Boa tarde,
Estou desenvolvendo um app com o App Framework, Template com Cordova e App Designer nessa versão do Intel XDK (2611).
Consegui desenhar todas as telas e implementar os scripts dos botões no app normalmente.
E depois de realizar build e tudo mais, quis fazer algumas alterações no Design do app.
Porém a tela onde tenho os componentes só fica no "loading..." e não sai disso, as demais funcionalidades funcionam corretamente, menos a aba de Design que fica ao lado da aba de "CODE".
Alguém já passou por esse problema nessa versão do XDK ou em outra?
Obrigado desde já.
- Tags:
- HTML5
- Intel® XDK
Good afternoon,
I'm developing an app with App Framework , Template with Cordova and App Information in this version of Intel XDK ( 2611 ) .
I could draw all screens and implement the scripts of the buttons in the app normally.
And after performing build and everything, I wanted to make some changes to the design of the app.
But the screen where you have the components only is the " loading ... " and not out of it , the other features work properly, unless the flap design which is next to the tab "CODE" .
Has anyone experienced this problem in this version of XDK or another ?
Thanks in advance .
Could you clarify this? So you built your app designer app and then came back to the design screen to make some design changes but it always shows the 'Loading...' message? But you are able to view the code panel?
Thanks for the feedback,
Yes that's right. Now it is showing an error message processing .less css file.
He has been through something like that?
