Software Archive
Read-only legacy content
Implementing Facebook Plugin
Hakim_T_
Hi All,
Just trying to implement facebook connect to my app which is build for Android Crosswalk ( using version 10 presently), I am using XDK version 1816, I am following the tutorial : https://software.intel.com/en-us/html5/articles/integrating-facebook-functionality-into-hybrid-apps-using-the-intel-xdk
but i am stuck at the stage : Android Key Hash from the XDK Build Procedure I can't find info on how to generate this hash key, the info on the post is out dated so any help to solve this issue is welcomed
Thank you
Hakim
Kancho_K_
Hi Hakim
As far as I know the Intel FB library is already deprecated and if you ask me I would recommend you to use this one: http://coenraets.org/blog/2014/04/facebook-phonegap-cordova-without-plugin/
 I am using it in my apps and it is working quite well. Keep in mind that to be able to use it, you would need to add the Cordova inappbrowser as a third-party plugin to your application. All that you need to do is very well described here, plus the library download link of course: https://github.com/ccoenraets/OpenFB
 Hope this would be of help to your development.
Hakim_T_
Hi Kancho,
Thank you for your reply I will test it and get back to you with my thoughts, There is one more thing I would like to ask you about is the Android key Hash how do you build it for development and production environements
Thx again for your quick reply.
Hakim
Amrita_C_Intel
Hi Hakim,
You can refer--  https://github.com/Wizcorp/phonegap-facebook-plugin
And download the Zip
Import the project and test that sample is working. So this is the updated document for Facebook plugin integration.
And similarly you make your project work.
