Software Archive
Read-only legacy content
17060 Discussions
Intel Xeon Phi assembly code
King_Crimson
Dear experts,
I'm not experienced in assembly, so I would appreciate it if you could help correlate the following assembly to the oneliner source.
source:
T localDistance = surfaceList[surfaceInnerIndex - 1]->CalculateDistance(attr->position, attr->direction, isCoincident);
// each element of the surfaceList is a surface object
// CalculateDistance() is a virtual function
corresponding assembly:
1       movq  0x20(%r13), %r10
2       movq  -0x8(%r10,%r9,8), %rdi
3       lea 0x1b0(%rsp), %rsi
4       movq  (%rdi), %r11  0
5       lea 0x1c8(%rsp), %rdx
6       callq  (%r11)   0
I understand that, for example, line 2 is copying mem[r10 - 8 + 8 * r9] to rdi, but what is the corresponding operation in the source? Thanks for any hints.
James_C_Intel2
Without seeing the class declarations and a bit more of the code so that we can work out what is in which register it's a bit hard to tell, but my guess (based on the -8 offset) is that that is the load of surfaceList[surfaceInnerIndex - 1]
King_Crimson
Hi James,
Thanks for your reply. Below is the class declaration. The surfaceList is a std::vector<Surface<double>*> of pointers each pointing to a derived-class surface. Please let me know if other code snippets are necessary.
enum class SurfaceType
    SXPlane,
    SYPlane,
    SZPlane,
    SXCylinder,
    SYCylinder,
    SZCylinder,
    SSphere,
template<typename T>
class Surface
public:
    int index;
    int innerIndex;
    SurfaceType surfaceType;
    std::vector<int> positiveCellInnerIndexList;
    std::vector<int> negativeCellInnerIndexList;
    Sense CalculateSense(const Vector3<T>& position, const Vector3<T>& direction);
    virtual T CalculateDistance(const Vector3<T>& position, const Vector3<T>& direction, bool isCoincident) = 0;
    virtual T EvaluateSurfaceEquation(const Vector3<T>& position) = 0;
    virtual Vector3<T> CalculateNormal(const Vector3<T>& position) = 0;
    virtual size_t GetClassSize();
