016-04-12T00:40:01.576Z]: (1460421601577): Component "client:project-meta" calling init()
xdk:client:[2016-04-12T00:40:01.577Z]: (1460421601577): Component "client:project-meta" finished initialization
xdk:client:[2016-04-12T00:40:01.581Z]: (1460421601581): Component "client:service-method" finished initialization
xdk:client:[2016-04-12T00:40:01.583Z]: (1460421601583): Component "client:settings-db" calling init()
xdk:client:[2016-04-12T00:40:01.583Z]: (1460421601583): Component "client:settings-db" waiting for delayed initialization
xdk:client:[2016-04-12T00:40:01.584Z]: (1460421601584): Component "client:adb" calling init()
xdk:client:[2016-04-12T00:40:01.594Z]: (1460421601594): Component "client:adb" waiting for delayed initialization
xdk:client:[2016-04-12T00:40:01.595Z]: (1460421601595): Component "client:iosdb" calling init()
xdk:client:[2016-04-12T00:40:01.595Z]: (1460421601595): Component "client:iosdb" finished initialization
xdk:client:[2016-04-12T00:40:01.601Z]: (1460421601601): Component "client:persistance" calling init()
xdk:client:[2016-04-12T00:40:01.601Z]: (1460421601601): Component "client:persistance" waiting for delayed initialization
xdk:client:[2016-04-12T00:40:01.602Z]: (1460421601603): Component "client:file-watcher" calling init()
xdk:client:[2016-04-12T00:40:01.603Z]: (1460421601603): Component "client:file-watcher" finished initialization
xdk:client:[2016-04-12T00:40:01.607Z]: (1460421601607): Component "client:external-links" finished initialization
xdk:client:[2016-04-12T00:40:01.607Z]: (1460421601607): Component "client:external-editors-runner" calling init()
xdk:client:[2016-04-12T00:40:01.607Z]: (1460421601607): Component "client:external-editors-runner" finished initialization
xdk:client:[2016-04-12T00:40:01.608Z]: (1460421601608): Component "client:project-list-load" calling init()
xdk:client:[2016-04-12T00:40:01.608Z]: (1460421601608): Component "client:project-list-load" waiting for delayed initialization
xdk:client:[2016-04-12T00:40:01.610Z]: (1460421601610): Component "client:upload-manager" calling init()
xdk:client:[2016-04-12T00:40:01.610Z]: (1460421601610): Component "client:upload-manager" finished initialization
xdk:client:[2016-04-12T00:40:01.611Z]: (1460421601611): Component "client:git-manager" calling init()
client:git-manager:[2016-04-12T00:40:01.611Z]: (1460421601611): git path =  C:\Users\CaioCoCora\AppData\Local\Intel\XDK\bin\git\bin\git.exe
xdk:client:[2016-04-12T00:40:01.611Z]: (1460421601611): Component "client:git-manager" waiting for delayed initialization
xdk:client:[2016-04-12T00:40:01.613Z]: (1460421601613): Component "client:new-project-creator" calling init()
xdk:client:[2016-04-12T00:40:01.613Z]: (1460421601613): Component "client:new-project-creator" finished initialization
xdk:client:[2016-04-12T00:40:01.618Z]: (1460421601618): Component "client:resource-render-frame" finished delayed initialization
xdk:client:[2016-04-12T00:40:01.623Z]: (1460421601623): Component "client:build-validator" finished initialization
xdk:client:[2016-04-12T00:40:01.631Z]: (1460421601631): Component "client:tool-tip" finished initialization
xdk:client:[2016-04-12T00:40:01.638Z]: (1460421601638): Component "client:ui-builder-client" calling init()
xdk:client:[2016-04-12T00:40:01.638Z]: (1460421601638): Component "client:ui-builder-client" finished initialization
xdk:client:[2016-04-12T00:40:01.640Z]: (1460421601640): Component "client:dialog-box" finished initialization
xdk:client:[2016-04-12T00:40:01.640Z]: (1460421601640): Component "client:hot-keys" calling init()
xdk:client:[2016-04-12T00:40:01.640Z]: (1460421601640): Component "client:hot-keys" finished initialization
xdk:client:[2016-04-12T00:40:01.642Z]: (1460421601642): Component "client:settings-ui" finished initialization
xdk:client:[2016-04-12T00:40:01.644Z]: (1460421601644): Component "client:document-manager" calling init()
xdk:client:[2016-04-12T00:40:01.644Z]: (1460421601644): Component "client:document-manager" finished initialization
xdk:client:[2016-04-12T00:40:01.658Z]: (1460421601658): Component "client:aa-controller" calling init()
xdk:client:[2016-04-12T00:40:01.658Z]: (1460421601658): Component "client:aa-controller" finished initialization
xdk:client:[2016-04-12T00:40:01.711Z]: (1460421601711): Component "client:contenttype-registry" calling init()
xdk:client:[2016-04-12T00:40:01.712Z]: (1460421601712): Component "client:contenttype-registry" finished initialization
xdk:client:[2016-04-12T00:40:01.712Z]: (1460421601712): Component "client:editor-registry" finished initialization
xdk:client:[2016-04-12T00:40:01.722Z]: (1460421601722): Component "client:library-registry" calling init()
xdk:client:[2016-04-12T00:40:01.722Z]: (1460421601722): Component "client:library-registry" finished initialization
xdk:client:[2016-04-12T00:40:01.729Z]: (1460421601729): Component "client:device-discovery" calling init()
xdk:client:[2016-04-12T00:40:01.729Z]: (1460421601729): Component "client:device-discovery" waiting for delayed initialization
xdk:client:[2016-04-12T00:40:01.730Z]: (1460421601730): Component "client:hash-utils" finished initialization
xdk:client:[2016-04-12T00:40:01.784Z]: (1460421601784): Component "client:cordova" calling init()
xdk:client:[2016-04-12T00:40:01.784Z]: (1460421601784): Component "client:cordova" waiting for delayed initialization
xdk:client:[2016-04-12T00:40:01.805Z]: (1460421601805): Component "client:resource-manager" calling init()
xdk:client:[2016-04-12T00:40:01.805Z]: (1460421601805): Component "client:resource-manager" waiting for delayed initialization
xdk:client:[2016-04-12T00:40:01.816Z]: (1460421601816): Component "client:resource-cocos2djs" calling init()
xdk:client:[2016-04-12T00:40:01.816Z]: (1460421601816): Component "client:resource-cocos2djs" finished initialization
xdk:client:[2016-04-12T00:40:01.819Z]: (1460421601819): Component "client:resource-phaser" calling init()
xdk:client:[2016-04-12T00:40:01.819Z]: (1460421601819): Component "client:resource-phaser" finished initialization
xdk:client:[2016-04-12T00:40:01.821Z]: (1460421601821): Component "client:resource-pixi" calling init()
xdk:client:[2016-04-12T00:40:01.821Z]: (1460421601821): Component "client:resource-pixi" finished initialization
xdk:client:[2016-04-12T00:40:01.822Z]: (1460421601822): Component "client:resource-easeljs" calling init()
xdk:client:[2016-04-12T00:40:01.822Z]: (1460421601822): Component "client:resource-easeljs" finished initialization
xdk:client:[2016-04-12T00:40:01.823Z]: (1460421601824): Component "client:resource-plain" calling init()
xdk:client:[2016-04-12T00:40:01.824Z]: (1460421601824): Component "client:resource-plain" finished initialization
xdk:client:[2016-04-12T00:40:01.830Z]: (1460421601830): Component "client:cordova-registry" calling init()
xdk:client:[2016-04-12T00:40:01.831Z]: (1460421601831): Component "client:cordova-registry" waiting for delayed initialization
xdk:client:[2016-04-12T00:40:01.835Z]: (1460421601835): Component "client:appcenter-options" calling init()
xdk:client:[2016-04-12T00:40:01.836Z]: (1460421601836): Component "client:appcenter-options" waiting for delayed initialization
xdk:client:[2016-04-12T00:40:01.839Z]: (1460421601839): Component "client:services-tab" calling init()
xdk:client:[2016-04-12T00:40:01.840Z]: (1460421601840): Component "client:services-tab" finished initialization
xdk:client:[2016-04-12T00:40:01.841Z]: (1460421601841): Component "client:test-local-server" calling init()
xdk:client:[2016-04-12T00:40:01.869Z]: (1460421601869): Component "client:test-local-server" finished initialization
xdk:client:[2016-04-12T00:40:01.870Z]: (1460421601870): Component "client:tabs" finished initialization
xdk:client:[2016-04-12T00:40:01.875Z]: (1460421601875): Component "client:app" calling init()
xdk:client:[2016-04-12T00:40:01.886Z]: (1460421601886): Component "client:app" finished initialization
xdk:client:[2016-04-12T00:40:01.938Z]: (1460421601938): Component "client:cert-manager" finished initialization
xdk:client:[2016-04-12T00:40:01.945Z]: (1460421601945): Component "client:quick-tour" calling init()
xdk:client:[2016-04-12T00:40:01.945Z]: (1460421601945): Component "client:quick-tour" finished initialization
xdk:client:[2016-04-12T00:40:01.954Z]: (1460421601954): Component "client:project-manager" calling init()
xdk:client:[2016-04-12T00:40:01.955Z]: (1460421601955): Component "client:project-manager" waiting for delayed initialization
xdk:client:[2016-04-12T00:40:01.960Z]: (1460421601960): Component "client:projects-renderers" calling init()
xdk:client:[2016-04-12T00:40:01.960Z]: (1460421601960): Component "client:projects-renderers" waiting for delayed initialization
xdk:client:[2016-04-12T00:40:01.961Z]: (1460421601961): Component "client:projects-renderers-iotapp" calling init()
xdk:client:[2016-04-12T00:40:01.961Z]: (1460421601961): Component "client:projects-renderers-iotapp" finished initialization
xdk:client:[2016-04-12T00:40:01.976Z]: (1460421601976): Component "client:resource-cocos2d" calling init()
xdk:client:[2016-04-12T00:40:01.977Z]: (1460421601977): Component "client:resource-cocos2d" waiting for delayed initialization
xdk:client:[2016-04-12T00:40:01.984Z]: (1460421601984): Component "client:account-settings" calling init()
xdk:client:[2016-04-12T00:40:01.984Z]: (1460421601984): Component "client:account-settings" finished initialization
xdk:client:[2016-04-12T00:40:01.988Z]: (1460421601988): Component "client:platform-registry" calling init()
xdk:client:[2016-04-12T00:40:01.989Z]: (1460421601989): Component "client:platform-registry" finished initialization
xdk:client:[2016-04-12T00:40:01.990Z]: (1460421601990): Component "client:projecttype-registry" calling init()
xdk:client:[2016-04-12T00:40:01.991Z]: (1460421601991): Component "client:projecttype-registry" finished initialization
xdk:client:[2016-04-12T00:40:01.995Z]: (1460421601995): Component "client:device" calling init()
xdk:client:[2016-04-12T00:40:02.107Z]: (1460421602107): Component "client:device" finished initialization
xdk:client:[2016-04-12T00:40:02.109Z]: (1460421602109): Component "client:navbar" starting import
xdk:client:[2016-04-12T00:40:02.109Z]: (1460421602109): Component "client:tweets" starting import
xdk:client:[2016-04-12T00:40:02.109Z]: (1460421602109): Component "client:projects-tab" starting import
xdk:client:[2016-04-12T00:40:02.109Z]: (1460421602109): Component "client:test-tab" starting import
xdk:client:[2016-04-12T00:40:02.109Z]: (1460421602109): Component "client:profilingTab" starting import
xdk:client:[2016-04-12T00:40:02.109Z]: (1460421602109): Component "client:emulator" starting import
xdk:client:[2016-04-12T00:40:02.109Z]: (1460421602109): Component "client:remote-tab" starting import
xdk:client:[2016-04-12T00:40:02.109Z]: (1460421602109): Component "client:build-tab" starting import
xdk:client:[2016-04-12T00:40:02.109Z]: (1460421602109): Component "client:build-service" starting import
xdk:client:[2016-04-12T00:40:02.109Z]: (1460421602109): Component "client:bower-client" starting import
xdk:client:[2016-04-12T00:40:02.109Z]: (1460421602109): Component "client:editor-tab" starting import
xdk:client:[2016-04-12T00:40:02.109Z]: (1460421602109): Component "client:account" starting import
xdk:client:[2016-04-12T00:40:02.109Z]: (1460421602109): Component "client:project-selector" starting import
xdk:client:[2016-04-12T00:40:02.110Z]: (1460421602110): Component "client:publish-tab" starting import
xdk:client:[2016-04-12T00:40:02.115Z]: (1460421602115): Component "client:device-discovery" finished delayed initialization
xdk:client:[2016-04-12T00:40:02.115Z]: (1460421602115): Component "client:resource-cocos2d" finished delayed initialization
client:adb:[2016-04-12T00:40:02.124Z]: (1460421602124): Using existing adb at "C:\Users\CaioCoCora\AppData\Local\Intel\XDK\bin\adb\adb.exe"
xdk:client:[2016-04-12T00:40:02.146Z]: (1460421602146): Component "client:bower-package-manager" calling init()
xdk:client:[2016-04-12T00:40:02.146Z]: (1460421602146): Component "client:bower-package-manager" waiting for delayed initialization
xdk:client:[2016-04-12T00:40:02.148Z]: (1460421602148): memmrk:	25603280	45450496
xdk:client:[2016-04-12T00:40:02.159Z]: (1460421602159): Component "client:settings-db" finished delayed initialization
client:git-manager:[2016-04-12T00:40:02.178Z]: (1460421602178): Custom Git Client Path is C:\Users\CaioCoCora\AppData\Local\Intel\XDK\bin\git\bin\git.exe
client:git-manager:[2016-04-12T00:40:02.178Z]: (1460421602178): Auto-Proxy setting is true
xdk:client:[2016-04-12T00:40:02.180Z]: (1460421602180): Component "client:bower-package-manager" finished delayed initialization
xdk:client:[2016-04-12T00:40:02.196Z]: (1460421602196): Component "client:adb" finished delayed initialization
xdk:client:[2016-04-12T00:40:02.203Z]: (1460421602203): Component "client:editor" calling init()
xdk:client:[2016-04-12T00:40:02.203Z]: (1460421602203): Component "client:editor" finished initialization
xdk:client:[2016-04-12T00:40:02.203Z]: (1460421602203): Component "client:live-preview" calling init()
xdk:client:[2016-04-12T00:40:02.204Z]: (1460421602204): Component "client:live-preview" finished initialization
xdk:client:[2016-04-12T00:40:02.204Z]: (1460421602204): Component "client:editor-tab" getting UI region for "develop"
xdk:client:[2016-04-12T00:40:02.205Z]: (1460421602205): Component "client:editor-tab" calling init()
xdk:client:[2016-04-12T00:40:02.213Z]: (1460421602213): Component "client:editor-tab" waiting for delayed initialization
xdk:client:[2016-04-12T00:40:02.227Z]: (1460421602227): Component "client:projects-renderers-webapp" calling init()
xdk:client:[2016-04-12T00:40:02.228Z]: (1460421602228): Component "client:projects-renderers-webapp" finished initialization
xdk:client:[2016-04-12T00:40:02.232Z]: (1460421602232): Component "client:projects-renderers-jsapp" calling init()
xdk:client:[2016-04-12T00:40:02.232Z]: (1460421602232): Component "client:projects-renderers-jsapp" finished initialization
xdk:client:[2016-04-12T00:40:02.250Z]: (1460421602250): Component "client:build-service" getting UI region for "build"
xdk:client:[2016-04-12T00:40:02.250Z]: (1460421602250): Component "client:build-service" calling init()
xdk:client:[2016-04-12T00:40:02.251Z]: (1460421602251): Component "client:build-service" finished initialization
xdk:client:[2016-04-12T00:40:02.262Z]: (1460421602262): Component "client:projects-renderers" finished delayed initialization
xdk:client:[2016-04-12T00:40:02.265Z]: (1460421602265): Component "client:git-manager" finished delayed initialization
xdk:client:[2016-04-12T00:40:02.305Z]: (1460421602305): Component "client:account" getting UI region for "account"
xdk:client:[2016-04-12T00:40:02.305Z]: (1460421602305): Component "client:account" calling init()
xdk:client:[2016-04-12T00:40:02.309Z]: (1460421602309): Component "client:account" finished initialization
xdk:client:[2016-04-12T00:40:02.310Z]: (1460421602310): Component "client:project-selector" getting UI region for "project-selector"
xdk:client:[2016-04-12T00:40:02.310Z]: (1460421602310): Component "client:project-selector" calling init()
xdk:client:[2016-04-12T00:40:02.310Z]: (1460421602310): Component "client:project-selector" finished initialization
xdk:client:[2016-04-12T00:40:02.315Z]: (1460421602315): Component "client:tweets" finished initialization
xdk:client:[2016-04-12T00:40:02.316Z]: (1460421602316): Component "client:projects-tab" getting UI region for "project"
xdk:client:[2016-04-12T00:40:02.316Z]: (1460421602316): Component "client:projects-tab" calling init()
xdk:client:[2016-04-12T00:40:02.316Z]: (1460421602317): Component "client:projects-tab" waiting for delayed initialization
xdk:client:[2016-04-12T00:40:02.318Z]: (1460421602318): Component "client:test-tab" getting UI region for "test"
xdk:client:[2016-04-12T00:40:02.318Z]: (1460421602318): Component "client:test-tab" calling init()
xdk:client:[2016-04-12T00:40:02.318Z]: (1460421602318): Component "client:test-tab" waiting for delayed initialization
xdk:client:[2016-04-12T00:40:02.327Z]: (1460421602327): Component "client:emulator" getting UI region for "emulate"
xdk:client:[2016-04-12T00:40:02.327Z]: (1460421602327): Component "client:emulator" calling init()
xdk:client:[2016-04-12T00:40:02.329Z]: (1460421602329): Component "client:emulator" finished initialization
xdk:client:[2016-04-12T00:40:02.336Z]: (1460421602336): Component "client:remote-tab" getting UI region for "debug"
xdk:client:[2016-04-12T00:40:02.336Z]: (1460421602336): Component "client:remote-tab" calling init()
xdk:client:[2016-04-12T00:40:02.436Z]: (1460421602436): Component "client:remote-tab" waiting for delayed initialization
xdk:client:[2016-04-12T00:40:02.449Z]: (1460421602449): Component "client:remote-tab" finished delayed initialization
xdk:client:[2016-04-12T00:40:02.454Z]: (1460421602454): Component "client:cordova" finished delayed initialization
xdk:client:[2016-04-12T00:40:02.458Z]: (1460421602458): Component "client:navbar" getting UI region for "navbar-common"
xdk:client:[2016-04-12T00:40:02.458Z]: (1460421602458): Component "client:navbar" calling init()
client:navbar:[2016-04-12T00:40:02.458Z]: (1460421602458): navbar options: {"common":{"servicesVersion":"release-2016-ww11"},"updatePollingInterval":1800,"forceUpdate":false}
xdk:client:[2016-04-12T00:40:02.458Z]: (1460421602458): Component "client:navbar" finished initialization
xdk:client:[2016-04-12T00:40:02.505Z]: (1460421602505): Component "client:build-tab" getting UI region for "build"
xdk:client:[2016-04-12T00:40:02.505Z]: (1460421602505): Component "client:build-tab" calling init()
xdk:client:[2016-04-12T00:40:02.510Z]: (1460421602510): Component "client:build-tab" waiting for delayed initialization
xdk:client:[2016-04-12T00:40:02.515Z]: (1460421602515): Component "client:publish-tab" getting UI region for "publish"
xdk:client:[2016-04-12T00:40:02.515Z]: (1460421602515): Component "client:publish-tab" calling init()
xdk:client:[2016-04-12T00:40:02.521Z]: (1460421602521): Component "client:build-tab" finished delayed initialization
xdk:client:[2016-04-12T00:40:02.522Z]: (1460421602522): Component "client:publish-tab" finished initialization
xdk:client:[2016-04-12T00:40:02.556Z]: (1460421602556): Component "client:bower-client" getting UI region for "deps-manager"
xdk:client:[2016-04-12T00:40:02.557Z]: (1460421602557): Component "client:bower-client" calling init()
xdk:client:[2016-04-12T00:40:02.558Z]: (1460421602558): Component "client:bower-client" finished initialization
xdk:client:[2016-04-12T00:40:02.645Z]: (1460421602646): Component "client:profilingTab" getting UI region for "profile"
xdk:client:[2016-04-12T00:40:02.646Z]: (1460421602646): Component "client:profilingTab" calling init()
xdk:client:[2016-04-12T00:40:02.647Z]: (1460421602647): Component "client:profilingTab" finished initialization
xdk:server:[2016-04-12T00:40:03.309Z]: (1460421603309): memmrk:	28856280	43419136
client:appcenter-options:[2016-04-12T00:40:03.526Z]: (1460421603526): Fetch Status: 1, Message: Feched latest appcenter-options info because network is available.
xdk:client:[2016-04-12T00:40:03.527Z]: (1460421603527): Component "client:appcenter-options" finished delayed initialization
xdk:client:[2016-04-12T00:40:03.533Z]: (1460421603533): Component "client:test-tab" finished delayed initialization
xdk:client:[2016-04-12T00:40:03.566Z]: (1460421603566): Component "client:cordova-registry" finished delayed initialization
xdk:client:[2016-04-12T00:40:05.829Z]: (1460421605829): Component "client:persistance" finished delayed initialization
xdk:client:[2016-04-12T00:40:07.241Z]: (1460421607241): memmrk:	41183532	62774656
xdk:server:[2016-04-12T00:40:08.311Z]: (1460421608311): memmrk:	49636604	65751936
xdk:client:[2016-04-12T00:40:13.237Z]: (1460421613237): memmrk:	37671552	69884416
xdk:server:[2016-04-12T00:40:13.313Z]: (1460421613313): memmrk:	46862500	95206656
xdk:client:[2016-04-12T00:40:18.235Z]: (1460421618235): memmrk:	36347324	69884416
xdk:server:[2016-04-12T00:40:18.317Z]: (1460421618317): memmrk:	48599204	95206656
xdk:client:[2016-04-12T00:40:23.236Z]: (1460421623236): memmrk:	25593564	69884416
xdk:server:[2016-04-12T00:40:23.317Z]: (1460421623317): memmrk:	33436468	103332096
xdk:client:[2016-04-12T00:40:24.790Z]: (1460421624790): Component "client:project-manager" finished delayed initialization
client:cordova:[2016-04-12T00:40:24.849Z]: (1460421624849): { xdkProjectStatus: 'all_same',
  pluginStatus: { 'cordova-plugin-device': 'same' } }
xdk:client:[2016-04-12T00:40:24.858Z]: (1460421624858): Component "client:project-list-load" finished delayed initialization
xdk:client:[2016-04-12T00:40:24.870Z]: (1460421624870): Component "client:resource-manager" finished delayed initialization
xdk:client:[2016-04-12T00:40:24.870Z]: (1460421624870): Component "client:projects-tab" finished delayed initialization
xdk:client:[2016-04-12T00:40:24.871Z]: (1460421624871): Component "client:projects-list" starting import
xdk:client:[2016-04-12T00:40:24.871Z]: (1460421624871): Component "client:projects-info" starting import
xdk:client:[2016-04-12T00:40:24.871Z]: (1460421624871): Component "client:projects-create-list" starting import
xdk:client:[2016-04-12T00:40:24.871Z]: (1460421624871): Component "client:projects-create-info" starting import
xdk:client:[2016-04-12T00:40:25.252Z]: (1460421625252): Component "client:projects-list" getting UI region for "existing-list"
xdk:client:[2016-04-12T00:40:25.252Z]: (1460421625252): Component "client:projects-list" calling init()
xdk:client:[2016-04-12T00:40:25.254Z]: (1460421625254): Component "client:projects-list" finished initialization
xdk:client:[2016-04-12T00:40:25.256Z]: (1460421625256): Component "client:projects-info" getting UI region for "existing-info"
xdk:client:[2016-04-12T00:40:25.256Z]: (1460421625256): Component "client:projects-info" calling init()
xdk:client:[2016-04-12T00:40:25.256Z]: (1460421625256): Component "client:projects-info" finished initialization
xdk:client:[2016-04-12T00:40:25.263Z]: (1460421625263): Component "client:projects-create-info" getting UI region for "create-info"
xdk:client:[2016-04-12T00:40:25.263Z]: (1460421625263): Component "client:projects-create-info" calling init()
xdk:client:[2016-04-12T00:40:25.263Z]: (1460421625263): Component "client:projects-create-info" finished initialization
xdk:client:[2016-04-12T00:40:25.269Z]: (1460421625269): Component "client:projects-create-list" getting UI region for "create-list"
xdk:client:[2016-04-12T00:40:25.269Z]: (1460421625269): Component "client:projects-create-list" calling init()
xdk:client:[2016-04-12T00:40:25.270Z]: (1460421625270): Component "client:projects-create-list" finished initialization
xdk:client:[2016-04-12T00:40:28.236Z]: (1460421628236): memmrk:	37738952	76982016
xdk:server:[2016-04-12T00:40:28.317Z]: (1460421628317): memmrk:	41610320	103332096
xdk:client:[2016-04-12T00:40:31.420Z]: (1460421631420): onExitRequest listener 1:
    at Object.exports.onExitRequest (C:\Users\CaioCoCora\AppData\Local\Intel\XDK\xdk\core-modules\public\exit-notifier.js:17:2170)
    at Object.<anonymous> (file:///C:/Users/CaioCoCora/AppData/Local/Intel/XDK/xdk/brackets/b/extensions/default/XDK/main.js:459:21)
    at Object.context.execCb (file:///C:/Users/CaioCoCora/AppData/Local/Intel/XDK/xdk/brackets/b/thirdparty/requirejs/require.js:1658:33)
    at Object.Module.check (file:///C:/Users/CaioCoCora/AppData/Local/Intel/XDK/xdk/brackets/b/thirdparty/requirejs/require.js:869:55)
    at Object.<anonymous> (file:///C:/Users/CaioCoCora/AppData/Local/Intel/XDK/xdk/brackets/b/thirdparty/requirejs/require.js:1121:34)
    at file:///C:/Users/CaioCoCora/AppData/Local/Intel/XDK/xdk/brackets/b/thirdparty/requirejs/require.js:132:23
    at file:///C:/Users/CaioCoCora/AppData/Local/Intel/XDK/xdk/brackets/b/thirdparty/requirejs/require.js:1164:21
    at each (file:///C:/Users/CaioCoCora/AppData/Local/Intel/XDK/xdk/brackets/b/thirdparty/requirejs/require.js:57:31)
    at Object.Module.emit (file:///C:/Users/CaioCoCora/AppData/Local/Intel/XDK/xdk/brackets/b/thirdparty/requirejs/require.js:1163:17)
xdk:client:[2016-04-12T00:40:33.237Z]: (1460421633237): memmrk:	49959636	77985536
xdk:server:[2016-04-12T00:40:33.318Z]: (1460421633318): memmrk:	41783180	103332096
client:services-tab:[2016-04-12T00:40:34.393Z]: (1460421634393): component:services-tab : Container provided by brackets :
client:services-tab:[2016-04-12T00:40:34.393Z]: (1460421634393): component:services-tab : mainContainer_ = XDKMiniServices-main
client:services-tab:[2016-04-12T00:40:34.393Z]: (1460421634393): component:services-tab : sidebarContainer = XDKMiniServices-list
client:services-tab:[2016-04-12T00:40:34.393Z]: (1460421634393): component:services-tab : Iframes inserted by services-tab : .
client:services-tab:[2016-04-12T00:40:34.393Z]: (1460421634393): component:services-tab : $mainContainer_ = mini-api-explorer
client:services-tab:[2016-04-12T00:40:34.393Z]: (1460421634393): component:services-tab : $sidebarContainer_ = api-sidebar
xdk:client:[2016-04-12T00:40:34.841Z]: (1460421634842): Component "client:editor-tab" finished delayed initialization
xdk:client:[2016-04-12T00:40:34.843Z]: (1460421634843): Component "client:app" calling start()
xdk:client:[2016-04-12T00:40:34.860Z]: (1460421634860): Component "client:app" finished start()
xdk:client:[2016-04-12T00:40:34.860Z]: (1460421634860): Component "client:navbar" calling start()
xdk:client:[2016-04-12T00:40:34.878Z]: (1460421634878): Component "client:navbar" finished start()
xdk:client:[2016-04-12T00:40:34.878Z]: (1460421634878): Component "client:project-manager" calling start()
xdk:client:[2016-04-12T00:40:34.878Z]: (1460421634878): Component "client:project-manager" finished start()
xdk:client:[2016-04-12T00:40:34.878Z]: (1460421634878): Component "client:aa-controller" calling start()
xdk:client:[2016-04-12T00:40:34.879Z]: (1460421634879): Component "client:aa-controller" finished start()
xdk:client:[2016-04-12T00:40:34.879Z]: (1460421634879): Component "client:projects-tab" calling start()
xdk:client:[2016-04-12T00:40:34.887Z]: (1460421634887): Component "client:projects-tab" finished start()
xdk:client:[2016-04-12T00:40:34.887Z]: (1460421634887): Component "client:projects-list" calling start()
xdk:client:[2016-04-12T00:40:34.890Z]: (1460421634890): Component "client:projects-list" finished start()
xdk:client:[2016-04-12T00:40:34.890Z]: (1460421634890): Component "client:projects-info" calling start()
xdk:client:[2016-04-12T00:40:34.963Z]: (1460421634963): Component "client:projects-info" finished start()
xdk:client:[2016-04-12T00:40:34.963Z]: (1460421634963): Component "client:projects-create-list" calling start()
xdk:client:[2016-04-12T00:40:35.005Z]: (1460421635005): Component "client:projects-create-list" finished start()
xdk:client:[2016-04-12T00:40:35.005Z]: (1460421635005): Component "client:projects-create-info" calling start()
xdk:client:[2016-04-12T00:40:35.011Z]: (1460421635011): Component "client:projects-create-info" finished start()
xdk:client:[2016-04-12T00:40:35.011Z]: (1460421635011): Component "client:test-tab" calling start()
xdk:client:[2016-04-12T00:40:35.017Z]: (1460421635017): Component "client:test-tab" finished start()
xdk:client:[2016-04-12T00:40:35.017Z]: (1460421635017): Component "client:profilingTab" calling start()
xdk:client:[2016-04-12T00:40:35.072Z]: (1460421635072): Component "client:profilingTab" finished start()
xdk:client:[2016-04-12T00:40:35.072Z]: (1460421635072): Component "client:emulator" calling start()
xdk:client:[2016-04-12T00:40:35.073Z]: (1460421635073): Component "client:emulator" finished start()
xdk:client:[2016-04-12T00:40:35.073Z]: (1460421635073): Component "client:remote-tab" calling start()
xdk:client:[2016-04-12T00:40:35.078Z]: (1460421635078): onExitRequest listener 2:
    at Object.myExports.start (file:///C:/Users/CaioCoCora/AppData/Local/Intel/XDK/xdk/components/client/remote-tab/remote-tab.js:20:3484)
    at resumeClientInit (C:\Users\CaioCoCora\AppData\Local\Intel\XDK\xdk\core-modules\private\main.js:17:12040)
    at C:\Users\CaioCoCora\AppData\Local\Intel\XDK\xdk\core-modules\private\main.js:17:1734
xdk:client:[2016-04-12T00:40:35.079Z]: (1460421635079): Component "client:remote-tab" finished start()
xdk:client:[2016-04-12T00:40:35.079Z]: (1460421635079): Component "client:build-tab" calling start()
xdk:client:[2016-04-12T00:40:35.081Z]: (1460421635081): Component "client:build-tab" finished start()
xdk:client:[2016-04-12T00:40:35.081Z]: (1460421635081): Component "client:active-sync" calling start()
xdk:client:[2016-04-12T00:40:35.081Z]: (1460421635082): Component "client:active-sync" finished start()
xdk:client:[2016-04-12T00:40:35.082Z]: (1460421635082): Component "client:apk-installer" calling start()
xdk:client:[2016-04-12T00:40:35.082Z]: (1460421635082): Component "client:apk-installer" finished start()
xdk:client:[2016-04-12T00:40:35.082Z]: (1460421635082): Component "client:resource-manager" calling start()
xdk:client:[2016-04-12T00:40:35.084Z]: (1460421635084): Component "client:resource-manager" finished start()
xdk:client:[2016-04-12T00:40:35.084Z]: (1460421635084): Component "client:resource-cocos2d" calling start()
xdk:client:[2016-04-12T00:40:35.084Z]: (1460421635084): Component "client:resource-cocos2d" finished start()
xdk:client:[2016-04-12T00:40:35.084Z]: (1460421635084): Component "client:resource-cocos2djs" calling start()
xdk:client:[2016-04-12T00:40:35.084Z]: (1460421635084): Component "client:resource-cocos2djs" finished start()
xdk:client:[2016-04-12T00:40:35.084Z]: (1460421635084): Component "client:resource-phaser" calling start()
xdk:client:[2016-04-12T00:40:35.084Z]: (1460421635084): Component "client:resource-phaser" finished start()
xdk:client:[2016-04-12T00:40:35.084Z]: (1460421635084): Component "client:resource-pixi" calling start()
xdk:client:[2016-04-12T00:40:35.085Z]: (1460421635085): Component "client:resource-pixi" finished start()
xdk:client:[2016-04-12T00:40:35.085Z]: (1460421635085): Component "client:resource-easeljs" calling start()
xdk:client:[2016-04-12T00:40:35.085Z]: (1460421635085): Component "client:resource-easeljs" finished start()
xdk:client:[2016-04-12T00:40:35.085Z]: (1460421635085): Component "client:resource-plain" calling start()
xdk:client:[2016-04-12T00:40:35.085Z]: (1460421635085): Component "client:resource-plain" finished start()
xdk:client:[2016-04-12T00:40:35.085Z]: (1460421635085): Component "client:resource-render-frame" calling start()
xdk:client:[2016-04-12T00:40:35.085Z]: (1460421635085): Component "client:resource-render-frame" finished start()
xdk:client:[2016-04-12T00:40:35.085Z]: (1460421635085): Component "client:resource-util" calling start()
xdk:client:[2016-04-12T00:40:35.085Z]: (1460421635085): Component "client:resource-util" finished start()
xdk:client:[2016-04-12T00:40:35.085Z]: (1460421635085): Component "client:bower-client" calling start()
xdk:client:[2016-04-12T00:40:35.086Z]: (1460421635086): Component "client:bower-client" finished start()
xdk:client:[2016-04-12T00:40:35.086Z]: (1460421635086): Component "client:editor" calling start()
xdk:client:[2016-04-12T00:40:35.086Z]: (1460421635086): Component "client:editor" finished start()
xdk:client:[2016-04-12T00:40:35.086Z]: (1460421635086): Component "client:editor-tab" calling start()
xdk:client:[2016-04-12T00:40:35.108Z]: (1460421635108): Component "client:editor-tab" finished start()
xdk:client:[2016-04-12T00:40:35.108Z]: (1460421635108): Component "client:live-preview" calling start()
xdk:client:[2016-04-12T00:40:35.108Z]: (1460421635108): Component "client:live-preview" finished start()
xdk:client:[2016-04-12T00:40:35.108Z]: (1460421635108): Component "client:account" calling start()
xdk:client:[2016-04-12T00:40:35.110Z]: (1460421635110): Component "client:account" finished start()
xdk:client:[2016-04-12T00:40:35.110Z]: (1460421635110): Component "client:project-selector" calling start()
xdk:client:[2016-04-12T00:40:35.112Z]: (1460421635112): Component "client:project-selector" finished start()
xdk:client:[2016-04-12T00:40:35.112Z]: (1460421635112): Component "client:ui-builder-client" calling start()
xdk:client:[2016-04-12T00:40:35.113Z]: (1460421635113): Component "client:ui-builder-client" finished start()
xdk:client:[2016-04-12T00:40:35.113Z]: (1460421635113): Component "client:project-meta" calling start()
xdk:client:[2016-04-12T00:40:35.113Z]: (1460421635113): Component "client:project-meta" finished start()
xdk:client:[2016-04-12T00:40:35.113Z]: (1460421635113): Component "client:cordova-registry" calling start()
xdk:client:[2016-04-12T00:40:35.113Z]: (1460421635113): Component "client:cordova-registry" finished start()
xdk:client:[2016-04-12T00:40:35.113Z]: (1460421635113): Component "client:adb" calling start()
xdk:client:[2016-04-12T00:40:35.113Z]: (1460421635113): Component "client:adb" finished start()
xdk:client:[2016-04-12T00:40:35.113Z]: (1460421635113): Component "client:iosdb" calling start()
xdk:client:[2016-04-12T00:40:35.116Z]: (1460421635116): Component "client:iosdb" finished start()
xdk:client:[2016-04-12T00:40:35.116Z]: (1460421635116): Component "client:device-discovery" calling start()
xdk:client:[2016-04-12T00:40:35.119Z]: (1460421635119): onExitRequest listener 3:
    at Object.start (file:///C:/Users/CaioCoCora/AppData/Local/Intel/XDK/xdk/components/client/device-discovery/device-discovery.js:17:9195)
xdk:client:[2016-04-12T00:40:35.119Z]: (1460421635119): Component "client:device-discovery" finished start()
xdk:client:[2016-04-12T00:40:35.119Z]: (1460421635119): Component "client:test-local-server" calling start()
xdk:client:[2016-04-12T00:40:35.119Z]: (1460421635119): Component "client:test-local-server" finished start()
xdk:client:[2016-04-12T00:40:35.119Z]: (1460421635119): Component "client:quick-tour" calling start()
xdk:client:[2016-04-12T00:40:35.119Z]: (1460421635119): Component "client:quick-tour" finished start()
xdk:client:[2016-04-12T00:40:35.119Z]: (1460421635119): Component "client:hot-keys" calling start()
xdk:client:[2016-04-12T00:40:35.121Z]: (1460421635121): Component "client:hot-keys" finished start()
xdk:client:[2016-04-12T00:40:35.121Z]: (1460421635121): Component "client:persistance" calling start()
xdk:client:[2016-04-12T00:40:35.123Z]: (1460421635123): onExit listener 4:
    at Object.start (file:///C:/Users/CaioCoCora/AppData/Local/Intel/XDK/xdk/components/client/persistance/persistance.js:17:4613)
xdk:client:[2016-04-12T00:40:35.123Z]: (1460421635123): Component "client:persistance" finished start()
xdk:client:[2016-04-12T00:40:35.123Z]: (1460421635123): Component "client:file-watcher" calling start()
xdk:client:[2016-04-12T00:40:35.123Z]: (1460421635123): Component "client:file-watcher" finished start()
xdk:client:[2016-04-12T00:40:35.123Z]: (1460421635123): Component "client:cordova" calling start()
xdk:client:[2016-04-12T00:40:35.124Z]: (1460421635124): Component "client:cordova" finished start()
xdk:client:[2016-04-12T00:40:35.124Z]: (1460421635124): Component "client:external-editors-runner" calling start()
xdk:client:[2016-04-12T00:40:35.125Z]: (1460421635125): Component "client:external-editors-runner" finished start()
xdk:client:[2016-04-12T00:40:35.126Z]: (1460421635126): Component "client:upload-manager" calling start()
xdk:client:[2016-04-12T00:40:35.126Z]: (1460421635126): Component "client:upload-manager" finished start()
xdk:client:[2016-04-12T00:40:35.126Z]: (1460421635126): Component "client:publish-tab" calling start()
xdk:client:[2016-04-12T00:40:35.129Z]: (1460421635129): onExitRequest listener 5:
    at AutofillController.registerForEvents_ (file:///C:/Users/CaioCoCora/AppData/Local/Intel/XDK/xdk/components/client/publish-tab/autofill-form-controller.js:17:1607)
    at new AutofillController (file:///C:/Users/CaioCoCora/AppData/Local/Intel/XDK/xdk/components/client/publish-tab/autofill-form-controller.js:17:470)
    at Object.myExports.start (file:///C:/Users/CaioCoCora/AppData/Local/Intel/XDK/xdk/components/client/publish-tab/publish-tab.js:17:4918)
xdk:client:[2016-04-12T00:40:35.173Z]: (1460421635173): Component "client:publish-tab" finished start()
xdk:client:[2016-04-12T00:40:35.177Z]: (1460421635177): Intel XDK is initialized now
bower-package-manager:[2016-04-12T00:40:35.204Z]: (1460421635204): Bower packages not found { [Error: An error ocurred while trying to check for the file "F:/Marek//Intaglio/bower.json".]
  code: 22,
  message: 'An error ocurred while trying to check for the file "F:/Marek//Intaglio/bower.json".',
  originalMessage: 'NotFound',
  originalError: null }
client:build-tab:[2016-04-12T00:40:35.347Z]: (1460421635347): [refreshPage] Unable to generate project hash. { message_: 'Cannot generate app id without user identifiers',
  code_: null,
  componentName_: null,
  stack_: 'Error\n    at Object.createXdkAppId (C:\\Users\\CaioCoCora\\AppData\\Local\\Intel\\XDK\\xdk\\core-modules\\private\\service\\http-wrappers.js:17:543)\n    at Object.exports.generateProjectHash (file:///C:/Users/CaioCoCora/AppData/Local/Intel/XDK/xdk/components/client/backend-service-utils/backend-service-utils.js:17:1574)\n    at _refreshPage (file:///C:/Users/CaioCoCora/AppData/Local/Intel/XDK/xdk/components/client/build-tab/build-tab.js:17:6994)\n    at Object.start (file:///C:/Users/CaioCoCora/AppData/Local/Intel/XDK/xdk/components/client/build-tab/build-tab.js:17:3869)\n    at resumeClientInit (C:\\Users\\CaioCoCora\\AppData\\Local\\Intel\\XDK\\xdk\\core-modules\\private\\main.js:17:12040)\n    at C:\\Users\\CaioCoCora\\AppData\\Local\\Intel\\XDK\\xdk\\core-modules\\private\\main.js:17:1734\n    at _fulfilled (C:\\Users\\CaioCoCora\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\q\\q.js:834:54)\n    at self.promiseDispatch.done (C:\\Users\\CaioCoCora\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\q\\q.js:863:30)\n    at Promise.promise.promiseDispatch (C:\\Users\\CaioCoCora\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\q\\q.js:796:13)\n    at C:\\Users\\CaioCoCora\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\q\\q.js:604:44',
  httpCode_: 400 }
client:build-tab:[2016-04-12T00:40:35.349Z]: (1460421635349): [updatePageStatus] Set Status: PAGE_STATUS_ERROR
xdk:client:[2016-04-12T00:40:35.369Z]: (1460421635369): onExitRequest listener 6:
    at file:///C:/Users/CaioCoCora/AppData/Local/Intel/XDK/xdk/components/client/project-manager/project-manager.js:18:10467
    at _fulfilled (file:///C:/Users/CaioCoCora/AppData/Local/Intel/XDK/xdk/node_modules/q/q.js:834:54)
    at self.promiseDispatch.done (file:///C:/Users/CaioCoCora/AppData/Local/Intel/XDK/xdk/node_modules/q/q.js:863:30)
    at Promise.promise.promiseDispatch (file:///C:/Users/CaioCoCora/AppData/Local/Intel/XDK/xdk/node_modules/q/q.js:796:13)
    at file:///C:/Users/CaioCoCora/AppData/Local/Intel/XDK/xdk/node_modules/q/q.js:604:44
    at runSingle (file:///C:/Users/CaioCoCora/AppData/Local/Intel/XDK/xdk/node_modules/q/q.js:137:13)
    at flush (file:///C:/Users/CaioCoCora/AppData/Local/Intel/XDK/xdk/node_modules/q/q.js:125:13)
    at process._tickCallback (node.js:393:11)
client:navbar:[2016-04-12T00:40:36.047Z]: (1460421636047): pollForUpdates called
client:build-tab:[2016-04-12T00:40:36.061Z]: (1460421636061): [refreshPage] projectId hr_Cv_QzkxynqyPpemrEbFFA_yksIxJucWawc5j4xYM
client:build-tab:[2016-04-12T00:40:36.061Z]: (1460421636061): [updatePageState] Set State: PAGE_STATE_LOADING
client:build-tab:[2016-04-12T00:40:36.065Z]: (1460421636065): [getBuildTargets] Getting available targets for project hr_Cv_QzkxynqyPpemrEbFFA_yksIxJucWawc5j4xYM
client:build-tab:[2016-04-12T00:40:36.067Z]: (1460421636067): [refreshProjectInfo] Getting project info.
client:build-tab:[2016-04-12T00:40:36.068Z]: (1460421636068): [refreshBuildAssetsDate] Getting latest upload date for project files
client:publish-tab:[2016-04-12T00:40:36.617Z]: (1460421636617): Stores data feed has been successfully loaded.
client:build-tab:[2016-04-12T00:40:36.623Z]: (1460421636623): [getBuildTargets] Targets retrieved for project hr_Cv_QzkxynqyPpemrEbFFA_yksIxJucWawc5j4xYM
client:build-tab:[2016-04-12T00:40:36.668Z]: (1460421636668): [updatePageStatus] Set Status: PAGE_STATUS_READY
client:build-tab:[2016-04-12T00:40:36.668Z]: (1460421636668): [updatePageState] Set State: PAGE_STATE_IDLE
client:build-tab:[2016-04-12T00:40:36.676Z]: (1460421636676): [startUpdateStatusProcess] Starting build pulling process. Project: hr_Cv_QzkxynqyPpemrEbFFA_yksIxJucWawc5j4xYM
client:build-tab:[2016-04-12T00:40:36.676Z]: (1460421636676): [updatePageState] Set State: PAGE_STATE_UPDATING
client:build-service:[2016-04-12T00:40:36.677Z]: (1460421636677): [startUpdateStatusProcess] Starting polling. Project: hr_Cv_QzkxynqyPpemrEbFFA_yksIxJucWawc5j4xYM
client:navbar:[2016-04-12T00:40:37.798Z]: (1460421637798): polling up-to-date
xdk:client:[2016-04-12T00:40:38.236Z]: (1460421638237): memmrk:	66805412	88105856
xdk:server:[2016-04-12T00:40:38.318Z]: (1460421638318): memmrk:	24566476	103332096
client:build-service:[2016-04-12T00:40:40.116Z]: (1460421640116): [startUpdateStatusProcess] Polling process has finished.
client:build-tab:[2016-04-12T00:40:40.117Z]: (1460421640117): [updatePageState] Set State: PAGE_BUILDING
client:build-tab:[2016-04-12T00:40:40.121Z]: (1460421640121): [updatePageStatus] Set Status: PAGE_STATUS_READY
client:build-tab:[2016-04-12T00:40:40.122Z]: (1460421640122): [updatePageState] Set State: PAGE_STATE_IDLE
client:build-tab:[2016-04-12T00:40:40.404Z]: (1460421640404): [refreshBuildAssetsDate] latest upload date null
client:services-tab:[2016-04-12T00:40:42.501Z]: (1460421642501): Iframe onLoad resolved for : http://127.0.0.1:58889/http-services/api-explorer/iodocs/index?
client:services-tab:[2016-04-12T00:40:42.525Z]: (1460421642525): Iframe onLoad resolved for : http://127.0.0.1:58889/http-services/api-explorer/iodocs/sidebar?
client:services-tab:[2016-04-12T00:40:42.526Z]: (1460421642526): Both iframes loaded promise resolved.
client:services-tab:[2016-04-12T00:40:42.543Z]: (1460421642543): Calling postmessage for user refresh.
client:services-tab:[2016-04-12T00:40:42.543Z]: (1460421642543): main container window : true
client:services-tab:[2016-04-12T00:40:42.543Z]: (1460421642543): main container document : true
client:services-tab:[2016-04-12T00:40:42.543Z]: (1460421642543): component:services-tab:postMessageToWindow target = user
xdk:client:[2016-04-12T00:40:43.237Z]: (1460421643237): memmrk:	63176432	95666560
xdk:server:[2016-04-12T00:40:43.319Z]: (1460421643319): memmrk:	54090380	111028736
xdk:client:[2016-04-12T00:40:48.237Z]: (1460421648237): memmrk:	63298292	95666560
xdk:server:[2016-04-12T00:40:48.319Z]: (1460421648319): memmrk:	54098100	111028736
xdk:client:[2016-04-12T00:40:53.237Z]: (1460421653237): memmrk:	63469148	95666560
xdk:server:[2016-04-12T00:40:53.319Z]: (1460421653319): memmrk:	54711496	111028736
xdk:client:[2016-04-12T00:40:58.239Z]: (1460421658239): memmrk:	63585300	95666560
xdk:server:[2016-04-12T00:40:58.321Z]: (1460421658321): memmrk:	27426372	103307776
xdk:client:[2016-04-12T00:41:03.239Z]: (1460421663239): memmrk:	63760052	95666560
xdk:server:[2016-04-12T00:41:03.321Z]: (1460421663321): memmrk:	27445696	103307776
xdk:client:[2016-04-12T00:41:08.240Z]: (1460421668240): memmrk:	64855100	95666560
xdk:server:[2016-04-12T00:41:08.321Z]: (1460421668321): memmrk:	24123484	63251456
xdk:client:[2016-04-12T00:41:13.241Z]: (1460421673241): memmrk:	65781380	95666560
xdk:server:[2016-04-12T00:41:13.321Z]: (1460421673321): memmrk:	24131252	63251456
xdk:client:[2016-04-12T00:41:18.242Z]: (1460421678242): memmrk:	66015180	95666560
xdk:server:[2016-04-12T00:41:18.321Z]: (1460421678321): memmrk:	24139240	63251456
xdk:client:[2016-04-12T00:41:23.242Z]: (1460421683242): memmrk:	66197516	95666560
xdk:server:[2016-04-12T00:41:23.321Z]: (1460421683321): memmrk:	23585764	47000576
xdk:client:[2016-04-12T00:41:28.243Z]: (1460421688243): memmrk:	66550348	95666560
xdk:server:[2016-04-12T00:41:28.322Z]: (1460421688322): memmrk:	23754592	47000576
client:remote-tab:[2016-04-12T00:41:33.208Z]: (1460421693208): About to start needsDebugModule in addTabWatcher
xdk:client:[2016-04-12T00:41:33.294Z]: (1460421693294): memmrk:	63736340	95666560
xdk:server:[2016-04-12T00:41:33.322Z]: (1460421693322): memmrk:	22922164	34824576
xdk:client:[2016-04-12T00:41:38.294Z]: (1460421698294): memmrk:	63994220	95666560
xdk:server:[2016-04-12T00:41:38.322Z]: (1460421698322): memmrk:	22482012	32838272
xdk:client:[2016-04-12T00:41:43.294Z]: (1460421703294): memmrk:	64962248	95666560
xdk:server:[2016-04-12T00:41:43.322Z]: (1460421703322): memmrk:	21843896	32838272
xdk:client:[2016-04-12T00:41:48.294Z]: (1460421708294): memmrk:	68519776	96682240
xdk:server:[2016-04-12T00:41:48.322Z]: (1460421708322): memmrk:	21851028	32838272
xdk:client:[2016-04-12T00:41:53.295Z]: (1460421713295): memmrk:	71423132	96682240
xdk:server:[2016-04-12T00:41:53.322Z]: (1460421713322): memmrk:	21858076	32838272
xdk:client:[2016-04-12T00:41:58.295Z]: (1460421718295): memmrk:	71731264	96682240
xdk:server:[2016-04-12T00:41:58.322Z]: (1460421718322): memmrk:	21865124	32838272
xdk:client:[2016-04-12T00:42:03.296Z]: (1460421723296): memmrk:	72179896	96682240
xdk:server:[2016-04-12T00:42:03.322Z]: (1460421723322): memmrk:	21872172	32838272
xdk:client:[2016-04-12T00:42:08.297Z]: (1460421728297): memmrk:	72376212	96682240
xdk:server:[2016-04-12T00:42:08.322Z]: (1460421728322): memmrk:	21879236	32838272
xdk:client:[2016-04-12T00:42:13.297Z]: (1460421733297): memmrk:	72545592	96682240
xdk:server:[2016-04-12T00:42:13.322Z]: (1460421733322): memmrk:	21886284	32838272
xdk:client:[2016-04-12T00:42:18.298Z]: (1460421738298): memmrk:	72704688	96682240
xdk:server:[2016-04-12T00:42:18.322Z]: (1460421738322): memmrk:	21893332	32838272
xdk:client:[2016-04-12T00:42:23.298Z]: (1460421743298): memmrk:	72877772	96682240
xdk:server:[2016-04-12T00:42:23.322Z]: (1460421743322): memmrk:	21900380	32838272
xdk:client:[2016-04-12T00:42:28.299Z]: (1460421748299): memmrk:	55834728	94187776
xdk:server:[2016-04-12T00:42:28.322Z]: (1460421748322): memmrk:	21906508	32838272
xdk:client:[2016-04-12T00:42:33.300Z]: (1460421753300): memmrk:	56116320	94187776
xdk:server:[2016-04-12T00:42:33.322Z]: (1460421753322): memmrk:	21913556	32838272
xdk:client:[2016-04-12T00:42:38.300Z]: (1460421758300): memmrk:	56236800	94187776
xdk:server:[2016-04-12T00:42:38.322Z]: (1460421758322): memmrk:	21920604	32838272
xdk:client:[2016-04-12T00:42:43.301Z]: (1460421763301): memmrk:	56478564	94187776
xdk:server:[2016-04-12T00:42:43.323Z]: (1460421763323): memmrk:	21927652	32838272
xdk:client:[2016-04-12T00:42:48.301Z]: (1460421768301): memmrk:	56604024	94187776
xdk:server:[2016-04-12T00:42:48.324Z]: (1460421768324): memmrk:	21947888	32838272
xdk:client:[2016-04-12T00:42:53.301Z]: (1460421773301): memmrk:	56768596	94187776
xdk:server:[2016-04-12T00:42:53.323Z]: (1460421773323): memmrk:	21957064	32838272
xdk:client:[2016-04-12T00:42:58.301Z]: (1460421778301): memmrk:	50652664	71410176
xdk:server:[2016-04-12T00:42:58.324Z]: (1460421778324): memmrk:	21964080	32838272
xdk:client:[2016-04-12T00:43:03.301Z]: (1460421783302): memmrk:	50860776	71410176
xdk:server:[2016-04-12T00:43:03.324Z]: (1460421783324): memmrk:	21973344	32838272
xdk:client:[2016-04-12T00:43:08.302Z]: (1460421788302): memmrk:	50987456	71410176
xdk:server:[2016-04-12T00:43:08.324Z]: (1460421788324): memmrk:	21981620	32838272
xdk:client:[2016-04-12T00:43:13.303Z]: (1460421793303): memmrk:	48839220	67383936
xdk:server:[2016-04-12T00:43:13.324Z]: (1460421793324): memmrk:	21988652	32838272
xdk:client:[2016-04-12T00:43:18.304Z]: (1460421798304): memmrk:	48951684	67383936
xdk:server:[2016-04-12T00:43:18.325Z]: (1460421798325): memmrk:	21995668	32838272
xdk:client:[2016-04-12T00:43:23.305Z]: (1460421803305): memmrk:	49157056	67383936
xdk:server:[2016-04-12T00:43:23.325Z]: (1460421803325): memmrk:	22002700	32838272
xdk:client:[2016-04-12T00:43:28.305Z]: (1460421808305): memmrk:	49280844	67383936
xdk:server:[2016-04-12T00:43:28.325Z]: (1460421808325): memmrk:	22021608	32838272
xdk:client:[2016-04-12T00:43:33.305Z]: (1460421813305): memmrk:	47744608	67383936
xdk:server:[2016-04-12T00:43:33.326Z]: (1460421813326): memmrk:	22028608	32838272
xdk:client:[2016-04-12T00:43:38.306Z]: (1460421818306): memmrk:	47857072	67383936
xdk:server:[2016-04-12T00:43:38.325Z]: (1460421818325): memmrk:	22035624	32838272
xdk:client:[2016-04-12T00:43:43.307Z]: (1460421823307): memmrk:	48063800	67383936
xdk:server:[2016-04-12T00:43:43.326Z]: (1460421823326): memmrk:	22042624	32838272
xdk:client:[2016-04-12T00:43:48.308Z]: (1460421828308): memmrk:	45829468	66425472
xdk:server:[2016-04-12T00:43:48.326Z]: (1460421828326): memmrk:	22049624	32838272
xdk:client:[2016-04-12T00:43:53.308Z]: (1460421833308): memmrk:	46007344	66425472
xdk:server:[2016-04-12T00:43:53.326Z]: (1460421833326): memmrk:	22056624	32838272
xdk:client:[2016-04-12T00:43:58.308Z]: (1460421838308): memmrk:	47901208	66425472
xdk:server:[2016-04-12T00:43:58.327Z]: (1460421838327): memmrk:	22063624	32838272
xdk:client:[2016-04-12T00:44:03.308Z]: (1460421843308): memmrk:	48108096	66425472
xdk:server:[2016-04-12T00:44:03.327Z]: (1460421843327): memmrk:	22070640	32838272
xdk:client:[2016-04-12T00:44:08.314Z]: (1460421848314): memmrk:	47732260	66425472
xdk:server:[2016-04-12T00:44:08.327Z]: (1460421848327): memmrk:	22077672	32838272
builds:[2016-04-12T00:44:13.037Z]: (1460421853037): Unrecognized preference: permissions
xdk:client:[2016-04-12T00:44:13.315Z]: (1460421853315): memmrk:	49190640	67428992
xdk:server:[2016-04-12T00:44:13.328Z]: (1460421853328): memmrk:	22084688	32838272
xdk:client:[2016-04-12T00:44:18.316Z]: (1460421858316): memmrk:	48635224	67428992
xdk:server:[2016-04-12T00:44:18.328Z]: (1460421858328): memmrk:	22091704	32838272
client:remote-tab:[2016-04-12T00:44:19.620Z]: (1460421859620): About to start needsDebugModule in addTabWatcher
xdk:client:[2016-04-12T00:44:23.316Z]: (1460421863316): memmrk:	50613804	69526144
xdk:server:[2016-04-12T00:44:23.328Z]: (1460421863328): memmrk:	22361232	32838272
client:build-tab:[2016-04-12T00:44:24.184Z]: (1460421864184): [updatePageState] Set State: PAGE_STATE_PREPARING
client:build-tab:[2016-04-12T00:44:24.185Z]: (1460421864185): [uploadBuildAssets] Uploading project files
xdk:client:[2016-04-12T00:44:28.316Z]: (1460421868316): memmrk:	52585916	70529664
xdk:server:[2016-04-12T00:44:28.350Z]: (1460421868350): memmrk:	30190728	54615936
xdk:client:[2016-04-12T00:44:33.317Z]: (1460421873317): memmrk:	52750712	70529664
xdk:server:[2016-04-12T00:44:33.350Z]: (1460421873350): memmrk:	33178280	54615936
xdk:client:[2016-04-12T00:44:38.317Z]: (1460421878317): memmrk:	52861332	70529664
xdk:server:[2016-04-12T00:44:38.351Z]: (1460421878351): memmrk:	34799764	63757056
xdk:client:[2016-04-12T00:44:43.317Z]: (1460421883317): memmrk:	51761568	70529664
xdk:server:[2016-04-12T00:44:43.360Z]: (1460421883360): memmrk:	29004672	63757056
xdk:client:[2016-04-12T00:44:48.318Z]: (1460421888318): memmrk:	51892824	70529664
xdk:server:[2016-04-12T00:44:48.361Z]: (1460421888361): memmrk:	35909524	63757056
client:build-tab:[2016-04-12T00:44:52.436Z]: (1460421892436): [updatePageState] Set State: PAGE_UPLOADING_PROJECT
xdk:client:[2016-04-12T00:44:53.318Z]: (1460421893318): memmrk:	54786260	74723968
xdk:server:[2016-04-12T00:44:53.362Z]: (1460421893362): memmrk:	31882748	63757056
xdk:client:[2016-04-12T00:44:58.320Z]: (1460421898320): memmrk:	46606216	74723968
xdk:server:[2016-04-12T00:44:58.362Z]: (1460421898362): memmrk:	32813240	63757056
xdk:server:[2016-04-12T00:45:03.362Z]: (1460421903362): memmrk:	32827908	63757056
Node Webkit Error log:
[10252:0412/023957:INFO:CONSOLE(17)] ""xdk:client:[2016-04-12T00:39:57.148Z]: (1460421597148): Failed to load theme: xdk" {"code":"MODULE_NOT_FOUND"}", source: C:\Users\CaioCoCora\AppData\Local\Intel\XDK\xdk\core-modules\private\logger.js (17)
[10252:0412/024034:INFO:CONSOLE(212)] ""NW proxy string: DIRECT"", source: /brackets.js (212)
[10252:0412/024035:INFO:CONSOLE(17)] ""client:build-tab:[2016-04-12T00:40:35.347Z]: (1460421635347): [refreshPage] Unable to generate project hash." {"message_":"Cannot generate app id without user identifiers","code_":null,"componentName_":null,"stack_":"Error\n    at Object.createXdkAppId (C:\\Users\\CaioCoCora\\AppData\\Local\\Intel\\XDK\\xdk\\core-modules\\private\\service\\http-wrappers.js:17:543)\n    at Object.exports.generateProjectHash (file:///C:/Users/CaioCoCora/AppData/Local/Intel/XDK/xdk/components/client/backend-service-utils/backend-service-utils.js:17:1574)\n    at _refreshPage (file:///C:/Users/CaioCoCora/AppData/Local/Intel/XDK/xdk/components/client/build-tab/build-tab.js:17:6994)\n    at Object.start (file:///C:/Users/CaioCoCora/AppData/Local/Intel/XDK/xdk/components/client/build-tab/build-tab.js:17:3869)\n    at resumeClientInit (C:\\Users\\CaioCoCora\\AppData\\Local\\Intel\\XDK\\xdk\\core-modules\\private\\main.js:17:12040)\n    at C:\\Users\\CaioCoCora\\AppData\\Local\\Intel\\XDK\\xdk\\core-modules\\private\\main.js:17:1734\n    at _fulfilled (C:\\Users\\CaioCoCora\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\q\\q.js:834:54)\n    at self.promiseDispatch.done (C:\\Users\\CaioCoCora\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\q\\q.js:863:30)\n    at Promise.promise.promiseDispatch (C:\\Users\\CaioCoCora\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\q\\q.js:796:13)\n    at C:\\Users\\CaioCoCora\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\q\\q.js:604:44","httpCode_":400}", source: C:\Users\CaioCoCora\AppData\Local\Intel\XDK\xdk\core-modules\private\logger.js (17)
[10252:0412/024413:INFO:CONSOLE(17)] ""builds:[2016-04-12T00:44:13.037Z]: (1460421853037): Unrecognized preference: permissions"", source: C:\Users\CaioCoCora\AppData\Local\Intel\XDK\xdk\core-modules\private\logger.js (17)
[10252:0412/024453:INFO:CONSOLE(0)] "Refused to set unsafe header "Content-Length"", source: file:///C:/Users/CaioCoCora/AppData/Local/Intel/XDK/xdk/public/index-node-webkit.html (0)
[10252:0412/024501:INFO:CONSOLE(0)] "Refused to set unsafe header "Content-Length"", source: file:///C:/Users/CaioCoCora/AppData/Local/Intel/XDK/xdk/public/index-node-webkit.html (0)
[10252:0412/024503:INFO:dispatcher_host.cc(154)] [NW.JS]RenderProcessWasKilled
[10252:0412/024504:FATAL:render_process_host_impl.cc(479)] Check failed: !g_exited_main_message_loop.
XDK exit code & signal: 3221226324, null
Crash minidump not found in XDK data folder. Falling back to TEMP...
Crash minidump NOT FOUND.
NW Crash Detected.
What can I do for fix it?
PaulF_IntelCorp
Can you ZIP your ENTIRE project folder and attach it to a post (use the Attach Files to Post link below the edit window). Or, provide a link to a dropbox or similar download location. I suspect you have a bad build setting.
