Software Archive
Read-only legacy content
17060 Discussions
IAS Assembler Issues
inbuninbu
I have been trying to compile the IAS assembler, however it does not seem to like my system very much. I've solved a number of simple problems, however gcc now spits out
src/ias/pmath.h:77: error: parse error before `;' token
make[1]: *** [frmt_hash.o] Error 1
make[1]: Leaving directory `/home/jeff/Desktop/ias/src/ias/build'
make: *** [_build_build] Error 2
An investigation of the offending line reveals:
74:template
75:string get_string_from_num(NUM_t num)
76:{
77: ostrstream tmp_stream;
78: tmp_stream << num << ends;
79: return string(tmp_stream.str());
80:}
I'm stumped. Although I can't use either of the versions of gcc suggested (at least, not without a lot of trouble), I'm using 3.3.5, which is pretty close, and I can't imagine any gcc version peculiarities that would throw an error on this seemingly straightforward line of code.
Anyway, any help or suggestions would be most appreciated.
Intel_Software_Netw1
We're consulting our resident experts and will reportour findings here.
For a related discussion and alist of potentially helpful links, see this other thread.
Lexi S.
IntelSoftware NetworkSupport
http://www.intel.com/software
Contact us
One engineer suggests:
ostrstream is deprecated in the ISO C++ standard. I suspect theres some compiler/prepreprocessor flag that needs to be flipped one way or the other to enable the deprecated feature. The GNU header for 3.2.3 is backward/strstream.h. Maybe adding an explicit #include would help.
Lexi S.
Contact us
Denis_M_Intel1
Well, there are some IAS build issueswith gcc older than 3.3.0.
Try to changesome codelines (it was tested with gcc 3.4.5) in the following way:
src/DVLoc/global_access_board.cpp, line 748, remove ##:
#define CONTAINS_NIF_EVENTS(rgab_name) ((*p_rgabs_array)[RgabClassFactory::rgab_name]->ContainsNonImpliedFEvents())
src/DVLoc/ia64_resource.cpp, line 821, remove ##:
#define UPDATE_RES_NAME(res,name) strcpy(ResourceName[res],#name);
src/asmutils/unwind/und_internal.h, lines 37,38,39, remove .h extensions:
#include
#include
#include
src/ias/my_strstream.h, line 33, remove .h extension:
#include
