Software Archive
Read-only legacy content
17060 Discussions
License file
Richard_H_2
I'm trying to get started with VF.  When I build the sample programs I get the error "A license for FCompW could not be obtained;" error # 10052: could not checkout FLEXlm license."
What's wrong?
mecej4
The message indicates that the license file for the compiler was either not located or did not yield a valid license for the Windows Fortran compiler. In a typical installation, you should be able to examine the environmental variable INTEL_LICENSE_FILE under System Properties->Advanced. In Windows 7, for example, the value of the variable is "C:\Program Files (x86)\Common Files\Intel\Licenses". That is a directory containing one or more license files, at least one of which must contain an entry for an unexpired license for FCompW.
Richard_H_2
Thanks, if appeared after reinstalling product two times
Feilong_H_Intel
Hi Richard, Is it still an issue for you? If it is, please use the license file I sent to you a few minutes ago. Please let me know if that solves the problem. Thanks, Feilong
Richard_H_2
Feilong--No license problems now, did not use the license you sent-Thanks
