Software Archive
Read-only legacy content
17060 Discussions
I couldn't get local json file with jquery.getJSON method
Fatih_Mert_D_
Hi guys,
My json file is 'www/js/test.json' so it is same folder with app.js
My codes in app.js simple get json method my code bellow;
window.kelDb = "";
$.getJSON('test.json',function(jData){
    window.kelDb = jData;
var kDb = window.kelDb;
alert(kDb.simple.tree);
How can I do access in www folder any file type ?
Thank you for interest.
Good works..
Elroy_A_Intel
The method that you are using is intended to load JSON-encoded data from a server using a GET HTTP request as stated here. You are not able to load local file with that method. By design, standard JavaScript is not allowed to access or operate on a file.
Fatih_Mert_D_
How can I load local json file to associated javascript varriable ? Is this possible ?
Thank you.
PaulF_IntelCorp
You'll need to use the File plugin to access the file. See the Cordova core plugins in the plugin manager on the projects tab.
