I have a doubt
I set firt menu on intel xdk file and project files on CarolZerbini2.zip
When I click on Campinas option .... goes do my website files webfiles.zip
It asks for password to enter : Login = Carol and Pass = Zerbini10 ... all case sensitive
And It should show a list menu like first but not happening
Why ?
I copied the css diretory and set correctly ( I guess)
How can I fix this ...
Thanks in advance
Marcos
www.conteudoanimal.com.br
- Tags:
- HTML5
- Intel® XDK
I didn't look through the two .zip files, but from your screenshots it looks like you are using App Framework as your UI framework. And, it looks like the first page has all the App Framework dependencies (JS and CSS), but the second one does not. You mentioned the CSS, but AF requires some JS files too, and certain attributes in the HTML. It is not a pure CSS framework.
