Software Archive
Read-only legacy content
17060 Discussions
Intel HAXM not Working i Almost did everything Help needed.
Uzair_W_
Hello Intel :(
I Am Trying to install HAXM for android but its show me error
My System Is :
Intel® Core™ i5-4440 Processor
(6M Cache, up to 3.30 GHz)
i already check BIOS setting Virtulization is Enable And i already check with Intel Utility Tool.
and i already disable from bios and check again in studio still shows error .
my Windows is :
Windows 7
64 bit
i disable avast for 10mins and try again result remain same.
When ever i try to run emulator its shows me error :
emulator: ERROR: x86 emulation currently requires hardware acceleration!
Please ensure Intel HAXM is properly installed and usable.
CPU acceleration status: HAX kernel module is not installed!
i already install sdkmanager>extras> intel x86 emulator Accelerator.
when i try by going in folder and install it manually intellhaxm-android its shows me error Picture Attached.
What Should i do ?
Matthias_H_Intel
virtualization would have to be enabled in BIOS. Not quite clear what you set at the end: "already check BIOS setting Virtulization is Enable And i already check with Intel Utility Tool.
and i already disable from bios and check again in studio still shows error ."
