Software Archive
Read-only legacy content
17060 Discussions
Intel XDK crash
Péter_T_
Intel XDK crashes when i wanted to export to android.
Pls help me!
xdk:client:[2016-04-10T21:50:53.492Z]: (1460325053493): memlim: 767557632
xdk:client:[2016-04-10T21:50:53.504Z]: (1460325053504): Setting NW crash dump to: C:\Users\tpeti\AppData\Local\XDK
xdk:client:[2016-04-10T21:50:54.649Z]: (1460325054649): Intel XDK: 3088
xdk:client:[2016-04-10T21:50:54.649Z]: (1460325054649): Platform: win32-ia32 (6.3.9600)
xdk:client:[2016-04-10T21:50:54.649Z]: (1460325054649): System Info:  CPU: 8 X Intel(R) Core(TM) i7-4702MQ CPU @ 2.20GHz Physical Memory: 17054412800
xdk:client:[2016-04-10T21:50:54.650Z]: (1460325054650): NW: 0.11.7-rc10-dev
xdk:client:[2016-04-10T21:50:54.987Z]: (1460325054987): Created new theme: base
xdk:client:[2016-04-10T21:50:54.987Z]: (1460325054987): Registered new theme: base
xdk:client:[2016-04-10T21:50:54.989Z]: (1460325054989): Current theme is now: base
xdk:client:[2016-04-10T21:50:54.989Z]: (1460325054989): Loading theme from: ../../public/themes/xdk.json
xdk:client:[2016-04-10T21:50:54.990Z]: (1460325054990): Failed to load theme: xdk { [Error: Cannot find module '../../public/themes/xdk.json'] code: 'MODULE_NOT_FOUND' }
xdk:client:[2016-04-10T21:50:56.234Z]: (1460325056234): Starting client process initialization
xdk:client:[2016-04-10T21:50:56.273Z]: (1460325056273): NW Cache is up-to-date.
xdk:client:[2016-04-10T21:50:58.495Z]: (1460325058495): memmrk:    16414644    35318016
xdk:server:[2016-04-10T21:50:56.691Z]: (1460325056692): memlim: 767557632
xdk:server:[2016-04-10T21:50:56.696Z]: (1460325056696): Setting NW crash dump to: C:\Users\tpeti\AppData\Local\XDK
xdk:server:[2016-04-10T21:50:56.977Z]: (1460325056977): Starting server process initialization
xdk:server:[2016-04-10T21:50:57.862Z]: (1460325057862): Http server started on the standard port 58889
xdk:server:[2016-04-10T21:50:58.911Z]: (1460325058911): NW Cache is up-to-date.
xdk:server:[2016-04-10T21:50:59.533Z]: (1460325059533): Component "core:assert" starting import
xdk:client:[2016-04-10T21:51:03.495Z]: (1460325063495): memmrk:    16634504    35318016
xdk:server:[2016-04-10T21:50:59.533Z]: (1460325059533): Component "core:assert" finished initialization
xdk:server:[2016-04-10T21:50:59.534Z]: (1460325059534): Component "core:component-error" starting import
xdk:server:[2016-04-10T21:50:59.534Z]: (1460325059534): Component "core:component-error" finished initialization
xdk:server:[2016-04-10T21:50:59.534Z]: (1460325059534): Component "core:command-line-options" starting import
xdk:server:[2016-04-10T21:50:59.534Z]: (1460325059534): Component "core:command-line-options" finished initialization
xdk:server:[2016-04-10T21:50:59.534Z]: (1460325059534): Component "core:service-error" starting import
xdk:server:[2016-04-10T21:50:59.534Z]: (1460325059534): Component "core:service-error" finished initialization
xdk:server:[2016-04-10T21:50:59.534Z]: (1460325059534): Component "core:buffer" starting import
xdk:server:[2016-04-10T21:50:59.534Z]: (1460325059534): Component "core:buffer" finished initialization
xdk:server:[2016-04-10T21:50:59.534Z]: (1460325059534): Component "core:signaler" starting import
xdk:server:[2016-04-10T21:50:59.544Z]: (1460325059544): Component "core:signaler" finished initialization
xdk:server:[2016-04-10T21:50:59.544Z]: (1460325059544): Component "core:signaler-group" starting import
xdk:server:[2016-04-10T21:50:59.566Z]: (1460325059566): Component "core:signaler-group" finished initialization
xdk:server:[2016-04-10T21:50:59.566Z]: (1460325059567): Component "core:logger" starting import
xdk:server:[2016-04-10T21:50:59.573Z]: (1460325059573): Component "core:logger" finished initialization
xdk:server:[2016-04-10T21:50:59.573Z]: (1460325059573): Component "core:http-request" starting import
xdk:server:[2016-04-10T21:50:59.579Z]: (1460325059579): Component "core:http-request" finished initialization
xdk:server:[2016-04-10T21:50:59.579Z]: (1460325059579): Component "core:database" starting import
xdk:server:[2016-04-10T21:50:59.584Z]: (1460325059584): Component "core:database" finished initialization
xdk:server:[2016-04-10T21:50:59.584Z]: (1460325059584): Component "core:version" starting import
xdk:server:[2016-04-10T21:50:59.584Z]: (1460325059584): Component "core:version" finished initialization
xdk:server:[2016-04-10T21:50:59.584Z]: (1460325059584): Component "core:userfs-name-converter" starting import
xdk:server:[2016-04-10T21:50:59.591Z]: (1460325059591): Component "core:userfs-name-converter" finished initialization
xdk:server:[2016-04-10T21:50:59.591Z]: (1460325059591): Component "core:crash-handler" starting import
xdk:server:[2016-04-10T21:50:59.596Z]: (1460325059596): Component "core:crash-handler" finished initialization
xdk:server:[2016-04-10T21:50:59.596Z]: (1460325059596): Component "core:i18n-support" starting import
xdk:server:[2016-04-10T21:50:59.596Z]: (1460325059596): Component "core:i18n-support" finished initialization
xdk:server:[2016-04-10T21:50:59.596Z]: (1460325059596): Component "core:theme" starting import
xdk:server:[2016-04-10T21:50:59.642Z]: (1460325059642): Component "core:theme" finished initialization
xdk:server:[2016-04-10T21:50:59.643Z]: (1460325059643): Component "server:userfs" starting import
xdk:server:[2016-04-10T21:50:59.681Z]: (1460325059681): Component "server:userfs" calling init()
xdk:server:[2016-04-10T21:50:59.889Z]: (1460325059889): Component "server:userfs" finished initialization
xdk:server:[2016-04-10T21:50:59.890Z]: (1460325059890): Component "server:user-profile" starting import
xdk:server:[2016-04-10T21:50:59.900Z]: (1460325059900): Component "server:user-profile" calling init()
xdk:server:[2016-04-10T21:50:59.900Z]: (1460325059900): Component "server:user-profile" finished initialization
xdk:server:[2016-04-10T21:50:59.900Z]: (1460325059900): Component "server:ui-builder" starting import
xdk:server:[2016-04-10T21:51:00.383Z]: (1460325060383): Component "server:ui-builder" calling init()
xdk:server:[2016-04-10T21:51:00.385Z]: (1460325060385): Component "server:ui-builder" finished initialization
xdk:server:[2016-04-10T21:51:00.385Z]: (1460325060385): Component "server:emulator-notification" starting import
xdk:server:[2016-04-10T21:51:00.409Z]: (1460325060409): Component "server:emulator-notification" calling init()
xdk:server:[2016-04-10T21:51:00.410Z]: (1460325060410): Component "server:emulator-notification" finished initialization
xdk:server:[2016-04-10T21:51:00.410Z]: (1460325060410): Component "server:emulator-webserver" starting import
xdk:server:[2016-04-10T21:51:00.418Z]: (1460325060418): Component "server:emulator-webserver" calling init()
xdk:server:[2016-04-10T21:51:00.419Z]: (1460325060419): Component "server:emulator-webserver" finished initialization
xdk:server:[2016-04-10T21:51:00.419Z]: (1460325060419): Component "server:zip-util" starting import
xdk:server:[2016-04-10T21:51:00.431Z]: (1460325060431): Component "server:zip-util" calling init()
xdk:server:[2016-04-10T21:51:00.431Z]: (1460325060431): Component "server:zip-util" finished initialization
xdk:server:[2016-04-10T21:51:00.431Z]: (1460325060431): Component "server:uuid-server" starting import
xdk:server:[2016-04-10T21:51:00.442Z]: (1460325060442): Component "server:uuid-server" calling init()
xdk:server:[2016-04-10T21:51:00.442Z]: (1460325060442): Component "server:uuid-server" finished initialization
xdk:server:[2016-04-10T21:51:00.442Z]: (1460325060442): Component "server:force-download" starting import
xdk:server:[2016-04-10T21:51:00.451Z]: (1460325060451): Component "server:force-download" calling init()
xdk:server:[2016-04-10T21:51:00.451Z]: (1460325060451): Component "server:force-download" finished initialization
xdk:server:[2016-04-10T21:51:00.451Z]: (1460325060451): Component "server:updater" starting import
xdk:server:[2016-04-10T21:51:00.463Z]: (1460325060463): Component "server:updater" calling init()
server:updater:[2016-04-10T21:51:00.463Z]: (1460325060463): config.base-auto
server:updater:[2016-04-10T21:51:00.463Z]: (1460325060463): url=auto
xdk:server:[2016-04-10T21:51:00.464Z]: (1460325060464): Component "server:updater" finished initialization
xdk:server:[2016-04-10T21:51:00.464Z]: (1460325060464): Component "server:editor-node" starting import
xdk:server:[2016-04-10T21:51:00.758Z]: (1460325060758): Component "server:editor-node" calling init()
xdk:server:[2016-04-10T21:51:00.759Z]: (1460325060759): Component "server:editor-node" waiting for delayed initialization
xdk:server:[2016-04-10T21:51:00.759Z]: (1460325060759): Component "server:cordova-lib" starting import
xdk:server:[2016-04-10T21:51:04.624Z]: (1460325064624): Component "server:cordova-lib" calling init()
xdk:server:[2016-04-10T21:51:05.174Z]: (1460325065174): Component "server:cordova-lib" finished initialization
xdk:server:[2016-04-10T21:51:05.174Z]: (1460325065174): Component "server:api-explorer" starting import
xdk:server:[2016-04-10T21:51:05.200Z]: (1460325065200): Component "server:api-explorer" calling init()
xdk:server:[2016-04-10T21:51:05.565Z]: (1460325065565): Component "server:api-explorer" finished initialization
xdk:server:[2016-04-10T21:51:05.565Z]: (1460325065565): Component "server:plugin-listener" starting import
xdk:server:[2016-04-10T21:51:05.583Z]: (1460325065583): Component "server:plugin-listener" calling init()
xdk:server:[2016-04-10T21:51:05.583Z]: (1460325065583): Component "server:plugin-listener" finished initialization
xdk:server:[2016-04-10T21:51:05.583Z]: (1460325065583): Component "server:git-runner" starting import
xdk:server:[2016-04-10T21:51:05.598Z]: (1460325065598): Component "server:git-runner" calling init()
xdk:server:[2016-04-10T21:51:05.599Z]: (1460325065599): Component "server:git-runner" finished initialization
server:editor-node:[2016-04-10T21:51:05.600Z]: (1460325065600): Starting Brackets node process C:\Users\tpeti\AppData\Local\Intel\XDK\bin\node.exe C:\Users\tpeti\AppData\Local\Intel\XDK\bin\node-core
xdk:server:[2016-04-10T21:51:05.611Z]: (1460325065611): memmrk:    27303768    44434816
server:editor-node:[2016-04-10T21:51:05.802Z]: (1460325065802): Brackets node is running on port 56413
xdk:server:[2016-04-10T21:51:05.803Z]: (1460325065803): Component "server:editor-node" finished delayed initialization
xdk:server:[2016-04-10T21:51:05.803Z]: (1460325065803): Component "server:ui-builder" calling start()
xdk:server:[2016-04-10T21:51:05.807Z]: (1460325065807): Component "server:ui-builder" finished start()
xdk:server:[2016-04-10T21:51:05.807Z]: (1460325065807): Component "server:emulator-webserver" calling start()
xdk:server:[2016-04-10T21:51:05.807Z]: (1460325065807): Component "server:emulator-webserver" finished start()
xdk:server:[2016-04-10T21:51:05.808Z]: (1460325065808): Component "server:editor-node" calling start()
xdk:server:[2016-04-10T21:51:05.808Z]: (1460325065808): Component "server:editor-node" finished start()
xdk:server:[2016-04-10T21:51:05.809Z]: (1460325065809): Intel XDK is initialized now
xdk:server:[2016-04-10T21:51:05.810Z]: (1460325065810): Writing to the server data file
xdk:server:[2016-04-10T21:51:05.813Z]: (1460325065813): Wrote server data to "C:\Users\tpeti\AppData\Local\XDK\server-data.txt"
xdk:client:[2016-04-10T21:51:06.029Z]: (1460325066029): Successfully read server data file
xdk:client:[2016-04-10T21:51:06.329Z]: (1460325066329): Component "core:assert" starting import
xdk:client:[2016-04-10T21:51:06.329Z]: (1460325066329): Component "core:assert" finished initialization
xdk:client:[2016-04-10T21:51:06.329Z]: (1460325066329): Component "core:component-error" starting import
xdk:client:[2016-04-10T21:51:06.329Z]: (1460325066329): Component "core:component-error" finished initialization
xdk:client:[2016-04-10T21:51:06.329Z]: (1460325066329): Component "core:command-line-options" starting import
xdk:client:[2016-04-10T21:51:06.329Z]: (1460325066329): Component "core:command-line-options" finished initialization
xdk:client:[2016-04-10T21:51:06.329Z]: (1460325066329): Component "core:service-error" starting import
xdk:client:[2016-04-10T21:51:06.330Z]: (1460325066330): Component "core:service-error" finished initialization
xdk:client:[2016-04-10T21:51:06.330Z]: (1460325066330): Component "core:buffer" starting import
xdk:client:[2016-04-10T21:51:06.330Z]: (1460325066330): Component "core:buffer" finished initialization
xdk:client:[2016-04-10T21:51:06.330Z]: (1460325066330): Component "core:signaler" starting import
xdk:client:[2016-04-10T21:51:06.330Z]: (1460325066330): Component "core:signaler" finished initialization
xdk:client:[2016-04-10T21:51:06.330Z]: (1460325066330): Component "core:signaler-group" starting import
xdk:client:[2016-04-10T21:51:06.332Z]: (1460325066332): Component "core:signaler-group" finished initialization
xdk:client:[2016-04-10T21:51:06.332Z]: (1460325066332): Component "core:logger" starting import
xdk:client:[2016-04-10T21:51:06.333Z]: (1460325066333): Component "core:logger" finished initialization
xdk:client:[2016-04-10T21:51:06.333Z]: (1460325066333): Component "core:http-request" starting import
xdk:client:[2016-04-10T21:51:06.334Z]: (1460325066334): Component "core:http-request" finished initialization
xdk:client:[2016-04-10T21:51:06.334Z]: (1460325066334): Component "core:version" starting import
xdk:client:[2016-04-10T21:51:06.334Z]: (1460325066334): Component "core:version" finished initialization
xdk:client:[2016-04-10T21:51:06.334Z]: (1460325066334): Component "core:exit-notifier" starting import
xdk:client:[2016-04-10T21:51:06.334Z]: (1460325066334): Component "core:exit-notifier" finished initialization
xdk:client:[2016-04-10T21:51:06.334Z]: (1460325066334): Component "core:userfs-name-converter" starting import
xdk:client:[2016-04-10T21:51:06.335Z]: (1460325066335): Component "core:userfs-name-converter" finished initialization
xdk:client:[2016-04-10T21:51:06.335Z]: (1460325066335): Component "core:crash-handler" starting import
xdk:client:[2016-04-10T21:51:06.338Z]: (1460325066338): Component "core:crash-handler" finished initialization
xdk:client:[2016-04-10T21:51:06.338Z]: (1460325066338): Component "core:analytics" starting import
xdk:client:[2016-04-10T21:51:06.338Z]: (1460325066338): Component "core:analytics" finished initialization
xdk:client:[2016-04-10T21:51:06.338Z]: (1460325066338): Component "core:i18n-support" starting import
xdk:client:[2016-04-10T21:51:06.338Z]: (1460325066339): Component "core:i18n-support" finished initialization
xdk:client:[2016-04-10T21:51:06.339Z]: (1460325066339): Component "core:theme" starting import
xdk:client:[2016-04-10T21:51:06.339Z]: (1460325066339): Component "core:theme" finished initialization
xdk:client:[2016-04-10T21:51:06.346Z]: (1460325066346): Analytics ID: bb055c82-ff83-4620-a817-dcdc3127fb80
xdk:client:[2016-04-10T21:51:06.347Z]: (1460325066347): onExit listener 0:
    at Object.exports.onExit (C:\Users\tpeti\AppData\Local\Intel\XDK\xdk\core-modules\public\exit-notifier.js:17:2339)
    at setupDefaultAnalytics (C:\Users\tpeti\AppData\Local\Intel\XDK\xdk\core-modules\public\analytics.js:17:1438)
    at C:\Users\tpeti\AppData\Local\Intel\XDK\xdk\core-modules\public\analytics.js:17:6219
    at C:\Users\tpeti\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:1229:26
    at _fulfilled (C:\Users\tpeti\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:834:54)
    at self.promiseDispatch.done (C:\Users\tpeti\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:863:30)
    at Promise.promise.promiseDispatch (C:\Users\tpeti\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:796:13)
    at C:\Users\tpeti\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:604:44
    at runSingle (C:\Users\tpeti\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:137:13)
xdk:client:[2016-04-10T21:51:06.372Z]: (1460325066372): Component "client:app" starting import
xdk:client:[2016-04-10T21:51:06.373Z]: (1460325066373): Component "client:help-helper" starting import
xdk:client:[2016-04-10T21:51:06.373Z]: (1460325066373): Component "client:nativefs" starting import
xdk:client:[2016-04-10T21:51:06.373Z]: (1460325066373): Component "client:document-manager" starting import
xdk:client:[2016-04-10T21:51:06.373Z]: (1460325066373): Component "client:project-manager" starting import
xdk:client:[2016-04-10T21:51:06.373Z]: (1460325066373): Component "client:aa-controller" starting import
xdk:client:[2016-04-10T21:51:06.373Z]: (1460325066373): Component "client:build-validator" starting import
xdk:client:[2016-04-10T21:51:06.373Z]: (1460325066373): Component "client:projects-renderers" starting import
xdk:client:[2016-04-10T21:51:06.373Z]: (1460325066373): Component "client:projects-renderers-jsapp" starting import
xdk:client:[2016-04-10T21:51:06.373Z]: (1460325066373): Component "client:projects-renderers-webapp" starting import
xdk:client:[2016-04-10T21:51:06.373Z]: (1460325066373): Component "client:projects-renderers-iotapp" starting import
xdk:client:[2016-04-10T21:51:06.373Z]: (1460325066373): Component "client:active-sync" starting import
xdk:client:[2016-04-10T21:51:06.373Z]: (1460325066373): Component "client:apk-installer" starting import
xdk:client:[2016-04-10T21:51:06.373Z]: (1460325066373): Component "client:appcenter-options" starting import
xdk:client:[2016-04-10T21:51:06.373Z]: (1460325066373): Component "client:resource-manager" starting import
xdk:client:[2016-04-10T21:51:06.373Z]: (1460325066373): Component "client:resource-cocos2d" starting import
xdk:client:[2016-04-10T21:51:06.373Z]: (1460325066373): Component "client:resource-cocos2djs" starting import
xdk:client:[2016-04-10T21:51:06.373Z]: (1460325066373): Component "client:resource-phaser" starting import
xdk:client:[2016-04-10T21:51:06.373Z]: (1460325066373): Component "client:resource-pixi" starting import
xdk:client:[2016-04-10T21:51:06.373Z]: (1460325066373): Component "client:resource-easeljs" starting import
xdk:client:[2016-04-10T21:51:06.373Z]: (1460325066373): Component "client:resource-plain" starting import
xdk:client:[2016-04-10T21:51:06.373Z]: (1460325066373): Component "client:resource-render-frame" starting import
xdk:client:[2016-04-10T21:51:06.373Z]: (1460325066373): Component "client:resource-util" starting import
xdk:client:[2016-04-10T21:51:06.373Z]: (1460325066373): Component "client:bower-package-manager" starting import
xdk:client:[2016-04-10T21:51:06.373Z]: (1460325066373): Component "client:services-tab" starting import
xdk:client:[2016-04-10T21:51:06.373Z]: (1460325066373): Component "client:editor" starting import
xdk:client:[2016-04-10T21:51:06.373Z]: (1460325066373): Component "client:live-preview" starting import
xdk:client:[2016-04-10T21:51:06.373Z]: (1460325066373): Component "client:backend-services" starting import
xdk:client:[2016-04-10T21:51:06.373Z]: (1460325066373): Component "client:backend-feeds" starting import
xdk:client:[2016-04-10T21:51:06.373Z]: (1460325066373): Component "client:merged-feed" starting import
xdk:client:[2016-04-10T21:51:06.373Z]: (1460325066373): Component "client:backend-services-ext" starting import
xdk:client:[2016-04-10T21:51:06.373Z]: (1460325066373): Component "client:backend-service-utils" starting import
xdk:client:[2016-04-10T21:51:06.373Z]: (1460325066373): Component "client:cert-manager" starting import
xdk:client:[2016-04-10T21:51:06.373Z]: (1460325066373): Component "client:account-settings" starting import
xdk:client:[2016-04-10T21:51:06.373Z]: (1460325066373): Component "client:ui-builder-client" starting import
xdk:client:[2016-04-10T21:51:06.373Z]: (1460325066373): Component "client:project-meta" starting import
xdk:client:[2016-04-10T21:51:06.373Z]: (1460325066373): Component "client:contenttype-registry" starting import
xdk:client:[2016-04-10T21:51:06.373Z]: (1460325066373): Component "client:editor-registry" starting import
xdk:client:[2016-04-10T21:51:06.373Z]: (1460325066373): Component "client:platform-registry" starting import
xdk:client:[2016-04-10T21:51:06.373Z]: (1460325066373): Component "client:projecttype-registry" starting import
xdk:client:[2016-04-10T21:51:06.373Z]: (1460325066373): Component "client:library-registry" starting import
xdk:client:[2016-04-10T21:51:06.373Z]: (1460325066373): Component "client:cordova-registry" starting import
xdk:client:[2016-04-10T21:51:06.373Z]: (1460325066373): Component "client:service-method" starting import
xdk:client:[2016-04-10T21:51:06.373Z]: (1460325066373): Component "client:settings-db" starting import
xdk:client:[2016-04-10T21:51:06.373Z]: (1460325066373): Component "client:adb" starting import
xdk:client:[2016-04-10T21:51:06.373Z]: (1460325066373): Component "client:iosdb" starting import
xdk:client:[2016-04-10T21:51:06.373Z]: (1460325066373): Component "client:device" starting import
xdk:client:[2016-04-10T21:51:06.373Z]: (1460325066373): Component "client:device-discovery" starting import
xdk:client:[2016-04-10T21:51:06.373Z]: (1460325066373): Component "client:dialog-box" starting import
xdk:client:[2016-04-10T21:51:06.373Z]: (1460325066373): Component "client:test-local-server" starting import
xdk:client:[2016-04-10T21:51:06.373Z]: (1460325066373): Component "client:quick-tour" starting import
xdk:client:[2016-04-10T21:51:06.373Z]: (1460325066373): Component "client:hot-keys" starting import
xdk:client:[2016-04-10T21:51:06.373Z]: (1460325066373): Component "client:persistance" starting import
xdk:client:[2016-04-10T21:51:06.375Z]: (1460325066375): Component "client:tabs" starting import
xdk:client:[2016-04-10T21:51:06.375Z]: (1460325066375): Component "client:hash-utils" starting import
xdk:client:[2016-04-10T21:51:06.375Z]: (1460325066375): Component "client:file-watcher" starting import
xdk:client:[2016-04-10T21:51:06.375Z]: (1460325066375): Component "client:tool-tip" starting import
xdk:client:[2016-04-10T21:51:06.375Z]: (1460325066375): Component "client:cordova" starting import
xdk:client:[2016-04-10T21:51:06.375Z]: (1460325066375): Component "client:settings-ui" starting import
xdk:client:[2016-04-10T21:51:06.375Z]: (1460325066375): Component "client:external-links" starting import
xdk:client:[2016-04-10T21:51:06.375Z]: (1460325066375): Component "client:external-editors-runner" starting import
xdk:client:[2016-04-10T21:51:06.375Z]: (1460325066375): Component "client:project-list-load" starting import
xdk:client:[2016-04-10T21:51:06.375Z]: (1460325066375): Component "client:upload-manager" starting import
xdk:client:[2016-04-10T21:51:06.375Z]: (1460325066375): Component "client:git-manager" starting import
xdk:client:[2016-04-10T21:51:06.375Z]: (1460325066375): Component "client:new-project-creator" starting import
xdk:client:[2016-04-10T21:51:06.464Z]: (1460325066464): Component "client:help-helper" finished initialization
xdk:client:[2016-04-10T21:51:06.479Z]: (1460325066479): Component "client:nativefs" finished initialization
xdk:client:[2016-04-10T21:51:06.619Z]: (1460325066619): Component "client:apk-installer" calling init()
xdk:client:[2016-04-10T21:51:06.619Z]: (1460325066619): Component "client:apk-installer" finished initialization
xdk:client:[2016-04-10T21:51:06.623Z]: (1460325066623): Component "client:active-sync" calling init()
xdk:client:[2016-04-10T21:51:06.623Z]: (1460325066623): Component "client:active-sync" finished initialization
xdk:client:[2016-04-10T21:51:06.718Z]: (1460325066718): Component "client:resource-render-frame" calling init()
xdk:client:[2016-04-10T21:51:06.719Z]: (1460325066719): Component "client:resource-render-frame" waiting for delayed initialization
xdk:client:[2016-04-10T21:51:06.720Z]: (1460325066720): Component "client:resource-util" calling init()
xdk:client:[2016-04-10T21:51:06.720Z]: (1460325066720): Component "client:resource-util" finished initialization
xdk:client:[2016-04-10T21:51:06.721Z]: (1460325066721): Component "client:resource-render-frame" finished delayed initialization
xdk:client:[2016-04-10T21:51:06.790Z]: (1460325066790): Component "client:backend-services" calling init()
xdk:client:[2016-04-10T21:51:06.791Z]: (1460325066791): Component "client:backend-services" finished initialization
xdk:client:[2016-04-10T21:51:06.792Z]: (1460325066792): Component "client:backend-feeds" calling init()
xdk:client:[2016-04-10T21:51:06.793Z]: (1460325066793): Component "client:backend-feeds" finished initialization
xdk:client:[2016-04-10T21:51:06.797Z]: (1460325066797): Component "client:backend-services-ext" calling init()
xdk:client:[2016-04-10T21:51:06.797Z]: (1460325066797): Component "client:backend-services-ext" finished initialization
xdk:client:[2016-04-10T21:51:06.800Z]: (1460325066800): Component "client:backend-service-utils" finished initialization
xdk:client:[2016-04-10T21:51:06.815Z]: (1460325066815): Component "client:merged-feed" finished initialization
xdk:client:[2016-04-10T21:51:06.868Z]: (1460325066868): Component "client:project-meta" calling init()
xdk:client:[2016-04-10T21:51:06.868Z]: (1460325066868): Component "client:project-meta" finished initialization
xdk:client:[2016-04-10T21:51:06.954Z]: (1460325066954): Component "client:service-method" finished initialization
xdk:client:[2016-04-10T21:51:06.978Z]: (1460325066978): Component "client:settings-db" calling init()
xdk:client:[2016-04-10T21:51:06.979Z]: (1460325066979): Component "client:settings-db" waiting for delayed initialization
xdk:client:[2016-04-10T21:51:07.003Z]: (1460325067003): Component "client:adb" calling init()
xdk:client:[2016-04-10T21:51:07.013Z]: (1460325067013): Component "client:adb" waiting for delayed initialization
xdk:client:[2016-04-10T21:51:07.015Z]: (1460325067015): Component "client:iosdb" calling init()
xdk:client:[2016-04-10T21:51:07.015Z]: (1460325067015): Component "client:iosdb" finished initialization
xdk:client:[2016-04-10T21:51:07.083Z]: (1460325067083): Component "client:persistance" calling init()
xdk:client:[2016-04-10T21:51:07.083Z]: (1460325067083): Component "client:persistance" waiting for delayed initialization
xdk:client:[2016-04-10T21:51:07.101Z]: (1460325067101): Component "client:file-watcher" calling init()
xdk:client:[2016-04-10T21:51:07.101Z]: (1460325067101): Component "client:file-watcher" finished initialization
xdk:client:[2016-04-10T21:51:07.128Z]: (1460325067128): Component "client:external-links" finished initialization
xdk:client:[2016-04-10T21:51:07.155Z]: (1460325067155): Component "client:project-list-load" calling init()
xdk:client:[2016-04-10T21:51:07.155Z]: (1460325067155): Component "client:project-list-load" waiting for delayed initialization
xdk:client:[2016-04-10T21:51:07.161Z]: (1460325067161): Component "client:git-manager" calling init()
client:git-manager:[2016-04-10T21:51:07.161Z]: (1460325067161): git path =  C:\Users\tpeti\AppData\Local\Intel\XDK\bin\git\bin\git.exe
xdk:client:[2016-04-10T21:51:07.161Z]: (1460325067161): Component "client:git-manager" waiting for delayed initialization
xdk:client:[2016-04-10T21:51:07.173Z]: (1460325067173): Component "client:external-editors-runner" calling init()
xdk:client:[2016-04-10T21:51:07.173Z]: (1460325067173): Component "client:external-editors-runner" finished initialization
xdk:client:[2016-04-10T21:51:07.185Z]: (1460325067185): Component "client:new-project-creator" calling init()
xdk:client:[2016-04-10T21:51:07.185Z]: (1460325067185): Component "client:new-project-creator" finished initialization
xdk:client:[2016-04-10T21:51:07.224Z]: (1460325067224): Component "client:hot-keys" calling init()
xdk:client:[2016-04-10T21:51:07.224Z]: (1460325067225): Component "client:hot-keys" finished initialization
xdk:client:[2016-04-10T21:51:07.232Z]: (1460325067232): Component "client:upload-manager" calling init()
xdk:client:[2016-04-10T21:51:07.232Z]: (1460325067232): Component "client:upload-manager" finished initialization
xdk:client:[2016-04-10T21:51:07.314Z]: (1460325067314): Component "client:test-local-server" calling init()
xdk:client:[2016-04-10T21:51:07.337Z]: (1460325067337): Component "client:test-local-server" finished initialization
xdk:client:[2016-04-10T21:51:08.382Z]: (1460325068382): Component "client:cert-manager" finished initialization
client:adb:[2016-04-10T21:51:08.386Z]: (1460325068386): Using existing adb at "C:\Users\tpeti\AppData\Local\Intel\XDK\bin\adb\adb.exe"
xdk:client:[2016-04-10T21:51:08.393Z]: (1460325068393): Component "client:build-validator" finished initialization
xdk:client:[2016-04-10T21:51:08.394Z]: (1460325068394): Component "client:appcenter-options" calling init()
xdk:client:[2016-04-10T21:51:08.394Z]: (1460325068394): Component "client:appcenter-options" waiting for delayed initialization
xdk:client:[2016-04-10T21:51:08.401Z]: (1460325068401): Component "client:ui-builder-client" calling init()
xdk:client:[2016-04-10T21:51:08.401Z]: (1460325068401): Component "client:ui-builder-client" finished initialization
xdk:client:[2016-04-10T21:51:08.404Z]: (1460325068404): Component "client:tabs" finished initialization
xdk:client:[2016-04-10T21:51:08.404Z]: (1460325068404): Component "client:tool-tip" finished initialization
xdk:client:[2016-04-10T21:51:08.408Z]: (1460325068408): Component "client:app" calling init()
xdk:client:[2016-04-10T21:51:08.419Z]: (1460325068419): Component "client:app" finished initialization
xdk:client:[2016-04-10T21:51:08.419Z]: (1460325068419): Component "client:settings-ui" finished initialization
xdk:client:[2016-04-10T21:51:08.420Z]: (1460325068420): Component "client:navbar" starting import
xdk:client:[2016-04-10T21:51:08.420Z]: (1460325068420): Component "client:tweets" starting import
xdk:client:[2016-04-10T21:51:08.420Z]: (1460325068420): Component "client:projects-tab" starting import
xdk:client:[2016-04-10T21:51:08.420Z]: (1460325068420): Component "client:test-tab" starting import
xdk:client:[2016-04-10T21:51:08.420Z]: (1460325068420): Component "client:profilingTab" starting import
xdk:client:[2016-04-10T21:51:08.420Z]: (1460325068420): Component "client:emulator" starting import
xdk:client:[2016-04-10T21:51:08.420Z]: (1460325068420): Component "client:remote-tab" starting import
xdk:client:[2016-04-10T21:51:08.420Z]: (1460325068420): Component "client:build-tab" starting import
xdk:client:[2016-04-10T21:51:08.420Z]: (1460325068420): Component "client:build-service" starting import
xdk:client:[2016-04-10T21:51:08.420Z]: (1460325068420): Component "client:bower-client" starting import
xdk:client:[2016-04-10T21:51:08.420Z]: (1460325068420): Component "client:editor-tab" starting import
xdk:client:[2016-04-10T21:51:08.420Z]: (1460325068420): Component "client:account" starting import
xdk:client:[2016-04-10T21:51:08.420Z]: (1460325068420): Component "client:project-selector" starting import
xdk:client:[2016-04-10T21:51:08.420Z]: (1460325068420): Component "client:publish-tab" starting import
xdk:client:[2016-04-10T21:51:08.421Z]: (1460325068421): Component "client:adb" finished delayed initialization
xdk:client:[2016-04-10T21:51:08.425Z]: (1460325068425): Component "client:dialog-box" finished initialization
xdk:client:[2016-04-10T21:51:08.429Z]: (1460325068429): Component "client:document-manager" calling init()
xdk:client:[2016-04-10T21:51:08.429Z]: (1460325068429): Component "client:document-manager" finished initialization
xdk:client:[2016-04-10T21:51:08.435Z]: (1460325068435): Component "client:aa-controller" calling init()
xdk:client:[2016-04-10T21:51:08.435Z]: (1460325068435): Component "client:aa-controller" finished initialization
xdk:client:[2016-04-10T21:51:08.474Z]: (1460325068474): Component "client:services-tab" calling init()
xdk:client:[2016-04-10T21:51:08.474Z]: (1460325068474): Component "client:services-tab" finished initialization
xdk:client:[2016-04-10T21:51:08.480Z]: (1460325068480): Component "client:contenttype-registry" calling init()
xdk:client:[2016-04-10T21:51:08.480Z]: (1460325068480): Component "client:contenttype-registry" finished initialization
xdk:client:[2016-04-10T21:51:08.481Z]: (1460325068481): Component "client:editor-registry" finished initialization
xdk:client:[2016-04-10T21:51:08.483Z]: (1460325068483): Component "client:library-registry" calling init()
xdk:client:[2016-04-10T21:51:08.483Z]: (1460325068483): Component "client:library-registry" finished initialization
xdk:client:[2016-04-10T21:51:08.492Z]: (1460325068492): Component "client:device-discovery" calling init()
xdk:client:[2016-04-10T21:51:08.492Z]: (1460325068492): Component "client:device-discovery" waiting for delayed initialization
xdk:client:[2016-04-10T21:51:08.677Z]: (1460325068677): Component "client:cordova" calling init()
xdk:client:[2016-04-10T21:51:08.677Z]: (1460325068677): Component "client:cordova" waiting for delayed initialization
xdk:client:[2016-04-10T21:51:08.682Z]: (1460325068682): Component "client:quick-tour" calling init()
xdk:client:[2016-04-10T21:51:08.682Z]: (1460325068682): Component "client:quick-tour" finished initialization
xdk:client:[2016-04-10T21:51:08.683Z]: (1460325068683): Component "client:hash-utils" finished initialization
xdk:client:[2016-04-10T21:51:08.701Z]: (1460325068701): memmrk:    24933140    42403456
xdk:client:[2016-04-10T21:51:08.710Z]: (1460325068710): Component "client:project-manager" calling init()
xdk:client:[2016-04-10T21:51:08.710Z]: (1460325068710): Component "client:project-manager" waiting for delayed initialization
xdk:client:[2016-04-10T21:51:08.713Z]: (1460325068713): Component "client:projects-renderers" calling init()
xdk:client:[2016-04-10T21:51:08.713Z]: (1460325068713): Component "client:projects-renderers" waiting for delayed initialization
xdk:client:[2016-04-10T21:51:08.713Z]: (1460325068713): Component "client:projects-renderers-iotapp" calling init()
xdk:client:[2016-04-10T21:51:08.713Z]: (1460325068713): Component "client:projects-renderers-iotapp" finished initialization
xdk:client:[2016-04-10T21:51:08.723Z]: (1460325068723): Component "client:settings-db" finished delayed initialization
client:git-manager:[2016-04-10T21:51:08.735Z]: (1460325068735): Custom Git Client Path is C:\Users\tpeti\AppData\Local\Intel\XDK\bin\git\bin\git.exe
client:git-manager:[2016-04-10T21:51:08.736Z]: (1460325068736): Auto-Proxy setting is true
xdk:client:[2016-04-10T21:51:08.763Z]: (1460325068763): Component "client:git-manager" finished delayed initialization
xdk:client:[2016-04-10T21:51:08.773Z]: (1460325068773): Component "client:cordova" finished delayed initialization
xdk:client:[2016-04-10T21:51:08.779Z]: (1460325068779): Component "client:resource-manager" calling init()
xdk:client:[2016-04-10T21:51:08.779Z]: (1460325068779): Component "client:resource-manager" waiting for delayed initialization
xdk:client:[2016-04-10T21:51:08.825Z]: (1460325068825): Component "client:resource-cocos2d" calling init()
xdk:client:[2016-04-10T21:51:08.825Z]: (1460325068825): Component "client:resource-cocos2d" waiting for delayed initialization
xdk:client:[2016-04-10T21:51:08.827Z]: (1460325068827): Component "client:resource-cocos2d" finished delayed initialization
xdk:client:[2016-04-10T21:51:08.839Z]: (1460325068839): Component "client:resource-cocos2djs" calling init()
xdk:client:[2016-04-10T21:51:08.839Z]: (1460325068839): Component "client:resource-cocos2djs" finished initialization
xdk:client:[2016-04-10T21:51:08.878Z]: (1460325068878): Component "client:resource-easeljs" calling init()
xdk:client:[2016-04-10T21:51:08.878Z]: (1460325068878): Component "client:resource-easeljs" finished initialization
xdk:client:[2016-04-10T21:51:08.890Z]: (1460325068890): Component "client:resource-phaser" calling init()
xdk:client:[2016-04-10T21:51:08.890Z]: (1460325068890): Component "client:resource-phaser" finished initialization
xdk:client:[2016-04-10T21:51:08.897Z]: (1460325068897): Component "client:resource-pixi" calling init()
xdk:client:[2016-04-10T21:51:08.897Z]: (1460325068897): Component "client:resource-pixi" finished initialization
xdk:client:[2016-04-10T21:51:08.905Z]: (1460325068905): Component "client:resource-plain" calling init()
xdk:client:[2016-04-10T21:51:08.905Z]: (1460325068905): Component "client:resource-plain" finished initialization
xdk:client:[2016-04-10T21:51:09.035Z]: (1460325069035): Component "client:account-settings" calling init()
xdk:client:[2016-04-10T21:51:09.035Z]: (1460325069035): Component "client:account-settings" finished initialization
xdk:client:[2016-04-10T21:51:09.103Z]: (1460325069103): Component "client:platform-registry" calling init()
xdk:client:[2016-04-10T21:51:09.104Z]: (1460325069104): Component "client:platform-registry" finished initialization
xdk:client:[2016-04-10T21:51:09.151Z]: (1460325069151): Component "client:projecttype-registry" calling init()
xdk:client:[2016-04-10T21:51:09.152Z]: (1460325069152): Component "client:projecttype-registry" finished initialization
xdk:client:[2016-04-10T21:51:09.156Z]: (1460325069156): Component "client:device" calling init()
xdk:client:[2016-04-10T21:51:09.835Z]: (1460325069835): Component "client:device" finished initialization
xdk:client:[2016-04-10T21:51:09.835Z]: (1460325069835): Component "client:device-discovery" finished delayed initialization
xdk:client:[2016-04-10T21:51:09.837Z]: (1460325069837): Component "client:cordova-registry" calling init()
xdk:client:[2016-04-10T21:51:09.837Z]: (1460325069837): Component "client:cordova-registry" waiting for delayed initialization
xdk:client:[2016-04-10T21:51:09.854Z]: (1460325069854): Component "client:bower-package-manager" calling init()
xdk:client:[2016-04-10T21:51:09.855Z]: (1460325069855): Component "client:bower-package-manager" waiting for delayed initialization
xdk:client:[2016-04-10T21:51:09.855Z]: (1460325069855): Component "client:bower-package-manager" finished delayed initialization
xdk:client:[2016-04-10T21:51:09.866Z]: (1460325069866): Component "client:build-service" getting UI region for "build"
xdk:client:[2016-04-10T21:51:09.867Z]: (1460325069867): Component "client:build-service" calling init()
xdk:client:[2016-04-10T21:51:09.867Z]: (1460325069867): Component "client:build-service" finished initialization
xdk:client:[2016-04-10T21:51:09.889Z]: (1460325069889): Component "client:projects-renderers-webapp" calling init()
xdk:client:[2016-04-10T21:51:09.889Z]: (1460325069889): Component "client:projects-renderers-webapp" finished initialization
xdk:client:[2016-04-10T21:51:09.894Z]: (1460325069894): Component "client:projects-renderers-jsapp" calling init()
xdk:client:[2016-04-10T21:51:09.894Z]: (1460325069894): Component "client:projects-renderers-jsapp" finished initialization
xdk:client:[2016-04-10T21:51:09.900Z]: (1460325069900): Component "client:projects-renderers" finished delayed initialization
xdk:client:[2016-04-10T21:51:10.023Z]: (1460325070023): Component "client:projects-tab" getting UI region for "project"
xdk:client:[2016-04-10T21:51:10.024Z]: (1460325070024): Component "client:projects-tab" calling init()
xdk:client:[2016-04-10T21:51:10.024Z]: (1460325070024): Component "client:projects-tab" waiting for delayed initialization
xdk:client:[2016-04-10T21:51:10.026Z]: (1460325070026): Component "client:tweets" finished initialization
xdk:client:[2016-04-10T21:51:10.031Z]: (1460325070031): Component "client:navbar" getting UI region for "navbar-common"
xdk:client:[2016-04-10T21:51:10.031Z]: (1460325070031): Component "client:navbar" calling init()
client:navbar:[2016-04-10T21:51:10.032Z]: (1460325070032): navbar options: {"common":{"servicesVersion":"release-2016-ww11"},"updatePollingInterval":1800,"forceUpdate":false}
xdk:client:[2016-04-10T21:51:10.032Z]: (1460325070032): Component "client:navbar" finished initialization
xdk:client:[2016-04-10T21:51:10.064Z]: (1460325070064): Component "client:test-tab" getting UI region for "test"
xdk:client:[2016-04-10T21:51:10.064Z]: (1460325070064): Component "client:test-tab" calling init()
xdk:client:[2016-04-10T21:51:10.064Z]: (1460325070064): Component "client:test-tab" waiting for delayed initialization
xdk:client:[2016-04-10T21:51:10.119Z]: (1460325070119): Component "client:emulator" getting UI region for "emulate"
xdk:client:[2016-04-10T21:51:10.119Z]: (1460325070119): Component "client:emulator" calling init()
xdk:client:[2016-04-10T21:51:10.121Z]: (1460325070121): Component "client:emulator" finished initialization
xdk:client:[2016-04-10T21:51:10.229Z]: (1460325070229): Component "client:account" getting UI region for "account"
xdk:client:[2016-04-10T21:51:10.229Z]: (1460325070229): Component "client:account" calling init()
xdk:client:[2016-04-10T21:51:10.232Z]: (1460325070232): Component "client:account" finished initialization
xdk:client:[2016-04-10T21:51:10.291Z]: (1460325070291): Component "client:project-selector" getting UI region for "project-selector"
xdk:client:[2016-04-10T21:51:10.291Z]: (1460325070291): Component "client:project-selector" calling init()
xdk:client:[2016-04-10T21:51:10.291Z]: (1460325070291): Component "client:project-selector" finished initialization
xdk:client:[2016-04-10T21:51:10.347Z]: (1460325070347): Component "client:remote-tab" getting UI region for "debug"
xdk:server:[2016-04-10T21:51:10.611Z]: (1460325070611): memmrk:    29525500    44434816
xdk:client:[2016-04-10T21:51:10.347Z]: (1460325070347): Component "client:remote-tab" calling init()
xdk:client:[2016-04-10T21:51:11.020Z]: (1460325071020): Component "client:remote-tab" waiting for delayed initialization
xdk:client:[2016-04-10T21:51:11.021Z]: (1460325071021): Component "client:remote-tab" finished delayed initialization
xdk:client:[2016-04-10T21:51:11.032Z]: (1460325071032): Component "client:editor" calling init()
xdk:client:[2016-04-10T21:51:11.032Z]: (1460325071032): Component "client:editor" finished initialization
xdk:client:[2016-04-10T21:51:11.032Z]: (1460325071032): Component "client:live-preview" calling init()
xdk:client:[2016-04-10T21:51:11.032Z]: (1460325071032): Component "client:live-preview" finished initialization
xdk:client:[2016-04-10T21:51:11.032Z]: (1460325071032): Component "client:editor-tab" getting UI region for "develop"
xdk:client:[2016-04-10T21:51:11.032Z]: (1460325071033): Component "client:editor-tab" calling init()
xdk:client:[2016-04-10T21:51:11.040Z]: (1460325071040): Component "client:editor-tab" waiting for delayed initialization
client:appcenter-options:[2016-04-10T21:51:11.048Z]: (1460325071048): Fetch Status: 1, Message: Feched latest appcenter-options info because network is available.
xdk:client:[2016-04-10T21:51:11.049Z]: (1460325071049): Component "client:appcenter-options" finished delayed initialization
xdk:client:[2016-04-10T21:51:11.050Z]: (1460325071050): Component "client:test-tab" finished delayed initialization
xdk:client:[2016-04-10T21:51:11.054Z]: (1460325071054): Component "client:cordova-registry" finished delayed initialization
xdk:client:[2016-04-10T21:51:11.090Z]: (1460325071090): Component "client:build-tab" getting UI region for "build"
xdk:client:[2016-04-10T21:51:11.090Z]: (1460325071090): Component "client:build-tab" calling init()
xdk:client:[2016-04-10T21:51:11.094Z]: (1460325071094): Component "client:build-tab" waiting for delayed initialization
xdk:client:[2016-04-10T21:51:11.097Z]: (1460325071097): Component "client:publish-tab" getting UI region for "publish"
xdk:client:[2016-04-10T21:51:11.097Z]: (1460325071097): Component "client:publish-tab" calling init()
xdk:client:[2016-04-10T21:51:11.102Z]: (1460325071102): Component "client:build-tab" finished delayed initialization
xdk:client:[2016-04-10T21:51:11.104Z]: (1460325071104): Component "client:publish-tab" finished initialization
xdk:client:[2016-04-10T21:51:11.271Z]: (1460325071271): Component "client:bower-client" getting UI region for "deps-manager"
xdk:client:[2016-04-10T21:51:11.271Z]: (1460325071271): Component "client:bower-client" calling init()
xdk:client:[2016-04-10T21:51:11.272Z]: (1460325071272): Component "client:bower-client" finished initialization
xdk:client:[2016-04-10T21:51:11.379Z]: (1460325071379): Component "client:profilingTab" getting UI region for "profile"
xdk:client:[2016-04-10T21:51:11.380Z]: (1460325071380): Component "client:profilingTab" calling init()
xdk:client:[2016-04-10T21:51:11.381Z]: (1460325071381): Component "client:profilingTab" finished initialization
xdk:client:[2016-04-10T21:51:13.477Z]: (1460325073477): Component "client:persistance" finished delayed initialization
xdk:client:[2016-04-10T21:51:13.736Z]: (1460325073736): Component "client:project-manager" finished delayed initialization
xdk:client:[2016-04-10T21:51:13.737Z]: (1460325073737): Component "client:project-list-load" finished delayed initialization
xdk:client:[2016-04-10T21:51:13.742Z]: (1460325073742): Component "client:resource-manager" finished delayed initialization
xdk:client:[2016-04-10T21:51:13.742Z]: (1460325073742): Component "client:projects-tab" finished delayed initialization
xdk:client:[2016-04-10T21:51:13.742Z]: (1460325073742): Component "client:projects-list" starting import
xdk:client:[2016-04-10T21:51:13.742Z]: (1460325073742): Component "client:projects-info" starting import
xdk:client:[2016-04-10T21:51:13.742Z]: (1460325073742): Component "client:projects-create-list" starting import
xdk:client:[2016-04-10T21:51:13.742Z]: (1460325073742): Component "client:projects-create-info" starting import
xdk:client:[2016-04-10T21:51:14.045Z]: (1460325074045): memmrk:    36849028    50586496
xdk:client:[2016-04-10T21:51:14.125Z]: (1460325074125): Component "client:projects-list" getting UI region for "existing-list"
xdk:client:[2016-04-10T21:51:14.125Z]: (1460325074125): Component "client:projects-list" calling init()
xdk:client:[2016-04-10T21:51:14.127Z]: (1460325074127): Component "client:projects-list" finished initialization
xdk:client:[2016-04-10T21:51:14.140Z]: (1460325074140): Component "client:projects-info" getting UI region for "existing-info"
xdk:client:[2016-04-10T21:51:14.140Z]: (1460325074140): Component "client:projects-info" calling init()
xdk:client:[2016-04-10T21:51:14.141Z]: (1460325074141): Component "client:projects-info" finished initialization
xdk:client:[2016-04-10T21:51:14.206Z]: (1460325074206): Component "client:projects-create-list" getting UI region for "create-list"
xdk:client:[2016-04-10T21:51:14.206Z]: (1460325074206): Component "client:projects-create-list" calling init()
xdk:client:[2016-04-10T21:51:14.207Z]: (1460325074207): Component "client:projects-create-list" finished initialization
xdk:client:[2016-04-10T21:51:14.227Z]: (1460325074227): Component "client:projects-create-info" getting UI region for "create-info"
xdk:client:[2016-04-10T21:51:14.227Z]: (1460325074227): Component "client:projects-create-info" calling init()
xdk:client:[2016-04-10T21:51:14.227Z]: (1460325074227): Component "client:projects-create-info" finished initialization
xdk:server:[2016-04-10T21:51:15.612Z]: (1460325075612): memmrk:    21769144    44434816
xdk:client:[2016-04-10T21:51:19.046Z]: (1460325079046): memmrk:    45314296    63766016
xdk:server:[2016-04-10T21:51:20.612Z]: (1460325080612): memmrk:    19617408    25671296
xdk:client:[2016-04-10T21:51:20.706Z]: (1460325080706): onExitRequest listener 1:
    at Object.exports.onExitRequest (C:\Users\tpeti\AppData\Local\Intel\XDK\xdk\core-modules\public\exit-notifier.js:17:2170)
    at Object.<anonymous> (file:///C:/Users/tpeti/AppData/Local/Intel/XDK/xdk/brackets/b/extensions/default/XDK/main.js:459:21)
    at Object.context.execCb (file:///C:/Users/tpeti/AppData/Local/Intel/XDK/xdk/brackets/b/thirdparty/requirejs/require.js:1658:33)
    at Object.Module.check (file:///C:/Users/tpeti/AppData/Local/Intel/XDK/xdk/brackets/b/thirdparty/requirejs/require.js:869:55)
    at Object.<anonymous> (file:///C:/Users/tpeti/AppData/Local/Intel/XDK/xdk/brackets/b/thirdparty/requirejs/require.js:1121:34)
    at file:///C:/Users/tpeti/AppData/Local/Intel/XDK/xdk/brackets/b/thirdparty/requirejs/require.js:132:23
    at file:///C:/Users/tpeti/AppData/Local/Intel/XDK/xdk/brackets/b/thirdparty/requirejs/require.js:1164:21
    at each (file:///C:/Users/tpeti/AppData/Local/Intel/XDK/xdk/brackets/b/thirdparty/requirejs/require.js:57:31)
    at Object.Module.emit (file:///C:/Users/tpeti/AppData/Local/Intel/XDK/xdk/brackets/b/thirdparty/requirejs/require.js:1163:17)
client:services-tab:[2016-04-10T21:51:23.394Z]: (1460325083395): component:services-tab : Container provided by brackets :
client:services-tab:[2016-04-10T21:51:23.395Z]: (1460325083395): component:services-tab : mainContainer_ = XDKMiniServices-main
client:services-tab:[2016-04-10T21:51:23.395Z]: (1460325083395): component:services-tab : sidebarContainer = XDKMiniServices-list
client:services-tab:[2016-04-10T21:51:23.395Z]: (1460325083395): component:services-tab : Iframes inserted by services-tab : .
client:services-tab:[2016-04-10T21:51:23.395Z]: (1460325083395): component:services-tab : $mainContainer_ = mini-api-explorer
client:services-tab:[2016-04-10T21:51:23.395Z]: (1460325083395): component:services-tab : $sidebarContainer_ = api-sidebar
xdk:client:[2016-04-10T21:51:23.501Z]: (1460325083501): Component "client:editor-tab" finished delayed initialization
xdk:client:[2016-04-10T21:51:23.502Z]: (1460325083502): Component "client:app" calling start()
xdk:client:[2016-04-10T21:51:23.515Z]: (1460325083515): Component "client:app" finished start()
xdk:client:[2016-04-10T21:51:23.516Z]: (1460325083516): Component "client:navbar" calling start()
xdk:client:[2016-04-10T21:51:23.533Z]: (1460325083533): Component "client:navbar" finished start()
xdk:client:[2016-04-10T21:51:23.533Z]: (1460325083533): Component "client:project-manager" calling start()
xdk:client:[2016-04-10T21:51:23.533Z]: (1460325083533): Component "client:project-manager" finished start()
xdk:client:[2016-04-10T21:51:23.533Z]: (1460325083534): Component "client:aa-controller" calling start()
xdk:client:[2016-04-10T21:51:23.534Z]: (1460325083534): Component "client:aa-controller" finished start()
xdk:client:[2016-04-10T21:51:23.534Z]: (1460325083534): Component "client:projects-tab" calling start()
xdk:client:[2016-04-10T21:51:23.542Z]: (1460325083542): Component "client:projects-tab" finished start()
xdk:client:[2016-04-10T21:51:23.542Z]: (1460325083542): Component "client:projects-list" calling start()
xdk:client:[2016-04-10T21:51:23.544Z]: (1460325083544): Component "client:projects-list" finished start()
xdk:client:[2016-04-10T21:51:23.544Z]: (1460325083544): Component "client:projects-info" calling start()
xdk:client:[2016-04-10T21:51:23.547Z]: (1460325083547): Component "client:projects-info" finished start()
xdk:client:[2016-04-10T21:51:23.547Z]: (1460325083547): Component "client:projects-create-list" calling start()
xdk:client:[2016-04-10T21:51:23.620Z]: (1460325083620): Component "client:projects-create-list" finished start()
xdk:client:[2016-04-10T21:51:23.620Z]: (1460325083620): Component "client:projects-create-info" calling start()
xdk:client:[2016-04-10T21:51:23.628Z]: (1460325083628): Component "client:projects-create-info" finished start()
xdk:client:[2016-04-10T21:51:23.628Z]: (1460325083628): Component "client:test-tab" calling start()
xdk:client:[2016-04-10T21:51:23.631Z]: (1460325083631): Component "client:test-tab" finished start()
xdk:client:[2016-04-10T21:51:23.631Z]: (1460325083631): Component "client:profilingTab" calling start()
xdk:client:[2016-04-10T21:51:23.674Z]: (1460325083674): Component "client:profilingTab" finished start()
xdk:client:[2016-04-10T21:51:23.674Z]: (1460325083674): Component "client:emulator" calling start()
xdk:client:[2016-04-10T21:51:23.675Z]: (1460325083675): Component "client:emulator" finished start()
xdk:client:[2016-04-10T21:51:23.675Z]: (1460325083675): Component "client:remote-tab" calling start()
xdk:client:[2016-04-10T21:51:23.679Z]: (1460325083679): onExitRequest listener 2:
    at Object.myExports.start (file:///C:/Users/tpeti/AppData/Local/Intel/XDK/xdk/components/client/remote-tab/remote-tab.js:20:3484)
    at resumeClientInit (C:\Users\tpeti\AppData\Local\Intel\XDK\xdk\core-modules\private\main.js:17:12040)
    at C:\Users\tpeti\AppData\Local\Intel\XDK\xdk\core-modules\private\main.js:17:1734
xdk:client:[2016-04-10T21:51:23.680Z]: (1460325083680): Component "client:remote-tab" finished start()
xdk:client:[2016-04-10T21:51:23.680Z]: (1460325083680): Component "client:build-tab" calling start()
xdk:client:[2016-04-10T21:51:23.682Z]: (1460325083682): Component "client:build-tab" finished start()
xdk:client:[2016-04-10T21:51:23.682Z]: (1460325083682): Component "client:active-sync" calling start()
xdk:client:[2016-04-10T21:51:23.682Z]: (1460325083682): Component "client:active-sync" finished start()
xdk:client:[2016-04-10T21:51:23.682Z]: (1460325083682): Component "client:apk-installer" calling start()
xdk:client:[2016-04-10T21:51:23.682Z]: (1460325083682): Component "client:apk-installer" finished start()
xdk:client:[2016-04-10T21:51:23.682Z]: (1460325083682): Component "client:resource-manager" calling start()
xdk:client:[2016-04-10T21:51:23.682Z]: (1460325083682): Component "client:resource-manager" finished start()
xdk:client:[2016-04-10T21:51:23.682Z]: (1460325083682): Component "client:resource-cocos2d" calling start()
xdk:client:[2016-04-10T21:51:23.682Z]: (1460325083682): Component "client:resource-cocos2d" finished start()
xdk:client:[2016-04-10T21:51:23.682Z]: (1460325083683): Component "client:resource-cocos2djs" calling start()
xdk:client:[2016-04-10T21:51:23.683Z]: (1460325083683): Component "client:resource-cocos2djs" finished start()
xdk:client:[2016-04-10T21:51:23.683Z]: (1460325083683): Component "client:resource-phaser" calling start()
xdk:client:[2016-04-10T21:51:23.683Z]: (1460325083683): Component "client:resource-phaser" finished start()
xdk:client:[2016-04-10T21:51:23.683Z]: (1460325083683): Component "client:resource-pixi" calling start()
xdk:client:[2016-04-10T21:51:23.683Z]: (1460325083683): Component "client:resource-pixi" finished start()
xdk:client:[2016-04-10T21:51:23.683Z]: (1460325083683): Component "client:resource-easeljs" calling start()
xdk:client:[2016-04-10T21:51:23.683Z]: (1460325083683): Component "client:resource-easeljs" finished start()
xdk:client:[2016-04-10T21:51:23.683Z]: (1460325083683): Component "client:resource-plain" calling start()
xdk:client:[2016-04-10T21:51:23.683Z]: (1460325083683): Component "client:resource-plain" finished start()
xdk:client:[2016-04-10T21:51:23.683Z]: (1460325083683): Component "client:resource-render-frame" calling start()
xdk:client:[2016-04-10T21:51:23.683Z]: (1460325083683): Component "client:resource-render-frame" finished start()
xdk:client:[2016-04-10T21:51:23.683Z]: (1460325083683): Component "client:resource-util" calling start()
xdk:client:[2016-04-10T21:51:23.683Z]: (1460325083683): Component "client:resource-util" finished start()
xdk:client:[2016-04-10T21:51:23.683Z]: (1460325083683): Component "client:bower-client" calling start()
xdk:client:[2016-04-10T21:51:23.683Z]: (1460325083683): Component "client:bower-client" finished start()
xdk:client:[2016-04-10T21:51:23.683Z]: (1460325083683): Component "client:editor" calling start()
xdk:client:[2016-04-10T21:51:23.683Z]: (1460325083683): Component "client:editor" finished start()
xdk:client:[2016-04-10T21:51:23.683Z]: (1460325083683): Component "client:editor-tab" calling start()
xdk:client:[2016-04-10T21:51:23.699Z]: (1460325083699): Component "client:editor-tab" finished start()
xdk:client:[2016-04-10T21:51:23.700Z]: (1460325083700): Component "client:live-preview" calling start()
xdk:client:[2016-04-10T21:51:23.700Z]: (1460325083700): Component "client:live-preview" finished start()
xdk:client:[2016-04-10T21:51:23.700Z]: (1460325083700): Component "client:account" calling start()
xdk:client:[2016-04-10T21:51:23.701Z]: (1460325083701): Component "client:account" finished start()
xdk:client:[2016-04-10T21:51:23.701Z]: (1460325083701): Component "client:project-selector" calling start()
xdk:client:[2016-04-10T21:51:23.702Z]: (1460325083702): Component "client:project-selector" finished start()
xdk:client:[2016-04-10T21:51:23.702Z]: (1460325083702): Component "client:ui-builder-client" calling start()
xdk:client:[2016-04-10T21:51:23.703Z]: (1460325083703): Component "client:ui-builder-client" finished start()
xdk:client:[2016-04-10T21:51:23.703Z]: (1460325083703): Component "client:project-meta" calling start()
xdk:client:[2016-04-10T21:51:23.704Z]: (1460325083704): Component "client:project-meta" finished start()
xdk:client:[2016-04-10T21:51:23.704Z]: (1460325083704): Component "client:cordova-registry" calling start()
xdk:client:[2016-04-10T21:51:23.704Z]: (1460325083704): Component "client:cordova-registry" finished start()
xdk:client:[2016-04-10T21:51:23.704Z]: (1460325083704): Component "client:adb" calling start()
xdk:client:[2016-04-10T21:51:23.704Z]: (1460325083704): Component "client:adb" finished start()
xdk:client:[2016-04-10T21:51:23.704Z]: (1460325083704): Component "client:iosdb" calling start()
xdk:client:[2016-04-10T21:51:23.705Z]: (1460325083705): Component "client:iosdb" finished start()
xdk:client:[2016-04-10T21:51:23.705Z]: (1460325083705): Component "client:device-discovery" calling start()
xdk:client:[2016-04-10T21:51:23.707Z]: (1460325083707): onExitRequest listener 3:
    at Object.start (file:///C:/Users/tpeti/AppData/Local/Intel/XDK/xdk/components/client/device-discovery/device-discovery.js:17:9195)
xdk:client:[2016-04-10T21:51:23.707Z]: (1460325083707): Component "client:device-discovery" finished start()
xdk:client:[2016-04-10T21:51:23.707Z]: (1460325083707): Component "client:test-local-server" calling start()
xdk:client:[2016-04-10T21:51:23.707Z]: (1460325083707): Component "client:test-local-server" finished start()
xdk:client:[2016-04-10T21:51:23.708Z]: (1460325083708): Component "client:quick-tour" calling start()
xdk:client:[2016-04-10T21:51:23.708Z]: (1460325083708): Component "client:quick-tour" finished start()
xdk:client:[2016-04-10T21:51:23.708Z]: (1460325083708): Component "client:hot-keys" calling start()
xdk:client:[2016-04-10T21:51:23.709Z]: (1460325083709): Component "client:hot-keys" finished start()
xdk:client:[2016-04-10T21:51:23.709Z]: (1460325083709): Component "client:persistance" calling start()
xdk:client:[2016-04-10T21:51:23.710Z]: (1460325083710): onExit listener 4:
    at Object.start (file:///C:/Users/tpeti/AppData/Local/Intel/XDK/xdk/components/client/persistance/persistance.js:17:4613)
xdk:client:[2016-04-10T21:51:23.710Z]: (1460325083710): Component "client:persistance" finished start()
xdk:client:[2016-04-10T21:51:23.710Z]: (1460325083710): Component "client:file-watcher" calling start()
xdk:client:[2016-04-10T21:51:23.710Z]: (1460325083710): Component "client:file-watcher" finished start()
xdk:client:[2016-04-10T21:51:23.710Z]: (1460325083710): Component "client:cordova" calling start()
xdk:client:[2016-04-10T21:51:23.710Z]: (1460325083710): Component "client:cordova" finished start()
xdk:client:[2016-04-10T21:51:23.710Z]: (1460325083710): Component "client:external-editors-runner" calling start()
xdk:client:[2016-04-10T21:51:23.711Z]: (1460325083711): Component "client:external-editors-runner" finished start()
xdk:client:[2016-04-10T21:51:23.711Z]: (1460325083711): Component "client:upload-manager" calling start()
xdk:client:[2016-04-10T21:51:23.711Z]: (1460325083711): Component "client:upload-manager" finished start()
xdk:client:[2016-04-10T21:51:23.711Z]: (1460325083711): Component "client:publish-tab" calling start()
xdk:client:[2016-04-10T21:51:23.713Z]: (1460325083713): onExitRequest listener 5:
    at AutofillController.registerForEvents_ (file:///C:/Users/tpeti/AppData/Local/Intel/XDK/xdk/components/client/publish-tab/autofill-form-controller.js:17:1607)
    at new AutofillController (file:///C:/Users/tpeti/AppData/Local/Intel/XDK/xdk/components/client/publish-tab/autofill-form-controller.js:17:470)
    at Object.myExports.start (file:///C:/Users/tpeti/AppData/Local/Intel/XDK/xdk/components/client/publish-tab/publish-tab.js:17:4918)
xdk:client:[2016-04-10T21:51:23.740Z]: (1460325083740): Component "client:publish-tab" finished start()
xdk:client:[2016-04-10T21:51:23.741Z]: (1460325083741): Intel XDK is initialized now
client:build-tab:[2016-04-10T21:51:23.745Z]: (1460325083745): [refreshPage] Unable to generate project hash. { message_: 'no project selected',
  code_: null,
  componentName_: null,
  stack_: 'Error\n    at new ComponentError (C:\\Users\\tpeti\\AppData\\Local\\Intel\\XDK\\xdk\\core-modules\\public\\component-error.js:17:1122)\n    at makeError (file:///C:/Users/tpeti/AppData/Local/Intel/XDK/xdk/components/client/backend-service-utils/backend-service-utils.js:17:187)\n    at Object.exports.generateProjectHash (file:///C:/Users/tpeti/AppData/Local/Intel/XDK/xdk/components/client/backend-service-utils/backend-service-utils.js:17:1440)\n    at _refreshPage (file:///C:/Users/tpeti/AppData/Local/Intel/XDK/xdk/components/client/build-tab/build-tab.js:17:6994)\n    at Object.start (file:///C:/Users/tpeti/AppData/Local/Intel/XDK/xdk/components/client/build-tab/build-tab.js:17:3869)\n    at resumeClientInit (C:\\Users\\tpeti\\AppData\\Local\\Intel\\XDK\\xdk\\core-modules\\private\\main.js:17:12040)\n    at C:\\Users\\tpeti\\AppData\\Local\\Intel\\XDK\\xdk\\core-modules\\private\\main.js:17:1734\n    at _fulfilled (C:\\Users\\tpeti\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\q\\q.js:834:54)\n    at self.promiseDispatch.done (C:\\Users\\tpeti\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\q\\q.js:863:30)\n    at Promise.promise.promiseDispatch (C:\\Users\\tpeti\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\q\\q.js:796:13)' }
client:build-tab:[2016-04-10T21:51:23.746Z]: (1460325083746): [updatePageStatus] Set Status: PAGE_STATUS_ERROR
xdk:client:[2016-04-10T21:51:23.757Z]: (1460325083757): onExitRequest listener 6:
    at file:///C:/Users/tpeti/AppData/Local/Intel/XDK/xdk/components/client/project-manager/project-manager.js:18:10467
    at _fulfilled (file:///C:/Users/tpeti/AppData/Local/Intel/XDK/xdk/node_modules/q/q.js:834:54)
    at self.promiseDispatch.done (file:///C:/Users/tpeti/AppData/Local/Intel/XDK/xdk/node_modules/q/q.js:863:30)
    at Promise.promise.promiseDispatch (file:///C:/Users/tpeti/AppData/Local/Intel/XDK/xdk/node_modules/q/q.js:796:13)
    at file:///C:/Users/tpeti/AppData/Local/Intel/XDK/xdk/node_modules/q/q.js:604:44
    at runSingle (file:///C:/Users/tpeti/AppData/Local/Intel/XDK/xdk/node_modules/q/q.js:137:13)
    at flush (file:///C:/Users/tpeti/AppData/Local/Intel/XDK/xdk/node_modules/q/q.js:125:13)
    at process._tickCallback (node.js:393:11)
xdk:client:[2016-04-10T21:51:24.061Z]: (1460325084061): memmrk:    52879292    78964736
client:publish-tab:[2016-04-10T21:51:25.115Z]: (1460325085116): Stores data feed has been successfully loaded.
xdk:server:[2016-04-10T21:51:26.927Z]: (1460325086927): memmrk:    40666252    60673536
client:build-tab:[2016-04-10T21:51:26.945Z]: (1460325086945): [refreshPage] Unable to generate project hash. { message_: 'no project selected',
  code_: null,
  stack_: 'Error\n    at new ComponentError (C:\\Users\\tpeti\\AppData\\Local\\Intel\\XDK\\xdk\\core-modules\\public\\component-error.js:17:1122)\n    at makeError (file:///C:/Users/tpeti/AppData/Local/Intel/XDK/xdk/components/client/backend-service-utils/backend-service-utils.js:17:187)\n    at Object.exports.generateProjectHash (file:///C:/Users/tpeti/AppData/Local/Intel/XDK/xdk/components/client/backend-service-utils/backend-service-utils.js:17:1440)\n    at _refreshPage (file:///C:/Users/tpeti/AppData/Local/Intel/XDK/xdk/components/client/build-tab/build-tab.js:17:6994)\n    at file:///C:/Users/tpeti/AppData/Local/Intel/XDK/xdk/components/client/build-tab/build-tab.js:17:2905\n    at Promise.apply (C:\\Users\\tpeti\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\q\\q.js:1165:26)\n    at Promise.promise.promiseDispatch (C:\\Users\\tpeti\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\q\\q.js:788:41)\n    at C:\\Users\\tpeti\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\q\\q.js:1391:14\n    at runSingle (C:\\Users\\tpeti\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\q\\q.js:137:13)\n    at flush (C:\\Users\\tpeti\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\q\\q.js:125:13)' }
client:build-tab:[2016-04-10T21:51:26.946Z]: (1460325086946): [updatePageStatus] Set Status: PAGE_STATUS_ERROR
client:navbar:[2016-04-10T21:51:26.950Z]: (1460325086951): pollForUpdates called
client:services-tab:[2016-04-10T21:51:27.759Z]: (1460325087759): Iframe onLoad resolved for : http://127.0.0.1:58889/http-services/api-explorer/iodocs/index?
client:services-tab:[2016-04-10T21:51:27.838Z]: (1460325087838): Iframe onLoad resolved for : http://127.0.0.1:58889/http-services/api-explorer/iodocs/sidebar?
client:services-tab:[2016-04-10T21:51:27.838Z]: (1460325087838): Both iframes loaded promise resolved.
client:services-tab:[2016-04-10T21:51:27.844Z]: (1460325087845): Calling postmessage for user refresh.
client:services-tab:[2016-04-10T21:51:27.845Z]: (1460325087845): main container window : true
client:services-tab:[2016-04-10T21:51:27.845Z]: (1460325087845): main container document : true
client:services-tab:[2016-04-10T21:51:27.845Z]: (1460325087845): component:services-tab:postMessageToWindow target = user
client:navbar:[2016-04-10T21:51:28.657Z]: (1460325088657): polling up-to-date
xdk:client:[2016-04-10T21:51:29.062Z]: (1460325089062): memmrk:    58576048    86050176
xdk:server:[2016-04-10T21:51:31.928Z]: (1460325091928): memmrk:    43426612    60673536
xdk:client:[2016-04-10T21:51:34.063Z]: (1460325094064): memmrk:    58778288    86050176
xdk:server:[2016-04-10T21:51:36.929Z]: (1460325096929): memmrk:    44067396    60673536
xdk:client:[2016-04-10T21:51:39.063Z]: (1460325099063): memmrk:    58884076    86050176
xdk:server:[2016-04-10T21:51:41.930Z]: (1460325101930): memmrk:    24713408    60673536
xdk:client:[2016-04-10T21:51:44.064Z]: (1460325104064): memmrk:    59042836    86050176
xdk:server:[2016-04-10T21:51:46.930Z]: (1460325106930): memmrk:    24724224    60673536
xdk:client:[2016-04-10T21:51:49.064Z]: (1460325109064): memmrk:    59147308    86050176
xdk:server:[2016-04-10T21:51:51.930Z]: (1460325111930): memmrk:    22690616    30749696
xdk:client:[2016-04-10T21:51:54.065Z]: (1460325114065): memmrk:    59306320    86050176
xdk:server:[2016-04-10T21:51:56.931Z]: (1460325116932): memmrk:    22700152    30749696
xdk:client:[2016-04-10T21:51:59.066Z]: (1460325119066): memmrk:    59440508    86050176
xdk:server:[2016-04-10T21:52:01.932Z]: (1460325121932): memmrk:    22066672    30749696
xdk:client:[2016-04-10T21:52:04.066Z]: (1460325124066): memmrk:    59662364    86050176
xdk:server:[2016-04-10T21:53:31.668Z]: (1460325211668): memmrk:    21228028    30794752
xdk:client:[2016-04-10T21:53:31.679Z]: (1460325211679): memmrk:    58519272    89158016
xdk:server:[2016-04-10T21:53:36.668Z]: (1460325216668): memmrk:    20878092    29791232
xdk:client:[2016-04-10T21:53:36.672Z]: (1460325216672): memmrk:    44689268    89158016
xdk:server:[2016-04-10T21:53:41.669Z]: (1460325221669): memmrk:    20885712    29791232
xdk:client:[2016-04-10T21:53:41.672Z]: (1460325221672): memmrk:    50397076    77030656
xdk:server:[2016-04-10T21:53:46.669Z]: (1460325226669): memmrk:    20892948    29791232
xdk:client:[2016-04-10T21:53:46.673Z]: (1460325226673): memmrk:    42804448    77030656
xdk:server:[2016-04-10T21:53:51.669Z]: (1460325231669): memmrk:    20900168    29791232
xdk:client:[2016-04-10T21:53:51.674Z]: (1460325231674): memmrk:    42914652    77030656
xdk:server:[2016-04-10T21:53:56.669Z]: (1460325236669): memmrk:    20907388    29791232
xdk:client:[2016-04-10T21:53:56.674Z]: (1460325236674): memmrk:    41856132    77030656
xdk:server:[2016-04-10T21:54:01.669Z]: (1460325241669): memmrk:    20914608    29791232
xdk:client:[2016-04-10T21:54:01.676Z]: (1460325241676): memmrk:    42045888    77030656
xdk:server:[2016-04-10T21:54:06.669Z]: (1460325246669): memmrk:    20921844    29791232
xdk:client:[2016-04-10T21:54:06.676Z]: (1460325246676): memmrk:    42269856    77030656
xdk:server:[2016-04-10T21:54:11.670Z]: (1460325251670): memmrk:    20930744    29791232
xdk:client:[2016-04-10T21:54:11.677Z]: (1460325251677): memmrk:    41327336    60298496
xdk:server:[2016-04-10T21:54:16.670Z]: (1460325256670): memmrk:    21303996    29791232
xdk:client:[2016-04-10T21:54:16.677Z]: (1460325256677): memmrk:    42628440    61302016
xdk:server:[2016-04-10T21:54:21.670Z]: (1460325261670): memmrk:    21518128    29791232
xdk:client:[2016-04-10T21:54:21.678Z]: (1460325261678): memmrk:    42564444    64447744
xdk:server:[2016-04-10T21:54:26.670Z]: (1460325266670): memmrk:    21525332    29791232
xdk:client:[2016-04-10T21:54:26.679Z]: (1460325266679): memmrk:    42712624    64447744
xdk:server:[2016-04-10T21:54:31.671Z]: (1460325271671): memmrk:    21532552    29791232
xdk:client:[2016-04-10T21:54:31.679Z]: (1460325271679): memmrk:    43216568    64447744
xdk:server:[2016-04-10T21:54:36.671Z]: (1460325276671): memmrk:    21542376    29791232
xdk:client:[2016-04-10T21:54:36.680Z]: (1460325276680): memmrk:    43922960    64447744
xdk:server:[2016-04-10T21:54:41.671Z]: (1460325281671): memmrk:    21549580    29791232
xdk:client:[2016-04-10T21:54:41.681Z]: (1460325281681): memmrk:    44051700    64447744
xdk:server:[2016-04-10T21:54:46.671Z]: (1460325286671): memmrk:    21556768    29791232
xdk:client:[2016-04-10T21:54:46.681Z]: (1460325286681): memmrk:    44837152    64447744
xdk:server:[2016-04-10T21:54:51.671Z]: (1460325291671): memmrk:    21563972    29791232
xdk:client:[2016-04-10T21:54:51.682Z]: (1460325291682): memmrk:    49280532    68642048
xdk:server:[2016-04-10T21:54:56.671Z]: (1460325296671): memmrk:    21571160    29791232
xdk:client:[2016-04-10T21:54:56.682Z]: (1460325296682): memmrk:    49462236    68642048
xdk:server:[2016-04-10T21:55:01.671Z]: (1460325301671): memmrk:    21580048    29791232
xdk:client:[2016-04-10T21:55:01.683Z]: (1460325301683): memmrk:    51415272    77030656
xdk:server:[2016-04-10T21:55:06.672Z]: (1460325306672): memmrk:    21587268    29791232
xdk:client:[2016-04-10T21:55:06.684Z]: (1460325306684): memmrk:    49169356    80077696
xdk:server:[2016-04-10T21:55:11.672Z]: (1460325311672): memmrk:    21594504    29791232
xdk:client:[2016-04-10T21:55:11.684Z]: (1460325311684): memmrk:    49308284    80077696
xdk:server:[2016-04-10T21:55:16.673Z]: (1460325316673): memmrk:    21601692    29791232
xdk:client:[2016-04-10T21:55:16.684Z]: (1460325316684): memmrk:    55100116    81081216
xdk:server:[2016-04-10T21:55:21.673Z]: (1460325321673): memmrk:    21608896    29791232
xdk:client:[2016-04-10T21:55:21.685Z]: (1460325321685): memmrk:    48162244    81081216
xdk:server:[2016-04-10T21:55:26.673Z]: (1460325326673): memmrk:    21616100    29791232
xdk:client:[2016-04-10T21:55:26.686Z]: (1460325326686): memmrk:    48756208    81081216
xdk:server:[2016-04-10T21:55:31.674Z]: (1460325331674): memmrk:    21625552    29791232
xdk:client:[2016-04-10T21:55:31.686Z]: (1460325331686): memmrk:    49704956    81081216
xdk:server:[2016-04-10T21:55:36.676Z]: (1460325336676): memmrk:    21634004    29791232
xdk:client:[2016-04-10T21:55:36.687Z]: (1460325336687): memmrk:    49852844    81081216
xdk:server:[2016-04-10T21:55:41.675Z]: (1460325341675): memmrk:    21651852    29791232
xdk:client:[2016-04-10T21:55:41.695Z]: (1460325341695): memmrk:    50446108    81081216
xdk:server:[2016-04-10T21:55:46.676Z]: (1460325346676): memmrk:    21663272    29791232
xdk:client:[2016-04-10T21:55:46.696Z]: (1460325346696): memmrk:    50990712    81081216
xdk:server:[2016-04-10T21:55:51.676Z]: (1460325351676): memmrk:    21690908    29791232
xdk:client:[2016-04-10T21:55:51.696Z]: (1460325351696): memmrk:    51089592    81081216
xdk:server:[2016-04-10T21:55:56.677Z]: (1460325356677): memmrk:    21910244    29791232
xdk:client:[2016-04-10T21:55:56.697Z]: (1460325356697): memmrk:    52172540    81081216
client:cordova:[2016-04-10T21:55:58.012Z]: (1460325358012): [cordova] top-down list =  [ 'cordova-plugin-statusbar',
  'cordova-plugin-splashscreen',
  'cordova-plugin-device' ]
client:cordova:[2016-04-10T21:55:58.014Z]: (1460325358014): [cordova] ********* changes for synch  { REMOVE: [],
  ADD:
   [ { origin: 'cordova-plugin-device',
       version: '1.1.1',
       gitref: '',
       subdir: undefined,
       variables: {},
       OVERRIDE_EXISTENCE_CHECK: false },
     { origin: 'cordova-plugin-splashscreen',
       version: '3.2.0',
       gitref: '',
       subdir: undefined,
       variables: {},
     { origin: 'cordova-plugin-statusbar',
       version: '2.1.0',
       gitref: '',
       subdir: undefined,
       variables: {},
       OVERRIDE_EXISTENCE_CHECK: false } ] }
xdk:client:[2016-04-10T21:56:01.698Z]: (1460325361698): memmrk:    54078424    82084736
xdk:client:[2016-04-10T21:56:06.699Z]: (1460325366699): memmrk:    54229808    82084736
xdk:client:[2016-04-10T21:56:11.699Z]: (1460325371699): memmrk:    54331732    82084736
xdk:client:[2016-04-10T21:56:16.700Z]: (1460325376700): memmrk:    54506580    82084736
xdk:client:[2016-04-10T21:56:21.700Z]: (1460325381700): memmrk:    54607108    82084736
xdk:client:[2016-04-10T21:56:26.701Z]: (1460325386701): memmrk:    54835356    82084736
xdk:server:[2016-04-10T21:56:29.548Z]: (1460325389548): memmrk:    65260876    78943616
client:cordova:[2016-04-10T21:56:29.549Z]: (1460325389549): Cordova plugin change request:  { ADD:
       version: '1.1.1',
       gitref: '',
       subdir: undefined,
       variables: {},
       version: '3.2.0',
       gitref: '',
       subdir: undefined,
       variables: {},
       version: '2.1.0',
       gitref: '',
       subdir: undefined,
       variables: {},
client:cordova:[2016-04-10T21:56:30.135Z]: (1460325390135): Cordova plugin add  [ 'cordova-plugin-device@1.1.1',
  'cordova-plugin-splashscreen@3.2.0',
  'cordova-plugin-statusbar@2.1.0' ]
xdk:client:[2016-04-10T21:56:31.701Z]: (1460325391701): memmrk:    55315500    82084736
client:cordova:[2016-04-10T21:56:32.963Z]: (1460325392963): All Cordova plugin changes done successfully, now updating plugin references..
client:cordova:[2016-04-10T21:56:33.168Z]: (1460325393168): [cordova] synchronize plugins done successfully!!
client:remote-tab:[2016-04-10T21:56:33.509Z]: (1460325393509): About to start needsDebugModule in addTabWatcher
bower-package-manager:[2016-04-10T21:56:33.550Z]: (1460325393550): Bower packages not found { [Error: An error ocurred while trying to check for the file "C:/Users/tpeti/Documents/Output/asd/bower.json".]
  code: 22,
  message: 'An error ocurred while trying to check for the file "C:/Users/tpeti/Documents/Output/asd/bower.json".',
  originalMessage: 'NotFound',
  originalError: null }
client:build-tab:[2016-04-10T21:56:33.769Z]: (1460325393769): [refreshPage] projectId CoVFKl9og7y9GuVxSWiwvIMepM9_MI6r4PkyLKloQjM
client:build-tab:[2016-04-10T21:56:33.769Z]: (1460325393769): [updatePageState] Set State: PAGE_STATE_LOADING
client:build-tab:[2016-04-10T21:56:33.771Z]: (1460325393771): [getBuildTargets] Getting available targets for project CoVFKl9og7y9GuVxSWiwvIMepM9_MI6r4PkyLKloQjM
client:build-tab:[2016-04-10T21:56:33.772Z]: (1460325393772): [refreshProjectInfo] Getting project info.
client:build-tab:[2016-04-10T21:56:33.773Z]: (1460325393773): [refreshBuildAssetsDate] Getting latest upload date for project files
builds:[2016-04-10T21:56:34.103Z]: (1460325394103): Error building UI for: certificateId
client:build-tab:[2016-04-10T21:56:34.235Z]: (1460325394235): [getBuildTargets] Targets retrieved for project CoVFKl9og7y9GuVxSWiwvIMepM9_MI6r4PkyLKloQjM
client:build-tab:[2016-04-10T21:56:34.270Z]: (1460325394270): [updatePageStatus] Set Status: PAGE_STATUS_READY
client:build-tab:[2016-04-10T21:56:34.270Z]: (1460325394270): [updatePageState] Set State: PAGE_STATE_IDLE
client:build-tab:[2016-04-10T21:56:34.273Z]: (1460325394273): [startUpdateStatusProcess] Starting build pulling process. Project: CoVFKl9og7y9GuVxSWiwvIMepM9_MI6r4PkyLKloQjM
client:build-tab:[2016-04-10T21:56:34.273Z]: (1460325394273): [updatePageState] Set State: PAGE_STATE_UPDATING
client:build-service:[2016-04-10T21:56:34.275Z]: (1460325394275): [startUpdateStatusProcess] Starting polling. Project: CoVFKl9og7y9GuVxSWiwvIMepM9_MI6r4PkyLKloQjM
uib-client:[2016-04-10T21:56:34.284Z]: (1460325394284): gradeHTMLFile 1 /C/Users/tpeti/Documents/Output/asd/www/index.html
xdk:server:[2016-04-10T21:56:34.548Z]: (1460325394548): memmrk:    60387952    87044736
xdk:client:[2016-04-10T21:56:36.702Z]: (1460325396702): memmrk:    67286608    91165056
client:build-tab:[2016-04-10T21:56:37.439Z]: (1460325397439): [refreshBuildAssetsDate] latest upload date null
client:remote-tab:[2016-04-10T21:56:37.854Z]: (1460325397854): About to start needsDebugModule in addTabWatcher
client:build-service:[2016-04-10T21:56:38.183Z]: (1460325398183): [startUpdateStatusProcess] Polling process has finished.
client:build-tab:[2016-04-10T21:56:38.184Z]: (1460325398184): [updatePageState] Set State: PAGE_BUILDING
client:build-tab:[2016-04-10T21:56:38.187Z]: (1460325398187): [updatePageStatus] Set Status: PAGE_STATUS_READY
client:build-tab:[2016-04-10T21:56:38.187Z]: (1460325398187): [updatePageState] Set State: PAGE_STATE_IDLE
client:services-tab:[2016-04-10T21:56:39.164Z]: (1460325399164): Calling postmessage for project refresh.
client:services-tab:[2016-04-10T21:56:39.164Z]: (1460325399164): sidebar container window : true
client:services-tab:[2016-04-10T21:56:39.164Z]: (1460325399164): sidebar container document : true
client:services-tab:[2016-04-10T21:56:39.164Z]: (1460325399164): main container window : true
client:services-tab:[2016-04-10T21:56:39.164Z]: (1460325399164): main container document : true
client:services-tab:[2016-04-10T21:56:39.164Z]: (1460325399164): component:services-tab:postMessageToWindow target = project
xdk:server:[2016-04-10T21:56:40.223Z]: (1460325400223): memmrk:    74929744    103882368
xdk:client:[2016-04-10T21:56:41.703Z]: (1460325401703): memmrk:    61543932    100241152
xdk:server:[2016-04-10T21:56:45.223Z]: (1460325405223): memmrk:    76294688    103882368
xdk:client:[2016-04-10T21:56:46.703Z]: (1460325406703): memmrk:    64046164    100241152
xdk:server:[2016-04-10T21:56:50.223Z]: (1460325410223): memmrk:    76302636    103882368
xdk:client:[2016-04-10T21:56:51.704Z]: (1460325411704): memmrk:    65892924    102825088
client:remote-tab:[2016-04-10T21:56:53.627Z]: (1460325413627): About to start needsDebugModule in addTabWatcher
client:emulator:[2016-04-10T21:56:53.629Z]: (1460325413629): emulator is shown for the project
client:emulator:[2016-04-10T21:56:53.629Z]: (1460325413629): asd
xdk:server:[2016-04-10T21:56:55.224Z]: (1460325415224): memmrk:    77104736    103882368
xdk:client:[2016-04-10T21:56:56.705Z]: (1460325416705): memmrk:    69164344    102825088
client:emulator:[2016-04-10T21:56:56.960Z]: (1460325416960): Device Emulator :: Environment Warming Up (Tea. Earl Gray. Hot.)
client:emulator:[2016-04-10T21:56:57.271Z]: (1460325417271): appmobi_plus_cordova :: Emulator changing to project asd
client:emulator:[2016-04-10T21:56:57.276Z]: (1460325417276): appmobi_plus_cordova :: _xdkLoad for project asd
client:emulator:[2016-04-10T21:56:57.278Z]: (1460325417278): appmobi_plus_cordova :: Emulator changing to project asd
xdk:client:[2016-04-10T21:57:01.705Z]: (1460325421705): memmrk:    75212232    103828608
xdk:client:[2016-04-10T21:57:06.705Z]: (1460325426705): memmrk:    75385912    103828608
xdk:server:[2016-04-10T21:57:07.883Z]: (1460325427883): memmrk:    56380088    97259136
xdk:client:[2016-04-10T21:57:11.706Z]: (1460325431706): memmrk:    75615300    103828608
xdk:client:[2016-04-10T21:57:16.706Z]: (1460325436706): memmrk:    72354384    103828608
xdk:client:[2016-04-10T21:57:21.707Z]: (1460325441707): memmrk:    72455996    103828608
xdk:client:[2016-04-10T21:57:26.707Z]: (1460325446707): memmrk:    75602052    103828608
xdk:client:[2016-04-10T21:57:31.721Z]: (1460325451721): memmrk:    75729304    103828608
xdk:client:[2016-04-10T21:57:36.722Z]: (1460325456722): memmrk:    75882920    103828608
xdk:client:[2016-04-10T21:57:41.723Z]: (1460325461723): memmrk:    75987432    103828608
xdk:client:[2016-04-10T21:57:46.723Z]: (1460325466723): memmrk:    76152916    103828608
xdk:client:[2016-04-10T21:57:51.724Z]: (1460325471724): memmrk:    76398524    103828608
xdk:client:[2016-04-10T21:57:56.725Z]: (1460325476725): memmrk:    76557864    103828608
xdk:client:[2016-04-10T21:58:01.726Z]: (1460325481726): memmrk:    76697756    103828608
xdk:client:[2016-04-10T21:58:06.726Z]: (1460325486726): memmrk:    62284892    102325376
xdk:client:[2016-04-10T21:58:11.727Z]: (1460325491727): memmrk:    62388044    102325376
xdk:client:[2016-04-10T21:58:16.728Z]: (1460325496728): memmrk:    62766964    102325376
xdk:client:[2016-04-10T21:58:21.728Z]: (1460325501728): memmrk:    62872116    102325376
xdk:client:[2016-04-10T21:58:26.729Z]: (1460325506729): memmrk:    63042964    102325376
xdk:client:[2016-04-10T21:58:31.728Z]: (1460325511728): memmrk:    63142428    102325376
xdk:client:[2016-04-10T21:58:36.729Z]: (1460325516729): memmrk:    60102048    80551296
xdk:server:[2016-04-10T21:58:39.770Z]: (1460325519770): memmrk:    74679236    103341056
xdk:client:[2016-04-10T21:58:41.730Z]: (1460325521730): memmrk:    60337420    80551296
xdk:client:[2016-04-10T21:58:46.731Z]: (1460325526731): memmrk:    60515740    80551296
xdk:client:[2016-04-10T21:58:51.731Z]: (1460325531731): memmrk:    59009904    77504256
xdk:server:[2016-04-10T21:58:52.734Z]: (1460325532734): memmrk:    74472560    103341056
client:emulator:[2016-04-10T21:58:52.752Z]: (1460325532752): appmobi_plus_cordova :: Initialization Finished (Make it so.)
server:emulator-webserver:[2016-04-10T21:58:52.761Z]: (1460325532761): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-04-10T21:58:52.762Z]: (1460325532762): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/index.html
server:emulator-webserver:[2016-04-10T21:58:52.762Z]: (1460325532762): Main html fullPath = /C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/index.html
client:emulator:[2016-04-10T21:58:52.756Z]: (1460325532756): appmobi_plus_cordova :: frame appended to document
server:emulator-webserver:[2016-04-10T21:58:52.847Z]: (1460325532847): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-04-10T21:58:52.847Z]: (1460325532847): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/fonts/gamefont.css
server:emulator-webserver:[2016-04-10T21:58:52.847Z]: (1460325532847): Other file request, fullPath = /C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/fonts/gamefont.css
server:emulator-webserver:[2016-04-10T21:58:52.849Z]: (1460325532849): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-04-10T21:58:52.849Z]: (1460325532849): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/js/libs/pixi.js
server:emulator-webserver:[2016-04-10T21:58:52.849Z]: (1460325532849): Other file request, fullPath = /C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/js/libs/pixi.js
server:emulator-webserver:[2016-04-10T21:58:52.851Z]: (1460325532851): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-04-10T21:58:52.851Z]: (1460325532851): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/js/libs/fpsmeter.js
server:emulator-webserver:[2016-04-10T21:58:52.851Z]: (1460325532851): Other file request, fullPath = /C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/js/libs/fpsmeter.js
server:emulator-webserver:[2016-04-10T21:58:52.852Z]: (1460325532852): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-04-10T21:58:52.852Z]: (1460325532852): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/js/libs/lz-string.js
server:emulator-webserver:[2016-04-10T21:58:52.852Z]: (1460325532852): Other file request, fullPath = /C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/js/libs/lz-string.js
server:emulator-webserver:[2016-04-10T21:58:52.887Z]: (1460325532887): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-04-10T21:58:52.887Z]: (1460325532887): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/js/rpg_core.js
server:emulator-webserver:[2016-04-10T21:58:52.887Z]: (1460325532887): Other file request, fullPath = /C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/js/rpg_core.js
server:emulator-webserver:[2016-04-10T21:58:52.889Z]: (1460325532889): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-04-10T21:58:52.889Z]: (1460325532889): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/js/rpg_managers.js
server:emulator-webserver:[2016-04-10T21:58:52.889Z]: (1460325532889): Other file request, fullPath = /C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/js/rpg_managers.js
server:emulator-webserver:[2016-04-10T21:58:52.891Z]: (1460325532891): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-04-10T21:58:52.891Z]: (1460325532891): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/js/rpg_objects.js
server:emulator-webserver:[2016-04-10T21:58:52.891Z]: (1460325532891): Other file request, fullPath = /C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/js/rpg_objects.js
server:emulator-webserver:[2016-04-10T21:58:52.905Z]: (1460325532905): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-04-10T21:58:52.905Z]: (1460325532905): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/js/rpg_scenes.js
server:emulator-webserver:[2016-04-10T21:58:52.905Z]: (1460325532905): Other file request, fullPath = /C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/js/rpg_scenes.js
server:emulator-webserver:[2016-04-10T21:58:52.906Z]: (1460325532906): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-04-10T21:58:52.907Z]: (1460325532907): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/js/rpg_sprites.js
server:emulator-webserver:[2016-04-10T21:58:52.907Z]: (1460325532907): Other file request, fullPath = /C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/js/rpg_sprites.js
server:emulator-webserver:[2016-04-10T21:58:52.912Z]: (1460325532912): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-04-10T21:58:52.912Z]: (1460325532912): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/js/rpg_windows.js
server:emulator-webserver:[2016-04-10T21:58:52.913Z]: (1460325532913): Other file request, fullPath = /C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/js/rpg_windows.js
server:emulator-webserver:[2016-04-10T21:58:52.914Z]: (1460325532914): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-04-10T21:58:52.914Z]: (1460325532914): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/js/plugins.js
server:emulator-webserver:[2016-04-10T21:58:52.914Z]: (1460325532914): Other file request, fullPath = /C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/js/plugins.js
server:emulator-webserver:[2016-04-10T21:58:52.924Z]: (1460325532924): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-04-10T21:58:52.924Z]: (1460325532924): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/js/main.js
server:emulator-webserver:[2016-04-10T21:58:52.925Z]: (1460325532925): Other file request, fullPath = /C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/js/main.js
server:emulator-webserver:[2016-04-10T21:58:53.004Z]: (1460325533004): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-04-10T21:58:53.004Z]: (1460325533004): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/js/main.js
server:emulator-webserver:[2016-04-10T21:58:53.004Z]: (1460325533004): Other file request, fullPath = /C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/js/main.js
client:emulator:[2016-04-10T21:58:53.008Z]: (1460325533008): appmobi_plus_cordova :: Emulation frame loaded
server:emulator-webserver:[2016-04-10T21:58:53.010Z]: (1460325533010): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-04-10T21:58:53.010Z]: (1460325533010): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/img/system/Loading.png
server:emulator-webserver:[2016-04-10T21:58:53.010Z]: (1460325533010): Other file request, fullPath = /C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/img/system/Loading.png
server:emulator-webserver:[2016-04-10T21:58:53.032Z]: (1460325533032): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-04-10T21:58:53.032Z]: (1460325533032): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/data/Actors.json
server:emulator-webserver:[2016-04-10T21:58:53.032Z]: (1460325533032): Other file request, fullPath = /C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/data/Actors.json
server:emulator-webserver:[2016-04-10T21:58:53.034Z]: (1460325533035): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-04-10T21:58:53.035Z]: (1460325533035): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/data/Classes.json
server:emulator-webserver:[2016-04-10T21:58:53.035Z]: (1460325533035): Other file request, fullPath = /C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/data/Classes.json
server:emulator-webserver:[2016-04-10T21:58:53.038Z]: (1460325533038): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-04-10T21:58:53.038Z]: (1460325533038): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/data/Skills.json
server:emulator-webserver:[2016-04-10T21:58:53.038Z]: (1460325533038): Other file request, fullPath = /C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/data/Skills.json
server:emulator-webserver:[2016-04-10T21:58:53.041Z]: (1460325533041): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-04-10T21:58:53.041Z]: (1460325533041): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/data/Items.json
server:emulator-webserver:[2016-04-10T21:58:53.041Z]: (1460325533041): Other file request, fullPath = /C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/data/Items.json
server:emulator-webserver:[2016-04-10T21:58:53.051Z]: (1460325533051): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-04-10T21:58:53.051Z]: (1460325533051): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/data/Weapons.json
server:emulator-webserver:[2016-04-10T21:58:53.051Z]: (1460325533051): Other file request, fullPath = /C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/data/Weapons.json
server:emulator-webserver:[2016-04-10T21:58:53.053Z]: (1460325533053): emulator-webserver: got a request for userapp.
client:emulator:[2016-04-10T21:58:53.017Z]: (1460325533017): appmobi_plus_cordova :: fired appMobi.device.ready event!
server:emulator-webserver:[2016-04-10T21:58:53.053Z]: (1460325533053): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/data/Armors.json
client:emulator:[2016-04-10T21:58:53.067Z]: (1460325533067): appmobi_plus_cordova :: tinyHipposLoaded cleared _loading/_delayedproject
server:emulator-webserver:[2016-04-10T21:58:53.054Z]: (1460325533054): Other file request, fullPath = /C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/data/Armors.json
client:emulator:[2016-04-10T21:58:53.067Z]: (1460325533067): appmobi_plus_cordova :: [emulator] file watcher started
server:emulator-webserver:[2016-04-10T21:58:53.056Z]: (1460325533056): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-04-10T21:58:53.056Z]: (1460325533056): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/data/Enemies.json
server:emulator-webserver:[2016-04-10T21:58:53.056Z]: (1460325533056): Other file request, fullPath = /C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/data/Enemies.json
server:emulator-webserver:[2016-04-10T21:58:53.060Z]: (1460325533060): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-04-10T21:58:53.060Z]: (1460325533060): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/data/Troops.json
server:emulator-webserver:[2016-04-10T21:58:53.061Z]: (1460325533061): Other file request, fullPath = /C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/data/Troops.json
server:emulator-webserver:[2016-04-10T21:58:53.069Z]: (1460325533069): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-04-10T21:58:53.069Z]: (1460325533069): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/data/States.json
server:emulator-webserver:[2016-04-10T21:58:53.069Z]: (1460325533069): Other file request, fullPath = /C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/data/States.json
server:emulator-webserver:[2016-04-10T21:58:53.071Z]: (1460325533071): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-04-10T21:58:53.071Z]: (1460325533071): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/data/Animations.json
server:emulator-webserver:[2016-04-10T21:58:53.071Z]: (1460325533071): Other file request, fullPath = /C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/data/Animations.json
server:emulator-webserver:[2016-04-10T21:58:53.075Z]: (1460325533075): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-04-10T21:58:53.075Z]: (1460325533075): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/data/Tilesets.json
server:emulator-webserver:[2016-04-10T21:58:53.075Z]: (1460325533075): Other file request, fullPath = /C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/data/Tilesets.json
server:emulator-webserver:[2016-04-10T21:58:53.079Z]: (1460325533079): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-04-10T21:58:53.079Z]: (1460325533079): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/data/CommonEvents.json
server:emulator-webserver:[2016-04-10T21:58:53.079Z]: (1460325533079): Other file request, fullPath = /C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/data/CommonEvents.json
server:emulator-webserver:[2016-04-10T21:58:53.087Z]: (1460325533087): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-04-10T21:58:53.087Z]: (1460325533087): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/data/System.json
server:emulator-webserver:[2016-04-10T21:58:53.087Z]: (1460325533087): Other file request, fullPath = /C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/data/System.json
server:emulator-webserver:[2016-04-10T21:58:53.090Z]: (1460325533090): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-04-10T21:58:53.090Z]: (1460325533090): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/data/MapInfos.json
server:emulator-webserver:[2016-04-10T21:58:53.090Z]: (1460325533090): Other file request, fullPath = /C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/data/MapInfos.json
server:emulator-webserver:[2016-04-10T21:58:53.094Z]: (1460325533094): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-04-10T21:58:53.094Z]: (1460325533094): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/fonts/mplus-1m-regular.ttf
server:emulator-webserver:[2016-04-10T21:58:53.095Z]: (1460325533095): Other file request, fullPath = /C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/fonts/mplus-1m-regular.ttf
server:emulator-webserver:[2016-04-10T21:58:53.098Z]: (1460325533098): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-04-10T21:58:53.098Z]: (1460325533098): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/img/system/Window.png
server:emulator-webserver:[2016-04-10T21:58:53.099Z]: (1460325533099): Other file request, fullPath = /C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/img/system/Window.png
server:emulator-webserver:[2016-04-10T21:58:53.105Z]: (1460325533105): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-04-10T21:58:53.105Z]: (1460325533105): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/img/system/IconSet.png
server:emulator-webserver:[2016-04-10T21:58:53.105Z]: (1460325533105): Other file request, fullPath = /C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/img/system/IconSet.png
server:emulator-webserver:[2016-04-10T21:58:53.107Z]: (1460325533107): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-04-10T21:58:53.107Z]: (1460325533107): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/img/system/Balloon.png
server:emulator-webserver:[2016-04-10T21:58:53.107Z]: (1460325533107): Other file request, fullPath = /C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/img/system/Balloon.png
server:emulator-webserver:[2016-04-10T21:58:53.113Z]: (1460325533113): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-04-10T21:58:53.114Z]: (1460325533114): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/img/system/Shadow1.png
server:emulator-webserver:[2016-04-10T21:58:53.114Z]: (1460325533114): Other file request, fullPath = /C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/img/system/Shadow1.png
server:emulator-webserver:[2016-04-10T21:58:53.120Z]: (1460325533120): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-04-10T21:58:53.120Z]: (1460325533120): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/img/system/Shadow2.png
server:emulator-webserver:[2016-04-10T21:58:53.120Z]: (1460325533120): Other file request, fullPath = /C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/img/system/Shadow2.png
server:emulator-webserver:[2016-04-10T21:58:53.126Z]: (1460325533126): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-04-10T21:58:53.126Z]: (1460325533126): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/img/system/Damage.png
server:emulator-webserver:[2016-04-10T21:58:53.126Z]: (1460325533126): Other file request, fullPath = /C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/img/system/Damage.png
server:emulator-webserver:[2016-04-10T21:58:53.128Z]: (1460325533128): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-04-10T21:58:53.128Z]: (1460325533128): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/img/system/States.png
server:emulator-webserver:[2016-04-10T21:58:53.128Z]: (1460325533128): Other file request, fullPath = /C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/img/system/States.png
server:emulator-webserver:[2016-04-10T21:58:53.136Z]: (1460325533136): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-04-10T21:58:53.136Z]: (1460325533136): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/img/system/Weapons1.png
server:emulator-webserver:[2016-04-10T21:58:53.136Z]: (1460325533136): Other file request, fullPath = /C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/img/system/Weapons1.png
server:emulator-webserver:[2016-04-10T21:58:53.140Z]: (1460325533140): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-04-10T21:58:53.140Z]: (1460325533140): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/img/system/Weapons2.png
server:emulator-webserver:[2016-04-10T21:58:53.141Z]: (1460325533141): Other file request, fullPath = /C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/img/system/Weapons2.png
server:emulator-webserver:[2016-04-10T21:58:53.148Z]: (1460325533148): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-04-10T21:58:53.148Z]: (1460325533148): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/img/system/Weapons3.png
server:emulator-webserver:[2016-04-10T21:58:53.149Z]: (1460325533149): Other file request, fullPath = /C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/img/system/Weapons3.png
server:emulator-webserver:[2016-04-10T21:58:53.150Z]: (1460325533150): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-04-10T21:58:53.150Z]: (1460325533150): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/img/system/ButtonSet.png
server:emulator-webserver:[2016-04-10T21:58:53.150Z]: (1460325533150): Other file request, fullPath = /C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/img/system/ButtonSet.png
server:emulator-webserver:[2016-04-10T21:58:54.330Z]: (1460325534330): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-04-10T21:58:54.330Z]: (1460325534330): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/audio/se/Cursor2.m4a
server:emulator-webserver:[2016-04-10T21:58:54.330Z]: (1460325534330): Other file request, fullPath = /C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/audio/se/Cursor2.m4a
server:emulator-webserver:[2016-04-10T21:58:54.332Z]: (1460325534332): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-04-10T21:58:54.332Z]: (1460325534332): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/audio/se/Decision1.m4a
server:emulator-webserver:[2016-04-10T21:58:54.333Z]: (1460325534333): Other file request, fullPath = /C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/audio/se/Decision1.m4a
server:emulator-webserver:[2016-04-10T21:58:54.339Z]: (1460325534339): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-04-10T21:58:54.340Z]: (1460325534340): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/audio/se/Cancel2.m4a
server:emulator-webserver:[2016-04-10T21:58:54.340Z]: (1460325534340): Other file request, fullPath = /C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/audio/se/Cancel2.m4a
server:emulator-webserver:[2016-04-10T21:58:54.341Z]: (1460325534341): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-04-10T21:58:54.341Z]: (1460325534341): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/audio/se/Buzzer1.m4a
server:emulator-webserver:[2016-04-10T21:58:54.342Z]: (1460325534342): Other file request, fullPath = /C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/audio/se/Buzzer1.m4a
server:emulator-webserver:[2016-04-10T21:58:55.013Z]: (1460325535013): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-04-10T21:58:55.013Z]: (1460325535013): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/img/titles1/Castle.png
server:emulator-webserver:[2016-04-10T21:58:55.013Z]: (1460325535013): Other file request, fullPath = /C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/img/titles1/Castle.png
server:emulator-webserver:[2016-04-10T21:58:55.049Z]: (1460325535049): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-04-10T21:58:55.049Z]: (1460325535049): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/audio/bgm/Theme6.m4a
server:emulator-webserver:[2016-04-10T21:58:55.049Z]: (1460325535049): Other file request, fullPath = /C/Users/tpeti/AppData/Local/XDK/xdk-scratchdir/f1097ed8-02d3-4f8d-a86c-603419bb0e1f/platforms/ios/www/audio/bgm/Theme6.m4a
xdk:client:[2016-04-10T21:58:56.732Z]: (1460325536732): memmrk:    66269308    86863488
xdk:server:[2016-04-10T21:58:57.734Z]: (1460325537734): memmrk:    75936712    103341056
xdk:client:[2016-04-10T21:59:01.732Z]: (1460325541732): memmrk:    67373184    87867008
client:remote-tab:[2016-04-10T21:59:01.838Z]: (1460325541838): About to start needsDebugModule in addTabWatcher
xdk:server:[2016-04-10T21:59:02.734Z]: (1460325542734): memmrk:    76121924    103341056
client:remote-tab:[2016-04-10T21:59:05.032Z]: (1460325545032): About to start needsDebugModule in addTabWatcher
xdk:client:[2016-04-10T21:59:06.733Z]: (1460325546733): memmrk:    63533264    87867008
xdk:server:[2016-04-10T21:59:07.735Z]: (1460325547735): memmrk:    66543452    103341056
xdk:client:[2016-04-10T21:59:11.733Z]: (1460325551733): memmrk:    65163828    87867008
xdk:server:[2016-04-10T21:59:12.735Z]: (1460325552735): memmrk:    66553112    103341056
xdk:client:[2016-04-10T21:59:16.737Z]: (1460325556737): memmrk:    62985336    87867008
xdk:server:[2016-04-10T21:59:17.735Z]: (1460325557735): memmrk:    66560112    103341056
xdk:client:[2016-04-10T21:59:21.743Z]: (1460325561743): memmrk:    63961600    87867008
xdk:server:[2016-04-10T21:59:22.736Z]: (1460325562736): memmrk:    63967848    80551296
xdk:client:[2016-04-10T21:59:26.745Z]: (1460325566745): memmrk:    64961044    87867008
client:remote-tab:[2016-04-10T21:59:26.932Z]: (1460325566932): About to start needsDebugModule in addTabWatcher
xdk:server:[2016-04-10T21:59:27.736Z]: (1460325567736): memmrk:    64213080    80551296
client:remote-tab:[2016-04-10T21:59:29.121Z]: (1460325569121): About to start needsDebugModule in addTabWatcher
xdk:client:[2016-04-10T21:59:31.747Z]: (1460325571747): memmrk:    62934500    87867008
xdk:server:[2016-04-10T21:59:32.736Z]: (1460325572736): memmrk:    64341464    80551296
xdk:client:[2016-04-10T21:59:36.747Z]: (1460325576747): memmrk:    65683508    87867008
xdk:server:[2016-04-10T21:59:37.736Z]: (1460325577736): memmrk:    60987808    78532096
xdk:client:[2016-04-10T21:59:41.748Z]: (1460325581748): memmrk:    66587168    87867008
xdk:server:[2016-04-10T21:59:42.737Z]: (1460325582737): memmrk:    60997588    78532096
xdk:client:[2016-04-10T21:59:46.749Z]: (1460325586749): memmrk:    63899216    87867008
xdk:server:[2016-04-10T21:59:47.738Z]: (1460325587738): memmrk:    61005776    78532096
xdk:client:[2016-04-10T21:59:51.750Z]: (1460325591750): memmrk:    64583324    87867008
xdk:server:[2016-04-10T21:59:52.754Z]: (1460325592754): memmrk:    60207840    75521536
xdk:client:[2016-04-10T21:59:56.750Z]: (1460325596750): memmrk:    65615224    87867008
xdk:server:[2016-04-10T21:59:57.755Z]: (1460325597755): memmrk:    60217084    75521536
xdk:client:[2016-04-10T22:00:01.751Z]: (1460325601751): memmrk:    66453880    87867008
xdk:server:[2016-04-10T22:00:02.755Z]: (1460325602755): memmrk:    60485448    75554432
xdk:client:[2016-04-10T22:00:06.752Z]: (1460325606752): memmrk:    63706680    87867008
xdk:server:[2016-04-10T22:00:07.755Z]: (1460325607755): memmrk:    58736216    75554432
xdk:client:[2016-04-10T22:00:11.753Z]: (1460325611753): memmrk:    64736772    87867008
xdk:server:[2016-04-10T22:00:12.756Z]: (1460325612756): memmrk:    58743652    75554432
xdk:client:[2016-04-10T22:00:16.753Z]: (1460325616753): memmrk:    65421604    87867008
xdk:server:[2016-04-10T22:00:17.756Z]: (1460325617756): memmrk:    58750676    75554432
xdk:client:[2016-04-10T22:00:21.753Z]: (1460325621753): memmrk:    66845384    87867008
xdk:server:[2016-04-10T22:00:22.757Z]: (1460325622757): memmrk:    58757684    75554432
xdk:client:[2016-04-10T22:00:26.754Z]: (1460325626754): memmrk:    65879840    87867008
xdk:server:[2016-04-10T22:00:27.757Z]: (1460325627757): memmrk:    58764692    75554432
client:remote-tab:[2016-04-10T22:00:28.389Z]: (1460325628389): About to start needsDebugModule in addTabWatcher
client:build-tab:[2016-04-10T22:00:31.472Z]: (1460325631472): [updatePageState] Set State: PAGE_STATE_PREPARING
client:build-tab:[2016-04-10T22:00:31.474Z]: (1460325631474): [uploadBuildAssets] Uploading project files
xdk:client:[2016-04-10T22:00:31.753Z]: (1460325631753): memmrk:    68538552    97271296
xdk:server:[2016-04-10T22:00:32.761Z]: (1460325632761): memmrk:    73532540    94285056
xdk:client:[2016-04-10T22:00:36.753Z]: (1460325636753): memmrk:    69274044    97271296
xdk:server:[2016-04-10T22:00:37.761Z]: (1460325637761): memmrk:    72702588    95300736
xdk:client:[2016-04-10T22:00:41.753Z]: (1460325641753): memmrk:    69904100    97271296
xdk:server:[2016-04-10T22:00:42.761Z]: (1460325642762): memmrk:    77727400    101394816
xdk:client:[2016-04-10T22:00:46.755Z]: (1460325646755): memmrk:    70581824    97271296
xdk:server:[2016-04-10T22:00:47.761Z]: (1460325647761): memmrk:    68954684    102410496
xdk:client:[2016-04-10T22:00:51.755Z]: (1460325651755): memmrk:    71211188    97271296
xdk:server:[2016-04-10T22:00:52.761Z]: (1460325652761): memmrk:    69310964    103426176
xdk:client:[2016-04-10T22:00:56.755Z]: (1460325656755): memmrk:    71890944    97271296
xdk:server:[2016-04-10T22:00:57.762Z]: (1460325657762): memmrk:    78307932    103426176
client:build-tab:[2016-04-10T22:00:58.509Z]: (1460325658509): [updatePageState] Set State: PAGE_UPLOADING_PROJECT
xdk:client:[2016-04-10T22:01:01.755Z]: (1460325661755): memmrk:    73672584    98286976
xdk:server:[2016-04-10T22:01:02.762Z]: (1460325662762): memmrk:    85253128    109520256
Node Webkit Error log:
[6648:0410/235054:INFO:CONSOLE(17)] ""xdk:client:[2016-04-10T21:50:54.990Z]: (1460325054990): Failed to load theme: xdk" {"code":"MODULE_NOT_FOUND"}", source: C:\Users\tpeti\AppData\Local\Intel\XDK\xdk\core-modules\private\logger.js (17)
[6648:0410/235123:INFO:CONSOLE(212)] ""NW proxy string: DIRECT"", source: /brackets.js (212)
[6648:0410/235123:INFO:CONSOLE(17)] ""client:build-tab:[2016-04-10T21:51:23.745Z]: (1460325083745): [refreshPage] Unable to generate project hash." {"message_":"no project selected","code_":null,"componentName_":null,"stack_":"Error\n    at new ComponentError (C:\\Users\\tpeti\\AppData\\Local\\Intel\\XDK\\xdk\\core-modules\\public\\component-error.js:17:1122)\n    at makeError (file:///C:/Users/tpeti/AppData/Local/Intel/XDK/xdk/components/client/backend-service-utils/backend-service-utils.js:17:187)\n    at Object.exports.generateProjectHash (file:///C:/Users/tpeti/AppData/Local/Intel/XDK/xdk/components/client/backend-service-utils/backend-service-utils.js:17:1440)\n    at _refreshPage (file:///C:/Users/tpeti/AppData/Local/Intel/XDK/xdk/components/client/build-tab/build-tab.js:17:6994)\n    at Object.start (file:///C:/Users/tpeti/AppData/Local/Intel/XDK/xdk/components/client/build-tab/build-tab.js:17:3869)\n    at resumeClientInit (C:\\Users\\tpeti\\AppData\\Local\\Intel\\XDK\\xdk\\core-modules\\private\\main.js:17:12040)\n    at C:\\Users\\tpeti\\AppData\\Local\\Intel\\XDK\\xdk\\core-modules\\private\\main.js:17:1734\n    at _fulfilled (C:\\Users\\tpeti\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\q\\q.js:834:54)\n    at self.promiseDispatch.done (C:\\Users\\tpeti\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\q\\q.js:863:30)\n    at Promise.promise.promiseDispatch (C:\\Users\\tpeti\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\q\\q.js:796:13)"}", source: C:\Users\tpeti\AppData\Local\Intel\XDK\xdk\core-modules\private\logger.js (17)
[6648:0410/235126:INFO:CONSOLE(17)] ""client:build-tab:[2016-04-10T21:51:26.945Z]: (1460325086945): [refreshPage] Unable to generate project hash." {"message_":"no project selected","code_":null,"componentName_":null,"stack_":"Error\n    at new ComponentError (C:\\Users\\tpeti\\AppData\\Local\\Intel\\XDK\\xdk\\core-modules\\public\\component-error.js:17:1122)\n    at makeError (file:///C:/Users/tpeti/AppData/Local/Intel/XDK/xdk/components/client/backend-service-utils/backend-service-utils.js:17:187)\n    at Object.exports.generateProjectHash (file:///C:/Users/tpeti/AppData/Local/Intel/XDK/xdk/components/client/backend-service-utils/backend-service-utils.js:17:1440)\n    at _refreshPage (file:///C:/Users/tpeti/AppData/Local/Intel/XDK/xdk/components/client/build-tab/build-tab.js:17:6994)\n    at file:///C:/Users/tpeti/AppData/Local/Intel/XDK/xdk/components/client/build-tab/build-tab.js:17:2905\n    at Promise.apply (C:\\Users\\tpeti\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\q\\q.js:1165:26)\n    at Promise.promise.promiseDispatch (C:\\Users\\tpeti\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\q\\q.js:788:41)\n    at C:\\Users\\tpeti\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\q\\q.js:1391:14\n    at runSingle (C:\\Users\\tpeti\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\q\\q.js:137:13)\n    at flush (C:\\Users\\tpeti\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\q\\q.js:125:13)"}", source: C:\Users\tpeti\AppData\Local\Intel\XDK\xdk\core-modules\private\logger.js (17)
[6648:0410/235634:INFO:CONSOLE(17)] ""builds:[2016-04-10T21:56:34.103Z]: (1460325394103): Error building UI for: certificateId"", source: C:\Users\tpeti\AppData\Local\Intel\XDK\xdk\core-modules\private\logger.js (17)
[6648:0410/235853:ERROR:audio_low_latency_output_win.cc(181)] Bailing out due to non-perfect timing.  Buffer size of 480 is not an even divisor of 1056
[6648:0411/000059:INFO:CONSOLE(0)] "Refused to set unsafe header "Content-Length"", source: file:///C:/Users/tpeti/AppData/Local/Intel/XDK/xdk/public/index-node-webkit.html (0)
[6648:0411/000106:INFO:CONSOLE(0)] "Refused to set unsafe header "Content-Length"", source: file:///C:/Users/tpeti/AppData/Local/Intel/XDK/xdk/public/index-node-webkit.html (0)
[6648:0411/000107:INFO:raw_input_data_fetcher_win.cc(101)] RegisterRawInputDevices() failed for RIDEV_REMOVE: A param�ter nem megfelel�. (0x57)
[6648:0411/000107:INFO:dispatcher_host.cc(151)] [NW.JS]RenderProcessCrashed
[6648:0411/000107:FATAL:render_process_host_impl.cc(479)] Check failed: !g_exited_main_message_loop.
XDK exit code & signal: 2147483651, null
Crash minidump not found in XDK data folder. Falling back to TEMP...
Crash minidump NOT FOUND.
NW Crash Detected.
PaulF_IntelCorp
Did you use non-ASCII characters (non-English characters) to name your Android cert? If so, please create a new Android cert and use only 7-bit ASCII characters (English) characters for the alias name and for the passwords. See if that makes a difference.
