Software Archive
Read-only legacy content
17060 Discussions
Invalid image path
sagar_s_
I have build and tested my game successfully on  intel XDK IOS using provisioning profile.   When I build with IOS distribution profile and try to upload the ipa file using Application Loader I get an error like
Error ITMS-90032: Invalid Image Path- No image found at the path referenced under key 'CFBundleIcons': 'icon-60@30x"
I saw a similar discussion on this forum on similar issue here  https://forums.html5dev-software.intel.com/viewtopic.php?f=34&t=10058, but the discussion did not cover the solution.
Can somebody please guide?
Eric_H_Intel
Which version of iOS are you targeting?  (You must target iOS 7 or greater for iPhone 6 images).
Which version of Cordova are you building?
Eric
sagar_s_
IOS version is 8
Cordova CLI version is 4.1.2
Eric_H_Intel
I'll take a look and see what is going on.
Eric
sagar_s_
I checked the build log for the project VortexImpossible. In the build log I see that image cp has failed ad the icon is not found. I have provided the icons. For some reason XDK is not able to find it.
sagar_s_
is there any update?
sagar_s_
i solved this problem. If the 180x180 icon extension is PNG rather than png this problem happens.
Sagar
Swati_S_Intel1
@Sagar, glad you found the problem. We'll make a note of it.
Swati
