Software Archive
Read-only legacy content
17060 Discussions
Intel compiler version update
Dinesh_M_
We are using Intel compilers with icc version as 11.1 20090511
One of the cluster user is getting following error while building source of milcv7.7.8 code.
com_mpi.o: In function initialize_machine': ../generic/com_mpi.c:(.text+0xb447): undefined reference to_mm_idivrem_epi32'
after going through the Intel forum I have found that this issue is fixed in subsequent updates (DPD200142326) according to document ..
I want to know
if I can install those updates with my current licence?
If yes then what are the steps I need to follow?
If I update will my current software stack be affected?
Hubert_H_Intel
Dinesh,
From the registrations I see under your account you are able to download and install newest versions of the Intel® Fortran Composer XE. You can install several versions side-by-side on your system. So you can keep your existing installation and install a newer version too using your existing product activation. The existing installation will not be affected hereby.
Regards, Hubert.
