Software Archive
Read-only legacy content
IOS Build error code 65
magdelaine__anthony
I'm trying to make a build usiing admob and IAP plugins, so the google play services is also requiered.
but if it works correctly for crosswalk application, it doesn't works aswell for IOS...
here is the error message.
if someone could light me... i also tryed building without admob and IAP plugins without difference
main page +detailled log:
/usr/bin/codesign --force --sign 4D2BA8845AACFEBE4877DD4786E516E8731F5B1C --resource-rules=.../Cordova/platforms/ios/build/device/How\ to\ make\ Games.app/ResourceRules.plist --entitlements .../Cordova/platforms/ios/build/How\ to\ make\ Games.build/Release-iphoneos/How\ to\ make\ Games.build/How\ to\ make\ Games.app.xcent .../Cordova/platforms/ios/build/device/How\ to\ make\ Games.app
4D2BA8845AACFEBE4877DD4786E516E8731F5B1C: no identity found
Command /usr/bin/codesign failed with exit code 1
The following build commands failed:
CodeSign build/device/How\ to\ make\ Games.app
(1 failure)
Error code 65 for command: xcodebuild with args: -xcconfig,.../Cordova/platforms/ios/cordova/build-release.xcconfig,-project,How to make Games.xcodeproj,ARCHS=armv7 armv7s arm64,-target,How to make Games,-configuration,Release,-sdk,iphoneos,build,VALID_ARCHS=armv7 armv7s arm64,CONFIGURATION_BUILD_DIR=.../Cordova/platforms/ios/build/device,SHARED_PRECOMPS_DIR=.../Cordova/platforms/ios/build/sharedpch
Command finished with error code 2: .../Cordova/platforms/ios/cordova/build --release,--device
ERROR building one of the platforms: Error: .../Cordova/platforms/ios/cordova/build: Command failed with exit code 2
You may not have the required environment or OS to build this project
at ChildProcess.whenDone (/Developer/cordova/5.1.1/node_modules/cordova/node_modules/cordova-lib/src/cordova/superspawn.js:134:23)
at ChildProcess.EventEmitter.emit (events.js:98:17)
at maybeClose (child_process.js:753:16)
at Process.ChildProcess._handle.onexit (child_process.js:820:5)
Amrita_C_Intel
Hello Anthony,
First you need to do the setup before you can run for iOS platforms.
Here is the article which will guide you through three main steps in details.
https://software.intel.com/en-us/xdk/docs/building-cordova-ios-apps-intel-xdk
