Software Archive
Read-only legacy content
17060 Discussions
JavaScript fixed with new version of ITA
Colleen_C_Intel
There has been an issue lately in launching any browser-based apps for the Intel® RealSense™ technology.  The issue is fixed and your web software will be updated in the next scheduled update window (within 30 days.) In the interim, you can go to this link to manually update the web software.
https://downloadcenter.intel.com/download/25435   (version 1.9.x of ITA)
DKryd
hello,
the license agreement at start of app states 1.7.1, was that just not updated or is it the old application? i did not install cause i do not want to be installing the old application , if it is.
Colleen_C_Intel
To update the license page would have meant touching the 2 dozen translated copies (yes, even for just a version number), which would have delayed posting further. You should find on installation that it's 1.9.x
DKryd
yes, you're correct. version 1.9.1.1008 thanks to all who got it done so quick.
Khalil_S_
Thanks ,it worked .
dslig
I already had Intel® Technology Access version 1.9.1.1008 ; repaired it anyway but still nothing happens when I try the JS SDK sample or the gesture code in this article.  https://software.intel.com/en-us/articles/building-gesture-recognition-web-apps-with-intel-realsense-sdk   I have the following form SDKinfo viewer
  • Intel(R) RealSense(TM) SDK 10.0.26.396
  • Intel(R) RealSense(TM) SDK Runtime 6.0.21.6598
  • Intel(R) RealSense(TM) Depth Camera Manager 1.4.27.52404
  • Intel(R) RealSense(TM) 3D Camera 2780
​so I pretty sure the software is ready to go. I tested the samples in the SDK; some seem to work, Camera Explorer, Camera Viewer (C++) but many just open and then close.  The SDK JavaScript* Sample loads correctly but nothing happens when I press the start button (and the camera LED do not turn on as they do the other samples that work).  Using Chrome and Edge.  Same for the JS sample Raja suggested ( http://davidslight.com/t/gesture.html ) – WEB SDK appears to run but no camera activity, no lights, nothing.  Any suggestions where to start?
