Software Archive
Read-only legacy content
17060 Discussions
Intel XDK upgrade Ionic Version
Leandro_S_1
i use intel xdk with ionic framework, but this version support in xdk is too old (1.0.0 beta 1.4). I try override files in dir ionic for new files (version 1.3) but my app doesn't works fine... For example in my css i have this:
.platform-ios .platform-nav {
    display: block;
Works fine on version beta, but after upgrade doesn't work.
My question is: How can i upgrade ionic version on Intel XDK?
PaulF_IntelCorp
The App Designer component of the XDK (the UI layout tool) does not support the use of later versions of the Ionic framework. If you want to use a later version of Ionic you'll need to create your app with that framework outside of App Designer. > https://software.intel.com/en-us/xdk/faqs/app-designer#best-app-designer-framework <
