Software Archive
Read-only legacy content
17060 Discussions
Intel Edison WiFI Problem
Bertug_Berkay_Y_1
Hello!
I am having an issue with my Edison. I have been using my Edison for a while and had no problems with it but yesterday I got the issue. When I type
> configure_edison --wifi or >configure_edison -w
I have this error:
Failed to connect to non-global ctrl_ifname: (null)  error: No such file or directory
Even if I rescan >0
I get the same error.
I deleted my image and flashed the newest one from Intel's website. No good. I don't know what to do. Any ideas?
Bertuğ
NagaVenkat_K_Intel
Never saw this issue before. Are you still facing this? Have you tried setting up using
#configure_edison --setup
Also please check the version of Yocto build
#cat /etc/version
Bertug_Berkay_Y_1
I tried
>configure_edison  --setup as well, no good :(
About the version, I am going to check and add it down here.
Bertug_Berkay_Y_1
# cat /etc/version result is :
edison-weekly_build_56_2014-08-20_15-54-05
I still could not figure out the problem. I am going to try re-flast the Yocto again. I will be waiting your ideas.
Matthias_H_Intel
that's a REALLY old version and you really should upgrade to latest
