Software Archive
Read-only legacy content
17060 Discussions
Intel XDK Player Plugin ??
jaime_m_
Hi
I have Intel XDK Player Plugin inmy project, have a simple code , but no work, what's wrong.
<!DOCTYPE html>
<html>
  * Please see the included README.md file for license terms and conditions.
    <head>
        <meta charset="UTF-8">
        <link rel="stylesheet" type="text/css" href="app_framework/3.0/af.ui.css" data-ver="2">
        <link rel="stylesheet" type="text/css" href="app_framework/3.0/icons.min.css">
        <title>Blank App Designer Cordova Web App Project Template</title>
        <meta http-equiv="Content-type" content="text/html; charset=utf-8">
        <!-- <meta name="viewport" content="width=device-width, minimum-scale=1, initial-scale=1"> -->
        <meta name="viewport" content="width=device-width, minimum-scale=1, initial-scale=1, user-scalable=no">
        <!-- <meta name="viewport" content="width=device-width, initial-scale=1, user-scalable=yes, minimum-scale=1, maximum-scale=2"> -->
        <style>
            /* following three (cascaded) are equivalent to above three meta viewport statements */
            /* see http://www.quirksmode.org/blog/archives/2014/05/html5_dev_conf.html */
            /* see http://dev.w3.org/csswg/css-device-adapt/ */
                @-ms-viewport { width: 100vw ; min-zoom: 100% ; zoom: 100% ; }          @viewport { width: 100vw ; min-zoom: 100% zoom: 100% ; }
                @-ms-viewport { user-zoom: fixed ; min-zoom: 100% ; }                   @viewport { user-zoom: fixed ; min-zoom: 100% ; }
                /*@-ms-viewport { user-zoom: zoom ; min-zoom: 100% ; max-zoom: 200% ; }   @viewport { user-zoom: zoom ; min-zoom: 100% ; max-zoom: 200% ; }*/
        </style>
        <link rel="stylesheet" href="css/app.css">
        <link rel="stylesheet" type="text/css" href="css/index_main.less.css" class="main-less">
        <script src="cordova.js" id="xdkJScordova_"></script>
        <script src="js/app.js"></script>
        <!-- for your event code, see README and file comments for details -->
        <script src="js/init-app.js"></script>
        <!-- for your init code, see README and file comments for details -->
        <script src="xdk/init-dev.js"></script>
        <!-- normalizes device and document ready events, see file for details -->
            You may substitute jQuery for the App Framework selector library.
            See http://app-framework-software.intel.com/documentation.php#afui/afui_jquery
        <script type="application/javascript" src="lib/jquery.min.js"></script>
        <script type="application/javascript" src="app_framework/3.0/appframework.ui.min.js"></script>
        <script type="application/javascript">
            $.afui.autoLaunch = false; //By default, it is set to true and you're app will run right away.  We set it to false to show a splashscreen
            /* This function runs when the content is loaded.*/
      $.afui.useOSThemes=false;
             $(document).ready(function(){
                setTimeout(function(){
                    $.afui.launch();
                },1500);
        </script>
        <script>
            function music()
            // Set Audio to play at 75% volume.
            intel.xdk.player.playSound("http://labs.qnimate.com/sound.mp3");
            intel.xdk.player.setAudioVolume(0.75);
        </script>
    </head>
    <body id="afui" class="v2">
        <div class="upage view" id="mainpage" data-header="af-header-0" data-footer="none">
          <header class="container-group outer-element uib_w_1" data-uib="app_framework/header" data-ver="3" id="af-header-0">
                <h1>Audio</h1>
                <div class="widget-container wrapping-col single-centered"></div>
                <div class="widget-container content-area horiz-area wrapping-col header-left"></div>
                <div class="widget-container content-area horiz-area wrapping-col header-right"></div>
            </header>
            <div class="pages">
                <div class="upage-content ac0 content-area vertical-col left panel" id="page_67_6">
                    <div class="grid grid-pad urow uib_row_1 row-height-1" data-uib="layout/row" data-ver="0">
                        <div class="col uib_col_1 col-0_12-12" data-uib="layout/col" data-ver="0">
                            <div class="widget-container content-area vertical-col">
                                <a class="button widget uib_w_2 d-margins" data-uib="app_framework/button" data-ver="2" onclick="music();">Button</a>
                                <span class="uib_shim"></span>
                            </div>
                        </div>
                    </div>
                </div>
            </div>
        </div>
    </body>
</html>
thankyou for your help
