Software Archive
Read-only legacy content
License File
28a7qw
Hallo,
I have just started to run the Intel Composer Example "par_openMP" as described by document. When I try to compile with Intel following Compiler error occurs ....
"1>------ Erstellen gestartet: Projekt: par-OpenMP, Konfiguration: Debug Win32 ------
1>Compiling with Intel C++ Compiler 11.1.061 [IA-32]... (Intel C++
1>Environment)
1>
1>Error: A license for CCompPW could not be obtained
1>Your license has expired.
1>
1>License file(s) used were (in this order):
1> 1. Trusted Storage
1> 2. C:/Program Files/Common Files/Intel/Licenses
1> 3. C:/Program Files (x86)/Common Files/Intel/Licenses
1> 4. C:\PROGRA~1\Intel\PARALL~1\Composer\bin\ia32\*.lic
1>
1>Please visit http://www.intel.com/software/products to obtain license
1>renewal information.
1>
1>icl: error #10052: could not checkout FLEXlm license
1>Build log was saved at "file://C:\Projekte\Intel
1>Samples\getting_started\par-OpenMP\Debug\BuildLog.htm"
1>par-OpenMP - 1 error(s), 0 warning(s)
========== Erstellen: 0 erfolgreich, Fehler bei 1, 0 aktuell, 0 bersprungen ========== "
There is no *lic file stored in Folder as expected by Intel (B)
I'm fully licensed to use Intel Parallel Studio, I hope this include the Intel Compiler too. Can you tell me what is going wrong or what I'm doing wrong?
Vladimir_T_Intel
Hi Marc,
An update to Intel Parallel Composer is available for download. Please, try it out and let me know if there still the problem.
