Software Archive
Read-only legacy content
17060 Discussions
Intel App Preview launch button not working
Jordi_D_
Hello, on the last update of App Preview (2.3.0), the launch button isn´t working on my iPhone 4 (ios 7.1.2).
Any can help me?
PaulF_IntelCorp
I tested a beta copy and it appeared to fix the problem. Sometimes it takes a few weeks to get past the Apple update process, which is outside of our control. I do not know what the expected date into the store is, but I would expect it in days or weeks.
Swati_S_Intel1
What error message do you get? Try to kill the App Preview app and relaunch. Also, push the project from test tab one more time. Does scanning of the barcode work for you?
Swati
Swati_S_Intel1
There is an issue with launching a new app. I've reported the issue.
If you are launching new app the App Preview is not able to pull it in the first attempt, so as I mentioned earlier kill the App Preview app and relaunch.
Swati
Jordi_D_
I've tried your solution and still not working the launch button.
The app don't give me any error, just I tap on launch button and the app don't launch my app simulation.
Swati_S_Intel1
Try logging out and then log back in to the App Preview. That should refresh the app.
Swati
Adam_G_
I am having the sale issue on my iPhone 4 (iOS 7.1.2).  I've logged out and back in, I've killed the app and re-launched; I even did a clean install of the OS; none of these have worked.  The Demo Apps (form the demo apps tab) and those work but any of my apps form the "server apps" tab get to the screen with the giant "play" button (blue circle with a white triangle facing right) and then just stop there (pushing the button has no effect though I can always go back to the app list or switch tabs.  It never even gets to the Intel splash screen.
I've tried creating new apps and trying those but i get the same result.
Has intel tried our the XDK on an iPhone 4 with iOS 7.1.2?
Any idea how to get this working?
Swati_S_Intel1
Can you try removing the App Preview altogether from your phone and then install it again? You said the demo apps work so looks like some apps are working. Maybe it's a problem with the app. Can you send me one of your app so I can test it?
Swati
Adam_G_
I have installed the Intel App Preview twice (once with each of the versions of iOS i have had on this device (latest is 7.1.2)).  I just tried deleting it again and re-installing; same result.
I doubt it's the apps I'm building as some of them are literally just a blank project (repro: go into the XDK, great a new project from a blank HTML5 template > upload to the test servers > and I can't click on it.  The issue seems to manifest in the inability to click the button.  I get the same button on the demo apps but I can click it and then the intel splash screen comes up, followed by the app.  For the page with user defined apps, I can select one of my apps but then pushing the button does nothing.  Other buttons on the page (back, and the tabs as the bottom) all work as expect.
I also notice that if I take a sample app in the XDK (I chose the 2048 app) it will also not launch.  It seems that anything on the "Server Apps" tab will get to the page where you can launch with the big "play" button but you can't push that button to initiate the app.
I would try using the camera to scan the bar code but it appears that it is unable to focus. (there are other threads on that issue so I don't want to complicate it here; just mentioning it so that we don't have to go try that path).
Are you able to launch your projects from the XDK (build: 1912) to a iPhone 4?
PaulF_IntelCorp
Yes, I just confirmed I'm having the same problem (plus a few others) with App Preview 2.3.0 on an iPod running iOS 6.1.6, which should work. I'll file a bug report. I was just running with App Preview 2.2.0 with no problems on this device.
Jordi_D_
How Adam G. said, install/unistall App Preview and login/logout isn't working.
I've tried use new templates from Intel XDK, upload to Server Apps and the result is the same: Big play button don't launch the app.
Hamilton_Tenório_da_
Valued Contributor I
The same problem in my iPhone 3S with iOS 6.1.6.
No error, just not open the APP. The tap is dead...
I uninstall, reinstall, etc. and nothing.
I tried to with QR Code. It works, but the APP does not open.
Adam_G_
It look like Paul (with the Intel account) has filed a bug on this.  There will need to be a new version of the client app I would assume so we're waiting for that.  Once they publish an update (and I hope Paul will let us know but those of us with iPhone 4's may also end up seeing it first when it's published) then we can reply to the thread about if this is fixed.  As of this writing, this is still an unresolved issue.
Steve_F_
I'm having exactly the same problem.  The app launch button isn't functioning with version 2.3.  Tried all the basic stuff like powering down my iphone and uninstalling/reinstalling the app.  No luck.
PaulF_IntelCorp
A bug report has been filed. Engineering is looking into this problem. Please see prior comment:
When a fix is implemented a new version of App Preview will be pushed to the store and you should receive a notification directly from the store. Until then, I have no workaround available.
Jordi_D_
Thanks Paul.
We will be waiting for the new version as soon as possible
David_T_
Suggestion - Please put a notice on the XDK platform (via Twitter postings?)  for problems like this so that feature degradations are common knowledge and people don't have to search the internet to discover that they're having the same problem. Thank you.
I didn't realize how much i relied on this tool - BTW the android App Preview is working fine (using android 2.3 on my 2 year "old" device).
Great product guys, we really appreciate all the work you do!
PaulF_IntelCorp
good suggestion -- we have identified the problem and are working on getting an update into the store
Rich_S_
What is the status of this issue?
Rich_S_
Any estimate on when the IOS fix will be released?  Are we talking days, weeks or months?
Rich
PaulF_IntelCorp
Jordi_D_
Good news!!!! The last update works perfect on iPhone 4 and iOs 7.1.2!!
Thanks Intel Team!!
