Software Archive
Read-only legacy content
17060 Discussions
Issue with plugins Calendar and Notification - CLI 5
Antonio_Za
I just passed from CLI 4 to 5.1.1 version and two of my plugins don't work anymore. I got a talk with the guy developed the Calendar plugin (here's the talk: https://github.com/EddyVerbruggen/Calendar-PhoneGap-Plugin/issues/265) and he suggested to ask Intel guys upgrade this Android lib:
https://github.com/EddyVerbruggen/Calendar-PhoneGap-Plugin/blob/master/plugin.xml#L66
The other one I got similar Android issue is this one: https://github.com/katzer/cordova-plugin-local-notifications. For this one too, it seems the lib is not updated.
Could someone help me?
Amrita_C_Intel
When you upgraded CLI version, did you just upgraded the CLI or both i.e. CLI and plugin?
Antonio_Za
I upgraded the CLI and also I deleted all plugins and added as brand new.
PaulF_IntelCorp
@Aaaa -- I've alerted the build engineer to insure that the build system libs are updated. In the meantime, your best bet is to use an older version of the problem plugin that is compatible with an older version of that Android SDK library file. I don't know which version that is, but Eddy might know or you could simply try older versions until you find the one that builds.
Kevin_L_3
Hi - any update on this fix? I reverted to version 4.4.6 of the Calendar plugin but its not working either. This is actually delaying me publishing to the app stores now (geniune complaint - not just a moan!) as I require this feature to provide some important functionality within my app.
Appreciate any update,
PaulF_IntelCorp
I just spoke with the responsible engineer and he is working on getting it updated in the next update of the build server. Those generally happen on a weekly basis, so I would expect it to show up in one to two weeks. They have to perform some testing to be sure nothing else gets broken, but this sort of an update has generally not caused problems.
Antonio_Za
I reverted to the 4.4.4 of this plugin and it works under the CLI 5.1.1.
Waiting for the bug resolution
Amrita_C_Intel
Great! we will update you soon!
Kevin_L_3
Hi Intel guys
I did try with the 4.4.4 version of the calendar plugin but there was not success with this. Can you update us to how your fixes are going?
Kevin
