I have a question about the architecture of knights corner. I wonder how many Vector Processing Unit (VPU) within one physical core? Because the hardware can support 4 threads within one core, does it that mean there are four VPUs within one core? or there is only one VPU within one core, and four threads share one VPU? I am not familiar with this, Can someone answer me ?
Thank you!
Qiang
The VPU can issue an instruction from any thread on each clock cycle, but can take an instruction from an individual thread only at an interval of 2 or more cycles. 2 threads could keep the VPU running at 90% of maximum throughput, so if you are creating a simplified model, don't let it become over-optimistic. Current compilers do an excellent job of generating code which is efficient over the full range of threads per core, so there's little incentive to spend time trying to second-guess it.
Hand-coded MKL functions which take full advantage of 4 threads per core are using at least one thread for data shuffling, rather than driving the VPU.
