Hello, can't link a view to join with a button element. I'm using the ratchet framework to make this application, my button code is:
<button class="btn btn-negative btn-block" href="../alfabeto_vie.html">Clique para prosseguir</button>
I'm trying to join this element with a html file called "alfabeto_vie.html", this file here's on the same location folder with the index.html.
I was consulting the framework's documentation, this documentation explains that's formula bellow:
<a class="navigate-right" href="../two.html" data-transition="slide-in">
Load new page with push
</a>
in otherwise, I did a view using the app design, with the same contents. But I still can't link a view with this button.
how I can link this elements?
well, my project have this structure:
- Tags:
- HTML5
- Intel® XDK
../ in the link means "go up to parent directory". But these two files (index.html and alfabeto_vie.html) are at the same level.
Therefore the link should be href="alfabeto_vie.html"
Also, your Mac is set up to hide file extensions. So make sure alfabeta_vie.html has the ".html" extension.
