Software Archive
Read-only legacy content
17060 Discussions
Installation and Visual Studio 2010 Integration
Woogoo
Having installed Window 7 Ultimate N (x64) from MSDN I am unable to correctly install the ICC Pro (v11.1.070 update 8). My support has expired but should not be an issue as I am attempting to install the last available ICC. Visual Studio is also from MSDN as well here is the output from the Welcome section of the Installer:
Intel C++ Compiler Professional Edition for Windows* installation can continue, but take note
The Intel C++ Compiler Professional Edition for Windows* requires that a Microsoft* development product be installed. Refer to the Release Notes for a list of the required Microsoft* development tools.
Installation can continue; however, you will have to enter full path for installed Microsoft Platform SDK.
The following components can not be installed:
- Integration(s) in Microsoft Visual Studio*
- Intel Parallel Debugger Extension
- Integrated Documentation
Installation can continue; however, these components will not be installed because they require that a supported Microsoft* development tools be installed. Refer to the Release Notes for a list of the required Microsoft* development tools.
I can't see what the issue is as both VS 2010 Pro is installed along with the Platform SDK 7.1 with .NET v4, is there something I am missing here?
Your help would be appreciated.
Bill
Igor_V_Intel
Dear Bill,
Note that VS2010 is not supported in 11.1 version of the compiler. This is the reason why the integration, documentation and Parallel Debugger Extension (also a plug-in for VS)to VS2010 failed to be installed.
You should download the latest version of the compiler (12.0 aka Composer XE) which supports the VS2010.
Igor
Woogoo
Thanks for the reply Igor, I would like to download the Composer XE but as my subscription has expired I am unable to to this.
Bill
