Software Archive
Read-only legacy content
17060 Discussions
Internal compiler error
eunoia
I have been trying to compile the cilkplus branch of the gcc 4.7 compiler on a 32 bit machine running ubuntu 10.10 compiling with
gcc version 4.4.5 (Ubuntu/Linaro 4.4.4-14ubuntu5)
It goes a long way into the comple until it reaches the libcilkrts compile in stage 3 at which point it gives the following error:
../.././libcilkrts/runtime/metacall_impl.c: In function __cilkrts_metacall:
../.././libcilkrts/runtime/metacall_impl.c:45:23: internal compiler error: in expand_builtin_cilk_metadata, at cilk.c:1071
Any idea what I am doing wrong?
Balaji_I_Intel
Can you please tell me what command you are using to configure the compiler?
Balaji V. Iyer.
eunoia
I used the following
./configure --prefix=/usr/local/cilk --enable-shared --enable-languages=c,c++ LD_LIBRARY_PATH=/usr/lib:/usr/local/lib --with-mpfr-lib=$(pwd)/mpfr/.libs --with-mpfr-include=$(pwd)/mpfr/include --with-gmp-include=$(pwd)/gmp --with-gmp-lib=$(pwd)/gmp/.libs LD_RUN_PATH=/usr/lib
I also have the following versions of bison, flex, gmp, mpfr and mpc installed:
bison 2.5
flex 2.5.35
gmp 4.3.2
mpfr 2.42
mpc 0.8.1
patrick_marlier
Just to report that I see the same thing on i686 (32bits) / fedora so probably you can reproduce this with 32 bits.
Some info (revision 184130):
(gdb) bt
#2 0x087902c5 in expand_builtin_cilk_metadata (annotation=0xb7c7527c "cilkscreen_metacall", exp=0xb7c754a4) at ../../cilkplus/gcc/cilk.c:1071
#3 0x081ee504 in expand_builtin (exp=0xb7c754a4, target=0xb7bed33c, subtarget=0x0, mode=VOIDmode, ignore=1)
at ../../cilkplus/gcc/builtins.c:6964
#4 0x082e7602 in expand_expr_real_1 (exp=0xb7c754a4, target=0x0, tmode=VOIDmode, modifier=EXPAND_NORMAL, alt_rtl=0x0)
at ../../cilkplus/gcc/expr.c:9998
#5 0x08220b3c in expand_call_stmt (stmt=0xb7caa000) at ../../cilkplus/gcc/cfgexpand.c:2077
#6 expand_gimple_stmt_1 (stmt=0xb7caa000) at ../../cilkplus/gcc/cfgexpand.c:2116
#7 expand_gimple_stmt (stmt=0xb7caa000) at ../../cilkplus/gcc/cfgexpand.c:2271
#8 0x082224e2 in expand_gimple_basic_block (bb=0xb7bf161c) at ../../cilkplus/gcc/cfgexpand.c:4020
(gdb)
1071 gcc_assert (loc_ref);
(gdb) l
1066 }
1067
1068 loc_ref = loc_descriptor (metadata_info.reg_rtx, VOIDmode,
1069 VAR_INIT_STATUS_UNKNOWN);
1070
1072 size = (unsigned short) size_of_locs (loc_ref);
1073
1074 metadata_info.dwarf_expr = (unsigned short)(size & 0xFF) |
1075 (unsigned short) (loc_ref->dw_loc_opc << 8);
(gdb) p debug_tree(exp)
type
align 8 symtab 0 alias set -1 canonical type 0xb7bf676c
pointer_to_this >
side-effects nothrow
fn
type
unsigned SI
size
unit size
align 32 symtab 0 alias set -1 canonical type 0xb7ca5258>
constant
arg 0
addressable used nothrow public external built-in decl_5 QI file line 0 col 0
align 8 built-in BUILT_IN_NORMAL:BUILT_IN_NOTIFY_INTRINSIC
(mem:QI (symbol_ref:SI ("__notify_intrinsic") [flags 0x41] ) [0 S1 A8]) chain >>
arg 0
type
unsigned SI size unit size
align 32 symtab 0 alias set 4 canonical type 0xb7ca512c>
readonly constant
arg 0
readonly constant static "cilkscreen_metacall\000">
../../../cilkplus/libcilkrts/runtime/metacall_impl.c:45:24>
arg 1
type
public unsigned SI size unit size
align 32 symtab 0 alias set -1 canonical type 0xb7ca51f4>
arg 0
addressable used BLK file ../../../cilkplus/libcilkrts/runtime/metacall_impl.c line 38 col 21
size
unit size
align 32 context
(mem/c:BLK (plus:SI (reg/f:SI 54 virtual-stack-vars)
(const_int -12 [0xfffffffffffffff4])) [2 d+0 S12 A32])>
../../../cilkplus/libcilkrts/runtime/metacall_impl.c:45:47>
../../../cilkplus/libcilkrts/runtime/metacall_impl.c:45:23>
I hope this can help you. Thanks for your work on Cilk/GCC!
Balaji_I_Intel
Hello Patrick and Eunoia,
It seem to work fine on a 64 bit machine and I think it has something to do with the 32 bit machine description of x86. I will investigate this and will let you know if I get more information.
Patrick, Thank you for giving me the additional information.
thanks,
Balaji V. Iyer.
Balaji_I_Intel
Hello Everyone,
I have fixed this bug and submitted a patch to GCC. Here is the snapshot for the updated version (http://gcc.gnu.org/git/?p=gcc.git;a=snapshot;h=9772b731380e25c3250e1d445c143854526c7d60;sf=tgz).
Please let me know if you have any additional problems.
Balaji V. Iyer.
patrick_marlier
Works for me.
Thanks a lot ;)
