Software Archive
Read-only legacy content
17060 Discussions
Issue with the assembly file libpxcclr.cs
HexLord
I am trying out the hand recognition function in a test app.
The application quits with the following error in Viusal Studio.  I tried to comment the psm.Enablehand() statement and the error was gone.
there seems to be a problem in the assembly file.
Pls help.
Shaleen
Pubudu-Silva_Intel
Could you share your code please, for us to have a look
HexLord
hi,
here's the code and the error again. Most of it is from the tuchless listbox sample. I did not face any issues in running the sample.
Pls help.
 public partial class MainWindow : Window
        static PXCMHandData.GestureData data;
        PXCMSenseManager sm;
        PXCMHandModule handmodule;
        PXCMHandData handdata;
        public MainWindow()
            InitializeComponent();
        private void Window_Loaded_1(object sender, RoutedEventArgs e)
            startrealsense();
            configure();
            StartFrameLoop();
        private void configure()
            PXCMHandConfiguration handcfg = handmodule.CreateActiveConfiguration();
            handcfg.EnableAllGestures();
            handcfg.LoadGesturePack("navigation");
            // Enable a gesture
            handcfg.EnableGesture("swipe");
            handcfg.EnableGesture("fist");
            handcfg.ApplyChanges();
            handcfg.Update();
            handcfg.SubscribeGesture(new PXCMHandConfiguration.OnFiredGestureDelegate(handler));
            Console.Write("config");
        private void startrealsense()
            sm = PXCMSenseManager.CreateInstance();
            Console.WriteLine("Creating SenseManager: " + sm == null ? "failed" : "success");
            Console.Write("problem");
            //       sm.EnableHand();
            handmodule = sm.QueryHand();
            handdata = handmodule.CreateOutput();
            sm.Init();
            Console.Write("here");
            //  ptc.SubscribeEvent(new PXCMTouchlessController.OnFiredUXEventDelegate(OnTouchlessControllerUXEvent));
        private void handler(PXCMHandData.GestureData gestureData)
            Console.Write("gesture");
        private void StartFrameLoop()
            sm.StreamFrames(false);
            Console.Write("frame2");
ERROR Image
