Software Archive
Read-only legacy content
17060 Discussions
Ios and webrtc plugin
Flemming_P_
Hi here
Has anyone had luck with build for ios with an webrtc plugin ?
Elroy_A_Intel
WebRTC is not supported in any version of iOS including the latest version 9.3.
Flemming_P_
Thanks  .. but that is why I need a plugin as from cordova
http://cordova.apache.org/plugins/?q=webrtc&platforms=cordova-ios
some off these I can load in xdk but they fail on build
R/Flemming
Zhen_Z_Intel
Hi Flemming, you could use this Cordova plugin which uses SIP.js with the PhoneRTC plugin to make WebRTC calls over the internet. Please access from following link: https://github.com/onsip/onsip-cordova
Hope this document could help you. https://software.intel.com/en-us/xdk/article/webrtc-client-on-mobile-server-implementation
Or you can add the Sip.js into Bower Packages to use sip tack for WebRTC. The Sip is an application layer control protocol for WebRTC. Learn more about Sip.js from http://sipjs.com/
Flemming_P_
THANKS  FIONA !!
Since Im not too much into codes Im VERY interrested in trying out your Idear ..
BUT what is Bower Packages ?
Could you give a little step-guide in xdk how to do this, please
REGARDS
Flemming
Zhen_Z_Intel
Here is the doc about the Bower Package. Hope that helps. https://software.intel.com/en-us/xdk/docs/bower-packages-intel-xdk
Flemming_P_
Thanks .. will give it a go ..
BTW.. How do I delete old p12 certificates
REGARDS
Flemming_P_
Hi Fiona
My build now includes the sip.js fine
BUT I cant figure out where to call the js in my project-files
http://sipjs.com/guides/mobile/cordova/
I see here that this somehow has to be included
// Use plugin version of SIP.js
var SIP = cordova.require("com.onsip.cordova.Sipjs");
// Use plugin version of MediaHandler
var PhoneRTCMediaHandler = cordova.require("com.onsip.cordova.SipjsMediaHandler")(SIP);
// Set my UA to use the MediaHandler
var ua = new SIP.UA({
  mediaHandlerFactory: PhoneRTCMediaHandler
Is it config xml or some where else .. ?
REGARDS
Zhen_Z_Intel
Hi Flemming, that is the Javascript code not XML settings. The purpose of these lines of code is to set the app to use the plugin installed SIP.js and MediaHandler. This usage is for cordova with ios through using WebRTC coomunication, but in a web browser app, there is no need to set the plugin version of SIP.js. There's an example about realizing video chat on IOS app: https://github.com/onsip/onsip-cordova
Hope it could help you.
