I am using Device Spy Version 1.3.1768.24086 and have noted the following behavior.
The controlURLs in my DDDs include query strings, so the "&" characters are encoded as & in the DDD.
For example, controlURL "/path?a=b&c=d" will be encoded in the XML as "/path?a=b&c=d".
When Device Spy uses this controlURL for an HTTP POST, it should retain the literal "&" but it does not; instead it quotes it as %26.
In the example above, the URL will be received as "/path?a=b%26c=d", so the HTTP server will not correctly parse the query string.
Note that it would be incorrect for the HTTP server to un-escape the query string before parsing it, because the query components might validly contain escaped special characters.
Any comments? Thanks,
William Lupton
William Lupton
