Software Archive
Read-only legacy content
17060 Discussions
Intel Joule with RealSense : Power
Sara_M_
I've been scouring the internet for max power specs, but I cannot find anything about the maximum amount of power the Intel Joule can put out through all of its peripherals i.e. how much power does the Intel Joule need when using it with all peripherals attached ? Can you please recommend what would be the ideal adaptor to use for powering it ? Right now I just need to power an Intel RealSense (R200 / ZR300) sensor with the Joule's USB 3.0 port, with perhaps another peripheral( a USB stick ).
Thank you very much !
Gal_A_Intel
Hi Sara M,
The ideal adaptor recommended should be :
INPUT:  100-240V~  50-60Hz 1.0A . OUTPUT: 12.0V=3000mA
Best Regards
Gal A
Intel Corporation
