Software Archive
Read-only legacy content
17060 Discussions
Intel MIC LDAP Issue
Atul_Y_
Dear Team,
In our setup we are having 6 MIC cards on 3 host machines.
Out of 6 mic cards, 1 card is not working with ldap authentication.
The troubleshooting steps given below:-
[root@phi1-mic0 ~]# rpm -qa | grep ldap
[root@phi1-mic0 ~]#
[root@phi1-mic0 ~]# logout
Connection to phi1-mic0 closed.
[root@nandadevi1 ~]# ssh phi1-mic1
[root@phi1-mic1 ~]# rpm -qa | grep ldap
libldap-2.4-2-2.4.23-r1.k1om
nss-ldap-265-r0.k1om
pam-ldap-186-r0.k1om
[root@phi1-mic1 ~]#
MIC 0 Log
Oct  6 16:39:58 phi1-mic0 authpriv.info sshd[7022]: pam_unix(sshd:session): session closed for user root
Oct  6 16:40:27 phi1-mic0 authpriv.err sshd[7028]: PAM unable to dlopen(/lib64/security/pam_ldap.so): /lib64/security/pam_ldap.so: cannot open shared object file: No such file or directory
Oct  6 16:40:27 phi1-mic0 authpriv.err sshd[7028]: PAM adding faulty module: /lib64/security/pam_ldap.so
Oct  6 16:40:27 phi1-mic0 authpriv.err sshd[7028]: PAM unable to dlopen(/lib64/security/pam_mkhomedir.so): /lib64/security/pam_mkhomedir.so: cannot open shared object file: No such file or directory
Oct  6 16:40:27 phi1-mic0 authpriv.err sshd[7028]: PAM adding faulty module: /lib64/security/pam_mkhomedir.so
[root@phi1 ~]# micctrl --config
mic0:
    Config Version: 1.1
    Linux Kernel:   /usr/share/mpss/boot/bzImage-knightscorner
    Map File:       /usr/share/mpss/boot/System.map-knightscorner
    BootOnStart:    Enabled
    Shutdowntimeout: 300 seconds
    ExtraCommandLine: Not configured
    PowerManagment: cpufreq_on;corec6_off;pc3_on;pc6_off
    Root Device:   Dynamic Ram Filesystem /var/mpss/mic0.image.gz from:
        Base:      CPIO /usr/share/mpss/boot/initramfs-knightscorner.cpio.gz
        Overlay:   RPM /root/mpss-3.3/k1om/pam-plugin-mkhomedir-1* on
        Overlay:   RPM /root/mpss-3.3/k1om/libldap-2.4-2-2.4.23-r1.k1om.rpm on
        Overlay:   RPM /root/mpss-3.3/k1om/nss-ldap-265-r0.k1om.rpm on
        Overlay:   RPM /root/mpss-3.3/k1om/pam-ldap-186-r0.k1om.rpm on
        Overlay:   Filelist /opt/lustre/2.5.2 /opt/lustre/2.5.2/lustre-client-mic-modules.filelist on
        Overlay:   Filelist /opt/lustre/2.5.2 /opt/lustre/2.5.2/lustre-client-mic.filelist on
        CommonDir: Directory /var/mpss/common
        Micdir:    Directory /var/mpss/mic0
    Network:       Static bridge br0
        MIC IP:    192.168.1.82
        Host IP:   192.168.1.81
        Net Bits:  24
        NetMask:   255.255.255.0
        MtuSize:   1500
        Hostname:  phi1-mic0.imsc.res.in
        MIC MAC:   4c:79:ba:54:00:66
        Host MAC:  4c:79:ba:54:00:67
    LDAP:          Enabled
     NIS:          Disabled
    Cgroup:
        Memory:    Disabled
    Console:        hvc0
    VerboseLogging: Disabled
    CrashDump:      /var/crash/mic 16GB
mic1:
    Config Version: 1.1
    Root Device:   Dynamic Ram Filesystem /var/mpss/mic1.image.gz from:
        Overlay:   RPM /root/mpss-3.3/k1om/nss-ldap-2* on
        Overlay:   RPM /root/mpss-3.3/k1om/pam-ldap-1* on
        Micdir:    Directory /var/mpss/mic1
        MIC IP:    192.168.1.83
        Net Bits:  24
        MtuSize:   1500
        Hostname:  phi1-mic1.imsc.res.in
        MIC MAC:   4c:79:ba:54:00:70
        Host MAC:  4c:79:ba:54:00:71
    LDAP:          Enabled
     NIS:          Disabled
    Cgroup:
        Memory:    Disabled
    Console:        hvc0
[root@phi1 ~]#
Need your guidance to resolve the problem
Thank you
Atul Yadav
James_T_Intel
I'm moving this to the appropriate forum.
