Software Archive
Read-only legacy content
17060 Discussions
Intel XDk HTML5 file uploads to PHP server script
Zack_S_
Good day,
I have spent many days learning and have progressed quite a bit but I am stilling missing the plot somewhere and would appreciate your guidance.
I have successfully build a number of pages that respectively can take pictures and I got a PHP server script running that receives the picture upload. One problem here is that the same image is uploaded every time and not the new picture taken.
I have further successfully got the geolocation feature working perfectly
Lastly I got the QR code reader working fine.
My problem is the following: I do not quite understand the concept of creating a text file and capture an image and uploading this on the same page within the app. My objective is as follows: To take a picture, add related and relevant text, then add the geolocation where the picture was taken. This I then want to upload to my web server using a PHP server side script. Lastly I need to write the info to a sql database. I would really apprectiate some guidance and/or examples.
I am pastinfg the current PHP script that work for the image on the server side below
<?php
ob_start();
echo "<pre>";
print_r($_FILES);
print_r($_GET);
print_r($_POST);
echo "</pre>";
print_r("file type: " . $_FILES["Filedata"]["type"]);
$allowedExts = array("gif", "jpeg", "jpg", "png");
$temp = explode(".", $_FILES["Filedata"]["name"]);
$extension = end($temp);
if ((($_FILES["Filedata"]["type"] == "image/gif")
|| ($_FILES["Filedata"]["type"] == "image/jpeg")
|| ($_FILES["Filedata"]["type"] == "image/jpg")
|| ($_FILES["Filedata"]["type"] == "image/pjpeg")
|| ($_FILES["Filedata"]["type"] == "image/x-png")
|| ($_FILES["Filedata"]["type"] == "image/png"))
&& ($_FILES["Filedata"]["size"] < 9999999999)
&& in_array($extension, $allowedExts))
  if ($_FILES["Filedata"]["error"] > 0)
    echo "Return Code: " . $_FILES["Filedata"]["error"] . "<br>";
  else
    echo "Upload: " . $_FILES["Filedata"]["name"] . "<br>";
    echo "Type: " . $_FILES["Filedata"]["type"] . "<br>";
    echo "Size: " . ($_FILES["Filedata"]["size"] / 1024) . " kB<br>";
    echo "Temp file: " . $_FILES["Filedata"]["tmp_name"] . "<br>";
    if (file_exists("upload/" . $_FILES["Filedata"]["name"]))
      echo $_FILES["Filedata"]["name"] . " already exists. ";
    else
      move_uploaded_file($_FILES["Filedata"]["tmp_name"],
      "upload/" . $_FILES["Filedata"]["name"]);
      echo "Stored in: " . "upload/" . $_FILES["Filedata"]["name"];
else
  echo "Invalid file";
  $data=ob_get_clean();
$fp=fopen("debug.txt","w+");
fputs($fp,$data);
fclose($fp);
Elroy_A_Intel
In order to capture images from your device's camera, I recommend using the Apache Cordova* Camera plugin API. In regards to getting the use's location, consider using the Apache Cordova* Geolocation plugin API. For developing a project that upload data to a server, visit http://www.ibm.com/developerworks/library/wa-html5db/.
