Software Archive
Read-only legacy content
17060 Discussions
Issue with plugin SQLite in Windows build
Hamilton_Tenório_da_
Valued Contributor I
I´m trying to build a Windows APP (Cordova Hybrid) on XDK 1878. This same APP was builded OK some days ago.
Now, on building, I receive this:
Build Log:
Building a Cordova 4.1.2 application.
The application name is ConfirmAki Basica
The package name is 9HTSInformtica.ConfirmAkiBsica
Plugin "Device" (0.2.13) was installed.
Plugin "SplashScreen" (0.3.5) was installed.
Plugin "google-analytics-plugin" () was installed.
Plugin "Device" (1.0.7) was installed.
Error: Plugin "Cordova-SQLitePlugin" failed to install.
Looking at he log, the final lines are:
Processing configuration changes for plugins.
Iterating over installed plugins: [ 'org.apache.cordova.device',
  'org.apache.cordova.splashscreen',
  'com.danielcwilson.plugins.googleanalytics',
  'com.intel.xdk.device' ]
Writing out cordova_plugins.js...
Install complete for com.intel.xdk.device on windows.
Calling plugman.fetch on plugin "...\pl.st.olyv1c5c.g5q\com.brodysoft.sqlitePlugin"
Copying plugin "...\pl.st.olyv1c5c.g5q\com.brodysoft.sqlitePlugin" => "...\ConfirmAkiBasica\plugins\com.brodysoft.sqlitePlugin"
Calling plugman.install on plugin "...\ConfirmAkiBasica\plugins\com.brodysoft.sqlitePlugin" for platform "windows" with options "{"cli_variables":{},"browserify":false}"
Installing "com.brodysoft.sqlitePlugin" for windows
Install start for "com.brodysoft.sqlitePlugin" on windows.
Error during processing of action! Attempting to revert...
I tried some times. Then, I change to Android version and the build was OK.
Any ideia?
I tried today and receive the same error.
Building iOS or Android everything is OK.
Then I removed this plugin (Cordova-SQLitePlugin") the build (Windows) is OK.
Is it a problem with the plugin?
Hi, I again...
I tried to change order of plugins, remove and reinstall, and nothing. I have the same issue yet.
The same APP is builded on iOS and Cordova, but doen´t work on Windows. The error message is always the same: Error: Plugin "Cordova-SQLitePlugin" failed to install.
Someone has any idea?
John_H_Intel2
Taken directly from Windows section of https://github.com/litehelpers/Cordova-sqlite-storage
WARNING: This is still in experimental state. Please read and follow these items very carefully.
    Yes, I know that. But I used the same plugin in another APP and it works well. It is now on Microsoft Store.
    But, in this APP the build does not finish. There is an error.
    I don´t know if the problem is on XDK or on plugin.
    John_H_Intel2
    Try creating a new app, moving your code over and only selecting the plugins that you require. Do NOT use the select all box, there is currently a bug with the select all box. Add you 3rd party plugin and build.
