Software Archive
Read-only legacy content
17060 Discussions
Intel XDK + IOS app + certyficate issue
Marek_K_
Hi, I want to use your Intel XDK soft to build an IOS app.
I have a problem with generating certificate: http://pl.tinypic.com/view.php?pic=71o00n&s=8
It is the cert which was there (by default), I have not created this file.
Unfortunately, I am not able to place it in Keychain folder.
Is that because I have to use my own cert, or do I need any special Keychain soft version?
Thanks for your help.
Elroy_A_Intel
I recommend that you follow the instructions under the "screenshot walkthrough" link in Step 5 CERTS which requires you to have a Apple Developer Program account. The CSR file needs to be uploaded online to the Apple Developer Portal Certificate panel.
For more step-by-step instructions, go to http://www.html5dev-software.intel.com/amdocs/lib/Walkthrough_v1_UploadCSR-ObtainCert.pdf.
Marek_K_
ok,thanks.
Shalayne_K_
Marek k.
Did you resolve your problem?
I have the same issue - thx
