Software Archive
Read-only legacy content
17060 Discussions
Ionic angular.js
nicolas_r_
hi im trying to build an apk. and i need to know if is posible whit intel xdk using ionic as framework get info from a DB  using php from a server like mySql im using Mamp but i need some help whit the connection. if some one can help or have a guide to follow or even know if is posible to do what im trying. if the problem is ionic i can use also Jquery. thanks for any information about.
Diego_Calp
Valued Contributor I
Hi Nicolas,
It is all possible, and you may use any framework you want.
I suggest you learn about RESTful, this is the way to call to a remote database from a mobile app. You may not need php at all.
Some tools that you could use:
http://phprestsql.sourceforge.net
Because you talk about php, I think this may be an easy starting point, I never tested it.
www.dreamfactory.com
Open source tool that generates a complete REST api for several databases, including MySQL and some NoSQL.
I used it a lot with XDK.
But the very first step is to understand that in your mobile app you don't have php, so if you come form web php+MySQL development you need to change the way you work. Learn about REST.
Good luck,
Diego
