Software Archive
Read-only legacy content
17060 Discussions
Intel License Manager for Flexlm errors
christophe_ogniervsg
I have bought some licenses for Treadchecker, ThreadProfile, VTUne to run with the flexlm manager.
Theses licenses are floating.
I use a Win 2008 64bit virtual server (EMT64) with flexlm.windows.ia32.zip (correct). Firewall is disabled.
The service cannot start. Here is the server status enquiry result (lmtools). (I changed the server name with its Ip in the lic file : no result)
Status
Flexible License Manager status on Fri 8/28/2009 16:31
[Detecting lmgrd processes...]
License server status: [email protected]
License file(s) on 192.168.192.150: C:\Program Files (x86)\Common Files\Intel\Licenses\intel_combined.lic:
lmgrd is not running: Cannot connect to license server
The server (lmgrd) has not been started yet, or
the wrong port@host or license file is being used, or the
port or hostname in the license file has been changed.
Server name: 192.168.192.150
License path: [email protected]
FLEXlm error: -15,10. System Error: 10061 "WinSock: Connection refused"
For further information, refer to the FLEXlm End User Manual,
available at "www.macrovision.com".
Server diags says :
Diagnostics
FLEXlm diagnostics on Fri 8/28/2009 16:32
License file: C:\Program Files (x86)\Common Files\Intel\Licenses\intel_combined.lic
"I69DC4AE9" v2010.0828, vendor: INTEL
License server: 192.168.192.150
nodelocked license locked to NOTHING (hostid=ANY) no expiration date
Requests from the same USER/HOST do not consume a new license
This license cannot be checked out because:
... I will try to determine what the problem is...
"telnet" port (23) on node 192.168.192.150 does not respond
->if 192.168.192.150 is a Unix system, it's probably down
Here is my lic file (combined keys). It doesn't work either with a single key.
Could anyone help ?
Thank you.
Shamla_P_Intel
Status
License file(s) on 192.168.192.150: C:Program Files (x86)Common FilesIntelLicensesintel_combined.lic:
Server diags says :
Diagnostics
License file: C:Program Files (x86)Common FilesIntelLicensesintel_combined.lic
Could anyone help ?
Thank you.
Greetings,
There is an article explaining the workaround for thebug preventing the normal start process of the license server on Windows Vista* or Windows Server* 2008.
http://software.intel.com/en-us/articles/installing-license-server-on-vista/
Please let me know if this helps.
Also Please don't post license file, serial number, e-mail address etcin an forum.
Thank You
Shamla
Quoting - Shamla (Intel)
Greetings,
Thank You
Shamla
Thank you for your help.
Even if non very convenient since it's a manual workaround, but I'm wondering if it's related to windows or flex ?
I tried to edit the parameters of the service, and added the -c , applied and reopened properties : it removed it automatically....
Sorry for the license details but I thought it could have helped.
Thanks again.
Shamla_P_Intel
Thanks again.
Thank You for the quick update. It is a Flexlm limitation.
Shamla
