Software Archive
Read-only legacy content
17060 Discussions
Intel XDK Update 3759, Build failure
Njendu__Kenneth
I had an issue that I'm running into with update 3759 (as well as 3491 which I reverted to to confirm the issue).
When I try and build out application (for Android) the IDE reports that the build failed as seen in the attached image. However, when I go ahead and open the logs (see attached text file), it indicates that the build was successful. I'm at a loss of what to do and how to resolve this issue.
Kindly advise on how I should move forward
PaulF_IntelCorp
Very confusing. Are your plugins added to your project via the plugin manager or the intelxdk.config.additions.xml file? If the latter, please remove them from the additions file and add them via the plugin manager. If that is not the case I may need to see more of your project.
Jerroyd_M_Intel
Can you take a screen shot of the summary log? Is there an error on the last line? How long did you wait for your build? 5-10 minutes? or 30 minute?
Njendu__Kenneth
Hi guys,
I was able to get past the issue by recreating tghe project, and re-importing the sources and plugins. Following that, the build worked with not issues. Thanks for your support and help. I do miss the Debug panel though. That was a sweet tool.
