Software Archive
Read-only legacy content
ICC compiler complaining about missing license
Zhunping_Zhang
We are using ICC at a class and we are trying to set up a cloud with ICC on every computer. However, ICC complains about missing license no matter how we install it. From the license file we got, it seems it wants to use ether as the license server. We installed ICC on ether. During the installation, we activated it using the license file we got. Whe we run it, it complains that a license is not available. Here are the extract of the license file and the error message.
Thanks!
Justin
==license
SERVER ether 00266cf247a8 28518
VENDOR INTEL
SIGN=E49AE9E0BBB0
==error message
Error: A license for CCompL is not available (-18,147).
Make sure that a license file is being used that contains a license for the requested feature.  If your license requires a license server, make sure that the server is using the right license file (usually, this would be the same license file that is being used by this application), and make sure that you have not changed the license file since starting the server.
James_T_Intel
Hi Justin, I've edited your post to remove your serial number. Please do not post serial numbers, as this could allow others to use your license. The signature you posted does not match the signature I see for your license file. I'm going to resend the license file to the registered owner (Charles Leiserson), please try using that file and let me know if it helps. Sincerely, James Tullos Technical Consulting Engineer Intel® Cluster Tools
