Software Archive
Read-only legacy content
17060 Discussions
Intel(R) 82852/82855 GM/GME Graphics Controller Problem
ramazansaribay
INTEL EXTREME GRAPHICS 2 FOR MOBILE REPORT
Report Date:05/29/2008
Report Time[hr:mm:ss]:01:00:22
Driver Version:6.14.10.4497
Operating System:Windows XP* Professional, Service Pack 3 (5.1.2600)
Default Language:English
DirectX* Version:9.0
Physical Memory:758 MB
Minimum Graphics Memory:8 MB
Maximum Graphics Memory:64 MB
Graphics Memory in Use:7 MB
Processor:x86 family 6 Model 13 Stepping 6
Processor Speed:1100 MHZ
Vendor ID:8086
Device ID:3582
Device Revision:02
* Accelerator Information *
Accelerator in Use:Intel 82852/82855 GM/GME Graphics Controller
Video BIOS:3098
Current Graphics Mode:1024 by 768 True Color (60 Hz)
Here is my laptop. I have got problem playing game in OpenGL, D3D or Software mode. For example Quake 3 or Half-Life. I play the game a bit then the game slows than for 2 or more minutes. Then it is back to normal. But again it does the same thing and more frequent. I have tried everything that I can. I have formatted harddisk, installed windows and necessary drivers and I havent installed any other program, to test it without any program working on background. But it doesn't solve the problem. I have the latest drivers and DirectX. I have tried to change the rams' slots or using them one by one it didn't help. Anyone can suggest an idea. Thanks
7oby
New Contributor II
This is definitely the wrong laptop to play games. And the chipset is EOL thus you hardly get support. However here we go:
. CPU overheating:
Some laptops are awefully designed (even brand laptops) and cannot cool the unit in extreme situations. If the CPU get's too hot, it gets throttled automatically. In these cases you see a dramatic slowdown as soon as a certain temperature is reached. In the throttle case your CPU temperature will be >70C and the CPU clock much lower than your maximum core clock (1,6GHz? 1,8GHz?). First make sure you do not suffer from these problems by installing NHC. There is also a Dell specific version:
http://www.pbus-167.com/
or if you're more advanced use RMClock (free version sufficient):
http://cpu.rightmark.org/products/rmclock.shtml
As soon as you see the slowdown, swith to Windows and watch temperature and CPU Clock in system tray. If you suffer from overheating, NHC can solve it. Google for "undervolting pentium-m nhc".
. bad drivers:
You won't get more recent drivers due to EOL. If you are an advanced (make a backup first) user, you may try the IEGD 8.0 drivers. They are more complicated to install and maintain - their are intended for embedded solutions. Standby/Suspend and such things may not work as expected any longer. However they contain more updated DirectX and OpenGL drivers:
http://www.intel.com/design/intarch/swsup/graphics_drivers.htm
BTW: wrong forum. Intel doesn't have end user support regarding those issues. Both solutions above are neither tested, advised or supported by neither Intel nor you OEM vendor.
regards,
7oby
