Software Archive
Read-only legacy content
Intel xdk, admob problem (construct 2)
yusuf_m_
Hello
I export my project from construct 2 and upload it to intel xdk, Then I chose the Cordova plugin AdMob (cranberrygame)
After everything is done, I build the apk file. But when I run my app the ads  doesn't  shows up.
Can someone help, please solve this problem?
PaulF_IntelCorp
You may have to add code to your app to make the ads appear; I'm not sure if C2 provides direct support for that AdMob plugin. See the AdMob sample apps for examples of how the code works with that plugin's API, you'll find them in that plugin's GitHub repo.
yusuf_m_
thanks Paul F
 i did the right steps in construct 2, but when i import the project to intel XDK and i add the admob plugin, the ads work when i run the xdk emulator, but when i export th apk file the ads doesn't  shows up
PaulF_IntelCorp
