Software Archive
Read-only legacy content
17060 Discussions
InputBox in QuickWin?
sabalan
Does anybody know if there is something like Visual Basic's InputBox function to be called in QuickWin? (A little dialog with OK- and Cancel-buttons and an Edit box). Perhaps something like MESSAGEBOXQQ?
Sabalan.
It's easy to create your own with a simple dialog box and an edit control. It's only two lines of Fortran source - DlgModal and DlgGet.
Steve
sabalan
Steve, Thanks for the tip. Maybe I should explain the problem more detailed: I have a dialog in QuickWin with several buttons and Edit boxes. What I wished was to open a new simple dialog when I click one of the buttons in the first dialog, to make it possible for the user to enter a value. I can do this in VB with just one line:
MyVariable=Val( InputBox(prompt[, title][, default][, xpos][, ypos][, helpfile, context]))
This opens a little, predesigned dialog, without losing the first dialog (or "form"), with an Edit box and 2 buttons: OK and Cancel. I don't even need to check if the OK or Cancel button was clicked or Enter was pushed. MyVariable is going to get a value from Edit box, or 0 if Cancel is clicked.
But I have been thinking, writing, coding, testing, reading N. Lawrence's book, tearing my hair, and have not been able to do this in 2 Fortran lines! What I have to do is as follows:
I have to design a new dialog in Resource Editor with 2 Edit boxes: 1 without border and "Read only" to show the prompt (above), and the other as an ordinary Edit box. This dialog can be called IDD_DIALOG2. Then:
Several variable declarations and a COMMON, and:
       Status = DlgInit (IDD_DIALOG2, InputData) ! the first dialog disappears
Status = DlgSet (InputData, IDC_EDIT1, Trim(Prompt)) ! Show preset Prompt
Write (Default,'(F8.4)') MyDefaultValue
Status = DlgSet( InputData, IDC_EDIT2, Trim(AdjustL(Default)))
Status = DlgSetSub( InputData, IDC_EDIT2, UpdateValue )
Resp = DlgModal (InputData)
If (Resp == 1) Then
MyVariable = CallBackVar ! CallBackVar should be shared through a COMMON
End If
Call DlgUninit (InputData)
Goto ? ! to DlgInit the first dialog
I Have to create a callback subroutine UpdateValue too, with SELECT CASE, and COMMON, and variable declarations, to update the CallBackVar. And forget about controlling the position of the dialog and help facilities (as I could do with VB InputBox).
I think that I should create an own function to do this, because I have to use such a thing very often. But I appreciate very much if you could show an easier way for that (although not just in 2 Fortran lines!). As I wrote in my question, something like MESSAGEBOXQQ would be ideal.
Sabalan.
