Software Archive
Read-only legacy content
17060 Discussions
Ignoring Alpha OpenVMS arithmetic error
Deleted_U_Intel
Is there any way on such a system to ignore certain arithmetic errors through environment settings rather than by compilation options?
I am getting a high performance arithmetic error for what it detects as a divide by zero. (I know, sloppy code). The same code on Windows or various Unix systems works -- it apparently returns a zero, which is OK.
The issue is that this was compiled on a customer system on the other side of the world and we do not have an Alpha system or essentially any OpenVMS knowledge.
Thanks for any help.
I suspect that on the other systems, you get an IEEE NaN, not a zero. You can get that too on VMS, but need to compile with /FLOAT_TYPE=IEEE /IEEE_MODE=UNDERFLOW_TO_ZERO There is no environment setting that will do this for you, as it requires completely different generated code.
Steve
