Software Archive
Read-only legacy content
17060 Discussions
Installing Common Areas
Intel_C_Intel
I have this scenario consider file NAV1.for
block data NAV1
include 'NAV2.for'
end
now if in NAV2.for there are more then one common area is declared like NAV2.for is like this
integer *2 a
integer *2 b
common/N1/a
common/N2/b
now If I use following command to link NAV1
$ Link/Share/Exe = NAV$COMMON:NAV1.EXE -
NAV$OBJECT:NAV1.OBJ, SYS$INPUT/OPTION
SYMBOL_VECTOR=(N1=PSECT)
PSECT_ATTR=N1,SHR
in third and fourth line I have to use the name of one of the common area otherwise if I use NAV1 in third and fourth line it gives
%LINK-W-UPSCNOCONTRI, universal psect NAV1 was not contributed by any object module
deleted from Global Symbol Table
but if I use N1 and install it with following command
$ Install Create SYS$SHARE:NAV1/WRITABLE/SHARED
It does'nt work for the programs that uses N2 common areas, is there any way to link NAV1 as shareable and install it, so that both common areas are available.
Naveed
james1
You need to make an entry for each common you want to share, so use an options file such as:
symbol_vector=(n1=psect)
symbol_vector=(n2=psect)
psect_attr=n1,shr
psect_attr=n2,shr
and link/share nav1,options/opt to get all your globals defined.
James
