Software Archive
Read-only legacy content
17060 Discussions
Installing yields unknown language
BvU
Is there a way to get a simple english version? When I install I get an unknown language:
Korean, chinese, japanese, I don't know and I can't paste an example here. The installation also screws up the MS VS2010, so I can't use that nay more either. Great.
Igor_V_Intel
Dear customer,
Looks like you are installing the Japanese package (it contains jp in the installator filename).
You can download the required package from the Registration Center (check that there is no jp in the package name).
Igor
Igor_V_Intel
About your VS2010 integration - it may be necessary to reinstall it as far as the integration from Japanese package was installed. Uninstall the Japanese version of the compiler and try to install the correct one.
If VS integration doesn't work correctly, then uninstall compiler and VS and reinstall again (VS should be installed first).
Igor
